my newly rebuilt 2.8
Old Nov 9, 2002 | 06:51 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
well, what do you think? it's been bored .040 over and the decks on both heads and block have been zerod, looking at just under 10:1 compression, runs very strong.
Old Nov 9, 2002 | 06:52 PM
mw66nova's Avatar
Engine: 7.0L
next
Old Nov 9, 2002 | 06:53 PM
mw66nova's Avatar
Engine: 7.0L
Old Nov 9, 2002 | 06:55 PM
mw66nova's Avatar
Engine: 7.0L
me working my butt off trying to get it done before homecoming dance (ended up breaking the flywheel later on the way to take my date home, needless to say, i was embarassed)
Old Nov 9, 2002 | 06:56 PM
mw66nova's Avatar
Engine: 7.0L
and the blowed up motor....the two motors at the top of the pic are a (left) 305 and (right) 350, the 350 is mine, i just don't have the money to do anything with it right now...
Old Nov 9, 2002 | 07:49 PM
V6camaroman's Avatar
damn im about to wet my pants! very nice work. that is a sweet lookin motor. now i finally got some competition.
Old Nov 9, 2002 | 07:54 PM
i also had my block zero decked. mines only runnin about 9:20 to 1 comp. my blocks also bored .040 over. i thin every little bit helps. keep me informed on what you run ni the 1/4. also what size valves do you have in there? what are your cam specs
Old Nov 9, 2002 | 08:14 PM
mw66nova's Avatar
Engine: 7.0L
right now, the cam and valves are stock specs, i don't think i will spend anymore money on this motor. i have spent alot of time and almost $3000 on this motor rebuild and i still want more horsepower. like i said, the 350 in that pic is mine, all i have to do if find a transmission. then i will build a 10:1 355 with a 750 holley vacuum secondary on top with at least a .490 lift cam.
Old Nov 9, 2002 | 08:31 PM
ah i see. i have put over $1800 into my motor alone. i really have no interest in swapping to a 350 though. none the less great job on the rebuild. its a beautiful motor.
Old Nov 9, 2002 | 08:41 PM
KED85's Avatar
What paint have you used on the intake set up?
How was it prepped before the painting?
Old Nov 9, 2002 | 08:45 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Damn, it looks good...
Old Nov 9, 2002 | 08:57 PM
third jenn's Avatar
nicely done!
my bro has a 91 firebird actually, he's going to rebuild his engine...for more power of course.
mw66nova's Avatar
Engine: 7.0L
intake manifold was painted using regular black engine paint. all i did before i painted it was i cleaned it using an engine degreaser. thanks for the copmliments guys, i worked very hard on it. i also changed the 2.8 badge to 2.9...which was done just for kicks and grins...
Old Nov 10, 2002 | 12:42 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Looks good.
Heh, I'm probably gonna paint my 3.4 block red also. I think I'll also paint the intake and plenum red.....PLUS, I have fiero valve covers which I already repainted red.
Hey, at least it'll match my interior.
Old Nov 10, 2002 | 08:49 PM
have you had the motor runnin yet? if so does it feel very strong? is it faster that your previous motor.
Old Nov 10, 2002 | 09:53 PM
mw66nova's Avatar
Engine: 7.0L
yes, the motor has been running, it is very strong on the top end, pulls like a horse, but is stubborn like donkey on low end. i think that the stock cam and the slightly bigger bore/compression boost don't like each other very much on the low end, but man, 80-100 is soo easy in this car now, any where above 3500 and this beast pulls like a ****...
Old Nov 14, 2002 | 11:07 PM
devianb's Avatar
Any of you guys have a double roller timing chain? If yes, do did you have to modify the timing plate. I want to have my engine rebuilt. These are the things I plan on adding:
Double roller timing chain
9.5:1 compression pistions
Crane CompuCam 2030
Comp Cams 1.52 roller rockers
Bored Block .030 over
3 angle valve job
port and polish
and any parts neccesary for the rebuild.
I keeping the motor naturally aspirated and I am only planning on rebuilding the engine for maximum efficience instead of performance. I use my car for driving around. I like to cruise at a comfortable speed (55 mph) while listening to music.
Anyways, that is a nice looking 2.8l rebuild.
Old Nov 15, 2002 | 09:33 AM
KJay's Avatar
I have often wondered if the 2020 cam might be a better choice. It is made to increase H.P. in the lower ranges.
Seems a better choice for a daily driver.
Old Nov 15, 2002 | 09:45 AM
KED85's Avatar
The Crane made cam is almost what is used in the 3.4 engine.
It's a great choice
Old Nov 15, 2002 | 12:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
3000 ouch, how much HP you end up with??? a crate 3.4 is only 2000 165-175 hp some mods get 200 add 150 NOS shot and 350hp later tires are flyin off the rim
Old Nov 15, 2002 | 01:27 PM
Brian K's Avatar
Need headers? Have some... Never used..
Old Nov 16, 2002 | 01:50 AM
mw66nova's Avatar
Engine: 7.0L
nope, thanks anyways, i want my 350, now. the $3000 was a little high of an estimate. That price contains a tranny rebuild also that happened this year. i am just tired of doing all of this work and spending lots of money and only getting halfway there on horsepower. i am going to put the 350 on the engine stand tomorrow if my dad lets me so that i can start taking it apart to begin the rebuild. if anyone knows of a place that i can buy a tranny for cheap or get a th350 case in the middle georgia area that would be great...
FormulasOnly
Jul 23, 2018 08:47 AM
sammy52401
Nov 11, 2015 07:20 PM
mrbird
Oct 20, 2015 03:43 AM
usafirebird
Sep 29, 2015 11:58 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
