If you own an '84, '85 or '86>>
Old Dec 23, 2002 | 08:51 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I need basic info on factory coolant fans. Please go to:
https://www.thirdgen.org/techbb2/sho...hreadid=150575
and post the year of your car, what your original engine is and whether it came with a belt-driven or electric coolant fan. Thanks.
Willie
Old Mar 31, 2003 | 07:17 PM
NEOMASTERZ28's Avatar
Car: 85 z28
85 Z28/IROCZ 305 TPI CAME WITH 1 ELECTRIC FAN
Old Apr 15, 2003 | 11:09 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
86 Trans Am WS6 305 TPI - 1 electric cooling fan
Old Apr 22, 2003 | 08:36 AM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
1986 LG4 Z28 Built in Van Nuys September 13, 1985.
Single electric fan.
Old May 1, 2003 | 12:01 AM
jocww's Avatar
Car: 84z, 65 elcamino
Transmission: t5 m21
Axle/Gears: 373s 411s
got a 84 z l69 ho and a electic fan and i m hating it alot rite now always breaking
Old May 1, 2003 | 02:02 AM
Kevs86TA's Avatar
Car: 86 Trans AM
86 Trans AM WS6 305 TPI single fan
Old May 5, 2003 | 01:43 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
85 trans am LG4 mechanical fan, no electric fans
Old May 20, 2003 | 11:01 PM
86budgetSC's Avatar
86 sport coupe.LG4 single electric.
Old May 21, 2003 | 05:42 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
84 Z28, LG4 w/o AC...V-belt driven fan
Pete
Old May 26, 2003 | 09:41 AM
conlinj's Avatar
86 Camaro Z28 305 TPI 1 Electric fan
Old May 26, 2003 | 09:50 AM
conlinj's Avatar
Old May 27, 2003 | 09:51 PM
Corbi_85-IROC's Avatar
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
85 iroc z
LG4 belt driven. No AC.
Old Jun 3, 2003 | 07:23 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
84 Z L69 i electric cooling fan whic is part of the L69 option package.
Old Jun 12, 2003 | 09:12 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
85 Berlinetta LG4,4 barrel V-belt driven with A/C
Old Jun 16, 2003 | 08:22 PM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
1984 Trans AM, L69 High Output, 5 speed transmission, 3.73 open rear. completly stock came with a single electric fan behind the radiator, my car has been overheating quite a bit. . then the fan broke replaced with 160 thermostat and new fan still over heated, had radiatior cleaned and pressure tested still overheated. replaced 195 thermostat and replaced both ecm sending units, one in the head other on gooseneck also changed fan switch..car runs better at 195 then is ever will at 160.. I spoke with a mechanic at the local gm dealer he said if none of that will fix the problem mount a secondary fan on the front of the radiatior to pust air through..
Old Jun 17, 2003 | 04:16 PM
meridius's Avatar
umm quick question about your overheating L69 does it still have the air dam under the front of the car because mine had the exact same problems yours did and I put another one on mine because mine was broken and it now runs fine
Old Jul 25, 2003 | 03:46 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Transmission: TH-350
Axle/Gears: 3:73
Fan
85 Iroc Carburated 5-speed. One electric fan.
Old Aug 6, 2003 | 01:31 AM
jocww's Avatar
i got a 84 z and my fan wont go on. i fixed the thing thats on the pass side of the block and i changed the motor in the fan too still doesnt work . at wat temp does the fan go on?
Old Aug 17, 2003 | 10:23 AM
eatmydust's Avatar
Car: 1986 IROC-Z28
1986 IROC-Z 305 TPI Single Electric fan.
Old Aug 17, 2003 | 10:32 PM
Car: 84 Trans Am
if your worried the switch is bad just take the wire and connect it to the frame....the switch works off a ground so if you hook the wire to the frame your bypassing the switch..the fan should come right on unless you have other problems..
Old Aug 18, 2003 | 03:59 PM
Car: 1985 IROC Z-28
Axle/Gears: 3:73
Could be the factory relay has gone bad. Back by the firewall on the drivers side.
Old Aug 20, 2003 | 08:54 PM
onebinky's Avatar
1985 Camaro Z28 305 TPI, single electric fan
Old Sep 1, 2003 | 12:38 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
1986 IROC-Z TPI w/ single electric fan
Old Sep 4, 2003 | 09:22 PM
breathment's Avatar
just a reminder. post all info at the link willie posted above. not in this thread.
Old Dec 26, 2003 | 07:57 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I've got an 85 LG69, but for some wierd reason, the fan is belt-driven! It's definately not factory, because it's bright-blue! I think the guy i bought it from installed it.
85 Z28 305 LG69 700r4 tranny 4bbl q-jet w/ edelbrock rebuild package, aftermarket muffler, gutted cat
Old Jan 4, 2004 | 02:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
82-85 all were mechanical fan except L69, 86-up electric
84 2.8L mechanical, 83 z28 LG4 mechanical, 84 z28 L69 electric
82 trans am LG4 mechanical, 85 trans am L69 mechanical
good luck
Old Mar 6, 2004 | 07:22 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
86 camaro 305, electric quadrajet, single electric fan... well thats what it used to have
Old Mar 11, 2004 | 11:37 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
'86 Z28 305, 700R4/TPI - 1 electric fan
Old Apr 7, 2004 | 01:31 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
fan ?
'85 trans am 305TPI, came with 1 electric fan.
have had cooling problems with the car since i got it...
so far i have replaced the radiator, then it cracked on the side plastic part...now needs to be replaced again, done a head gasket on it, and tried three different thermostats (stock 195 or what ever, 160, and 180 currently in it)
had an IROC-Z with factory dual electric fans, and never had a problem with temp. EVER not even in traffic on a 100degree day.
Old Apr 7, 2004 | 03:18 PM
'84TA w/L69's Avatar
Car: '92 Firebird
Engine: 3.1 Liter v6
Transmission: 700r4 w/shift kit
'84 TA with L69 305 HO...belt driven fan... and always seems to overheat...that'll be fixed this summer...305 comin out...350 or better goin in...
Old Apr 7, 2004 | 05:44 PM
Car: '86 Z28
Yeah when I got my car in the summer it loooved to overheat. We replaced the radiator/thermostat etc. this summer and it still did it once i think... gotta get that temp gauge fixed so i can stop it before it happens =/
Old Apr 7, 2004 | 06:47 PM
Car: 1985 IROC Z-28
Axle/Gears: 3:73
They ALL overheat. You gotta get an aluminum radiator and I haighly recommend a two-fan set-up.
Old May 6, 2004 | 03:00 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
84 TA w/L69 here....single electric fan
Old May 24, 2004 | 10:18 PM
jay92,85,79's Avatar
Car: 85z28,
I have a 85 z28 with two electric fans.Has a 305 tpi.Well I think I'm the 8th owner so who knows whats been done.
Old Jun 14, 2004 | 11:05 PM
fordsfairlane's Avatar
Car: 86 trans am
Engine: 1971 , 350 4bbr
86 t/a with a 1971 350cid 4bbr , 700r4 was belt drive now twin electric fans
Old Jun 23, 2004 | 01:12 AM
berlinettakid's Avatar
Car: 86 T/A, 86 z28, 79 berlinetta, 69 chevelle (totally rusted)
Engine: 350's in the f-bodys. 327 in the works for the T/A, MIGHT go with a 383, none in the chevelle
Transmission: T/A has a 5-speed, z28 has a 700-r4, th-350 in the 79' (5 or 6-speed soon), and none in the chevelle
Stock as W/ 2.8 v-6, single electric.
put a 350 in it, and I just started driving it a 3 days ago. I'm having stupid over heating problems.
new 180 high flow thermostat, 3 core radiator (some corrosion, hopefully thats the problem), and a new waterpump. painless electric fan kit, 200* on 185* off
The most confusing part though, It only overheats when driving faster than 10 mph. At idle It will run right at 190ish. Once I start driving It'll get up to 240 and still climb but i just shut it off once it hits 240ish.
Someone mentioned an airdam thing in front. Is this a little spoiler/wing thing that scoops air up to the radiator? And how much difference would it make if i didn't have all the thin black plastic covering stuff under the bumper. I don't have the air dam or the plastic cover things on. Could this be it?
I'm starting to wonder if it has a blown head gasket. The radiator doesn't loose ANY antifreeze though.
Any tips?
Old Aug 16, 2004 | 07:25 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
86 TA LG4 single electric fan
87 Firebird v6 single electric fan
Old Aug 23, 2004 | 11:33 PM
Car: 86 trans am
the airdam under the car is a must have item. if missing it must be replaced. mine broke off once while being dragged over a speed bump . the car ran hot as if i covered the radiator.
Old Aug 23, 2004 | 11:40 PM
Car: 86 trans am
also.....
if the intake had been replaced or any new gasket been installed on the intake . "this happened to me once." if the gasket wasn't installed correctly the water port passage could be blocked by the gasket. also i would try to bypass the heater core as some times they may leak and cause a car to over heat. i hope you get it fixed.
Old Sep 19, 2004 | 08:39 AM
chevman's Avatar
Car: 85 Camaro 3.4 converson
Engine: 3.4
Transmission: 5-speed B/W
85 2.8 liter sport coupe w A/C.
Plastic Radiator with single electric fan. Always wants to be leaking somewhere. Sometimes overheats even with the A/C off.
Old Nov 18, 2004 | 04:33 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
84 z28 lg4 v belt driven fan
Old Feb 5, 2005 | 02:34 PM
matt84z28's Avatar
Car: 1984 Camaro Z28
Engine: Turbo V6
Transmission: 200r4
1984 z28 h.o.
electric fan
Old Feb 6, 2005 | 10:11 AM
TheTrunkMonkey's Avatar
Car: 86 T/A, 90 RS (project)
Engine: 305 Quadrajet, 3.1 MPFI
Transmission: 700r4s all around
1986 Trans Am w. LG4, electric fan. Car overheats like a ****. at idle, it can get off the gauge within 15-20 minutes sometimes.
Old Feb 18, 2005 | 08:02 AM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
fan
84 trans am had 305 but now 350 both belt driven
Old Feb 23, 2005 | 09:48 PM
eflores's Avatar
Car: 91 z Clone
Engine: 6.4l LSX
Axle/Gears: s12 3.73
87 GTA 350 5spd
1 electric car has a 454 throttle body makes the 350 run a hell of alot better and a tripple core aluminum radiator
it still is hard to keep cool
Old Mar 8, 2005 | 06:56 PM
justin86z's Avatar
Car: 86 z-28
86 z-28 305 tpi 1 fan
Old Mar 24, 2005 | 08:59 PM
davey's Avatar
Car: '95 cutlass supreme, '82 F-150
Engine: 3100, 302
Transmission: auto
84 Z/28, lg4 305 4bbl, belt driven fan.
Old Apr 2, 2005 | 04:33 AM
jeff311270's Avatar
Car: 1985 iroc z
85 iroc 1 electric fan
Old Apr 6, 2005 | 11:50 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Barry85Iroc:
Is it the relay that only has 3 wires coming out of it? I asked for the relay replacement and it only has 3 wires available in the slots. All other relays have 3 in, 3 out.
Jim.
Old Apr 11, 2005 | 11:13 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Well, I answered my own question.
The part that Advanced Auto Parts gave me had 5 in-line blade receivers with the fith one blanked.
I assumed that it was the one on the right of the radiator by the battery, but it had all five blades in it. Fan still did not turn on.
Sooo, as I was reading this thread, Barry85Iroc mentioned the firewall on the drivers side. I looked and sure enough there was the relay (Part #14078902).
As soon as I plugged the new relay in, the fan started.
Whew!, now on to the next problem. Thanks for all of the insight.
Jim.
