whats a cc q-jet and a non cc q-jet????
Old Jan 6, 2003 | 01:21 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Whats the difference and how can I tell what one I have???
Old Jan 6, 2003 | 01:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
CC= computer-controlled
non-CC = non-computer-controlled
If you have a US-market 3rd gen and it has the stock carb, it's computer-controlled (or at least, it came that way). Look at the front right corner of it; if it has a blue thing sticking out the top with a connector going to it, it's computer-controlled.
Old Jan 6, 2003 | 05:13 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
QJETcarb
Try this
https://www.thirdgen.org/techbb2/sho...light=qjet+pic
Go down to Sitting bull post with the pic with Red distributor.
I have a Canadian T/A, with the non-cc Qjet. (just like the one on the pic)
Old Jan 6, 2003 | 08:20 PM
yanfoo's Avatar
Qjet
I have a question:
I was looking at Sitting bull Qjet again...
What is the "selenoid type" thing on the right front(near the throttle cable)
https://www.thirdgen.org/techbb2/att...&postid=636589
--> I dont have this piece on my car!!!!
I do have cruise control, but it's not functional and i have not look why yet.
Old Jan 6, 2003 | 08:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: Qjet
Originally posted by yanfoo
I have a question:
Maybe the throttle kicker for the A/C?
Old Jan 7, 2003 | 03:56 PM
Car: '81 Trans Am
Engine: 6.6L
ok Im still not sure but im going to look for that conector tomorow,,,,I know for sure that my choke is on the oposite side as redbull's,,,if that helps any???
Old Jan 7, 2003 | 04:11 PM
Jester's Avatar
The easiest way to tell is to look for the M/C solenoid plug. If you have a plug with a couple wires going right into the top surface of the carb itself, it's computer controlled.
Old Jan 7, 2003 | 05:53 PM
Apeiron's Avatar
Engine: 383 Carb
Your choke is on the driver's side? Not on a Qjet.
Old Jan 7, 2003 | 05:54 PM
yanfoo's Avatar
Re: Re: Qjet
I dont have AC on my car. So you might be right.
CC-Qjet should have a big "TPS" i think i saw that on Doug Roe Book.
Old Jan 10, 2003 | 11:22 AM
Car: '81 Trans Am
Engine: 6.6L
geess I cant belive i screwed that one up!!! My choke is on the pass. side! Oh well I must of been thinking of my old car with the two barel carb (i dont know?).
Ok heres the pics can you guys see if its computer controled,,,I dont think it is but I want to be 100%.
Attached Thumbnails whats a cc q-jet and a non cc q-jet????-carb-driverside-.jpg
Old Jan 10, 2003 | 11:26 AM
Car: '81 Trans Am
Engine: 6.6L
ok heres the otherside.....
Attached Thumbnails whats a cc q-jet and a non cc q-jet????-carb-passside-.jpg
Old Jan 10, 2003 | 01:12 PM
Apeiron's Avatar
Engine: 383 Carb
Doesn't look computer controlled to me, I don't see a TPS anywhere.
Old Jan 10, 2003 | 02:53 PM
zupmanZ28's Avatar
Car: 86' Z28
looks CC to me....
Attached Thumbnails whats a cc q-jet and a non cc q-jet????-carb-passside-copy.jpg
Old Jan 10, 2003 | 02:56 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
LOL, that's in a CAMARO???
That carb is a non-computer truck/van carb with the electrically activated "dual capacity" accelerator pump. Can't remember how it actually works, but I'd bet money hooking the MC solenoid connector up the grey solenoid isn't it.
The big give away is NO TPS on the driver's side.
Also, it looks like you're running a non-computer controlled distributor. I can just BARELY see the vacuum can in the pictures, behind the EGR valve.
Old Jan 10, 2003 | 03:03 PM
Pony Killer's Avatar
Car: 1986 Z28
Transmission: th400
it's not a third gen CCC carb. at least, not a standard us emmissions one....
i'd be willing to bet the distributor's got vacuum advance.
Looks like something off a truck.
A closer look at the picture, you can see the vacuum advnance distributor, that's not CCC setup. what that plug goes to.. got me by the tail.
Old Jan 10, 2003 | 03:08 PM
99Hawk120's Avatar
Found this on the net:
1985/86 Q-jets in U.S. trucks have dual capacity accelerator pumps. When the engine is cold, more fuel is needed for transition from idle to part-throttle. When the engine is warm, less fuel is required. Dual capacity pump solenoid (plug on top right front of carb) is activated by coolant temperature sensor (sensor in thermostat housing). At 170 degrees pump solenoid energizes, dual capacity pump valve opens and pump capacity reduces by about one-half.
Old Jan 10, 2003 | 03:33 PM
Apeiron's Avatar
Engine: 383 Carb
Yeah Sitting Bull's carb had the same thing, took a while to figure out what it was. I used to think it wasn't the original carb but we never ran the numbers.
Y'all can just forget everything you know about factory thirdgen Qjet setups, this is Canada.
Old Jan 10, 2003 | 03:38 PM
99Hawk120's Avatar
I don't see anything stating the original poster was in Canada. Half the other people in the thread, yes...
Old Jan 12, 2003 | 10:22 AM
Car: '81 Trans Am
Engine: 6.6L
yes my camaro is an Iroc with an LG4 305 carbed engine sold in Canada. How can I tell that my car has vacum advnce is that the vacum line coming from that round metal thing right under my distributer? Im still getting mixed ansewers on if I have a cc carb or not???
Old Jan 12, 2003 | 11:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here is a computer-controlled Q-Jet. Note the throttle position sensor over by the throttle linkage and the mixture control solenoid connection.
Old Jan 12, 2003 | 03:19 PM
Apeiron's Avatar
Engine: 383 Carb
The metal thing is actually part of the distributor, it's the vacuum advance pot. Your carb is non-CC.
Old Jan 13, 2003 | 08:36 AM
99Hawk120's Avatar
Well, it is not computer controlled, no, but it sure is an interesting lil' carb. Do yourself a favor, and trace the wires coming off the grey solenoid at the front of the carb. Unless I'm mistaken, at least one of them should run to a switch in the water jacket--possibly on the thermostat housing.
Old Jan 13, 2003 | 09:42 AM
Car: '81 Trans Am
Engine: 6.6L
I'll cheack it out,,,,but as you can see from my first pic above,,,both of those connectors on my thermostat housing are broken off??
69GTOby
Apr 18, 2016 02:34 PM
Zio
Carburetors
Apr 13, 2001 11:18 AM
fulo
Carburetors
Jan 28, 2001 02:04 PM
Z28HO
Carburetors
20
Jan 2, 2001 03:39 PM
Z28HO
Carburetors
Oct 5, 2000 02:58 PM
