Project top secret (until now) :)
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Excellent workmanship! I bet that didn't go in to easy. My hat goes of to you on a job well done...
Ok guys ,im afraid I can't take the credit for someone elses work
.A guy on the fiero board did it , actaully there is a total of 3 convertions in the works,I just wanted to see the Transam/camaro guys reaction
.It was a fairly straight forward install ,a few custom fiber glass pieces were made other then that it was a basic bolt up , the cluster is fully functional (so are the climate controls) One thing that does not work is the gas gauge but they are in the process of fixing that, other then that it looks right at home.
And knowwhere did I say I did the convertion,just for the record
.It was a fairly straight forward install ,a few custom fiber glass pieces were made other then that it was a basic bolt up , the cluster is fully functional (so are the climate controls) One thing that does not work is the gas gauge but they are in the process of fixing that, other then that it looks right at home.And knowwhere did I say I did the convertion,just for the record
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If the colors matched properly, I would tell ya the dash came stock in it. The panel rolls match quite well!!
ambainb
Apr 25, 2016 09:21 PM
is that a fourth gen dash in there?
