stock to posi
Old Jan 13, 2003 | 05:52 AM
radiateu2's Avatar
stock to posi
What would I need to turn my stock 1987 differential into a posi with a higher gear ratio like 3.42? I think I have a 2.73 in there now.
Old Jan 13, 2003 | 07:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A set of gears, and a posi carrier of the correct spines for your axles (26 in your case), and an install kit, and some fluids, and a few hours, and some tools.
Old Jan 13, 2003 | 08:24 AM
radiateu2's Avatar
hey RB
Whats a good estimate on the cost of the parts in particular the carrier? Do you know of any companies that deal in GM takeoff parts?
Thanks,
Ed
Old Jan 13, 2003 | 08:57 AM
vjo90RS8's Avatar
Car: 2002 Z28
The SLP take off posi unit (3-series carrier) is only $99, but you would have upgrade your axles from 26 to 28 spline.
Old Jan 13, 2003 | 09:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, if I were doing that for most cars, the SLP take-off is what I'd use. It came from a LS1 car, so it was installed by the factory behind about 360 HP and 375 ft-lbs of torque at the crank, and should be warrantable at that kind of moderate power level.
For other parts, look here. http://www.drivetrainspecialists.com...=28&cat=GM+7.5
Old Jan 13, 2003 | 10:48 AM
MdFormula350's Avatar
after that stuff you should have a nice posi rear diff.....
Old Jan 13, 2003 | 05:36 PM
vjo90RS8's Avatar
Car: 2002 Z28
my Richmonds 3.73s and the SLP take off posi knocked about 6 tenths off my quarter mile. it is a great unit, especially for the price.
Old Jan 13, 2003 | 09:36 PM
TransAmTBI's Avatar
Transmission: th700R4
I want to do the same thing.. i dont kow my gears cuz comeone ripped off my rpo codes but i simply want to put in a posi... i want cheap but i want posi... can i get one cheap with out changing gears or splines? i have a 88 trans am with 305 TBI LO3
Which leads me to my next question... I'm not sure what kinda trans i have.. (too lazy to go underneath and look up serial number, but when i change my shifter cable i might) I have an automatic but i heard that all trans am's with the v8 came with the 700 R4. i want to believe that but idk anyone who knows this can be of great help
Thanx
Bill
Old Jan 13, 2003 | 10:55 PM
vjo90RS8's Avatar
Car: 2002 Z28
more than likely you have 2.73 gears. It would not be a good idea to get a 2-series (for gears lower than 3.23) posi unit for a car with 26 spline axles because if you ever decide to upgrade your gears to 3.23s or higher, you will need to buy a new posi. Just save up some money and do it right the first time. It could be expensive to do it right though, i probably paid about 700 bucks for the parts and labor. I say, if you havent already put money into your exhaust, that is where it should go first.
Old Jan 13, 2003 | 11:08 PM
TransAmTBI's Avatar
well i always do my own labor.. so i would only need part prices
but id ont believe i will be going as far as changing the gears in my car since i'm happy with it for the most part
thanx for the info
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Aug 26, 2015 08:17 AM
