MAJOR problems with new March Pulleys
I recently installed the March power and amp series pulleys...and since then my battery has died and its taken a beating on my second alternator....this is what i believe happened...the alternator pulley by March is smaller in diamater...thus making more revolutions and putting more strain on the alternator...is this supposed to happen???
Car: 04 GTO
Transmission: M12 T56
Completely normal. If you want to fix the problem, put stock pulley's back on. Or would you rather keep compromising your charging system in the name of at most 10hp.
Car: 88GTA
Engine: 383
Transmission: t5 junk
if you dont wanna feel like you totally wasted your money on those pulleys just leave the crank underdrive pulley on and your charging should operate normally and u might get a couple horses out of it.
all those pulleys are is a headache especially when you have problems like that, buying new batterys and alternators
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I've had the March Power and Amp pulleys for about 4 years now on my IROC. Absolutely no problems. Car was my only car and daily driver for about 3 of those years.
Car: 04 GTO
Thats just it Buckeye. Some people get lucky and never have a problem, others sound like this guy. Thats why i say it's completely normal. And like i said, is a tenth worth constant headaches. Thats why i never got pullies. I've passed up 2 cheap sets, just because i wasn't even gonna risk the chance of problems down the road. The 2 cheap sets i've passed up, surpirse surprise, also came from people who never got their car to charge with 'em.
BTW, swapping a larger diameter alternator pulley back on will only make the problem worse. Slowing the alternator down will only make it output less. Even with the small diameter alt. pulley the alt. is spinning slower than stock. Hence 'underdrive' pulleys, although i guess nobody uses that term anymore since it's too descriptive.
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I have aluminum 3 piece on my 91...no problems whatsoever. My battery is even in the back. On my 87 GTA; however, I did have charging problems with a steel underdrive set. I fixed the problem when I happened to find a Ford alternator with a tiny diameter pulley. This sped up the alternator, but still allowed me to use the crank underdrive.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: MAJOR problems with new March Pulleys
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
JMatlock88..not to change the topic..but. What spacer did you have to use tho mount the 4rth gen wheels. I just bought a new set for the wifes 94, and I would like to use hers on my 89. They are of the 16" variety. Did you have to use the 2" spacers front and back...and do you have any rear view pics of your car....as for the underdrive pullys, alot of problems...PM or E-mail me if you like. Thanks....BTW that is one bad Bird!
Car: 1991 Formula
Mine are not 4th gen wheels. Instead they are Ronal thirdgen Firehawk wheels from 91-92. Since they were intended for 1le cars, my front wheels required a small spacer which I belive it is 3/8" The back required no spacers. I plan to change to c5 brakes soon, so the spacers will no longer be necessary for me. Do a quick search to find out what spacers you need for your application. I'm not sure what spacers you need off the top of my head, but I know they are large and costly.
Thanks man!!! :lala:
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
look i have used aluminum pulleys on 2 of my cars... no problems with either! they are not a waste of money. now on my camaro if i am at a light with my headlights on the battery gauge drops a little down around 10 to fix this just increase your idle about 200 rpms and it will be fine!
someone972
08-30-2015 12:52 AM
Navy8125
08-22-2015 07:13 PM
db057
08-11-2015 10:11 PM
