T-Tops squeecking. Im gonna throw em off at 90
Old Mar 11, 2003 | 05:02 PM
Camaro68Vette63's Avatar
Car: 1992 Z-28 Camaro
Engine: LB9 305 TPI
My T-tops are soooooooo. loud. They are constanly squecking, and its drivin me insane. I have the newer light plexiglass ones. 91 firebird. What can I do to quiet them? Help. I feel like unlatchin them at 90 on the highway.
Old Mar 11, 2003 | 05:53 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
get subframe connectors
Old Mar 11, 2003 | 07:57 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Go to the hardware store and get a spray can of silicone lubricant. Lube up the rubber weatherstripping really good. Say bye bye squeaks!
Depending on how dry your rubber is, you may have to apply quite a bit. Take your time it'll be worth it!
Old Mar 11, 2003 | 11:49 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
sweet...
Old Mar 11, 2003 | 11:58 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i heard vasoline works well too... gonna try it out tommorow. Supposed to help keep the water from getting in too.
Steve
Old Mar 12, 2003 | 09:42 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
also, dielectric grease workes real good.
thanks
Old Mar 13, 2003 | 08:15 AM
IROC57TPI's Avatar
Also the t-top mounts are adjustable. Where the pins go into the body you can take off the plastic panels with a phillips screwdriver and see the adjustable mounts.
Old Mar 13, 2003 | 10:03 PM
MdFormula350's Avatar
spray lubricant works well..
Old Mar 13, 2003 | 10:17 PM
kristopheer's Avatar
woot! i wondered how i could fix those. ;]
Old Mar 14, 2003 | 12:21 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
someone who has tried one of these solutions post and give you testimony!!!!
Old Mar 15, 2003 | 12:31 AM
TBIfly's Avatar
Ridding squeek options:
1. Subframe Connectors (weld in style)
2. New stripping, which may or may not eliminate it
3. rub it down with oil based lube/grease, not KY or anything
4. Cheapest way and usually effective..............................read on
Definitely on 91 birds/camaros there are adjusting plates that allow you to fine tune how tight your tops fit to the body.
These plates are found behind the A-pillar covers and the Sail panel covers where the Tops secure to the body.
(1) Remove the 1 screw on each cover and shift it aside to reveal the adjustment plate.
(2) There are 2 bolts that secure this plate to the brackets, these are 7mm, you loosen these and you can adjust the location of the hole that the pins from the tops secure into...lower for a more secure fit, but may require a bit more strength to secure the latch.
--Always tighten the bolts back down after each adjustment, failure to do so will result in frustration..........the force of those pins may move the adjustment plate when you didnt want it to--
(3) If the panels secure too easily, lower the plates even further, if the panels shift left or right when latched down, adjust the plates left or right also. You can align the tops based on how well they seat against the window when it is all the way up.
--------I replaced my acrylic 91 RS tops with a pair of 86 glass tops, for the weight and attractiveness....much less scratches and you get to do away with that gnarly plastic frame on the acrylic panels--------
My choice:
1. adjust first
2. SC's
3. weatherstripping
4. save the lube for something more entertaining
blain
Old Mar 15, 2003 | 10:09 PM
@ZZKKER's Avatar
blain
i wonder what could be more entertaining than rubbing down your f-body? but really, use the "lube" as a last resort or it will get all over your windows and the paint as well. and you dont want to put the t-tops back into the back with them greasy or they will have smears on them after every time of being in the bag, trust be i know .
thanks
anthony
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
91 SrS
Oct 7, 2015 04:32 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
