1982 firebird s/e weird vin # prototype?
Old Jun 3, 2003 | 06:38 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Hi i have a 1982 firebird s/e and I need the rpo codes can anyone help called 2 pontiac dealers to try and decode vin no help from them.Checked the rear cargo compartment and no rpo sticker please help
heres the vin# 1g2ax87h3cl5xxxxx any help on options and stuff would be great.Last 3 digits are sequential wonder if it means anything?
Old Jun 3, 2003 | 10:07 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Look for your build sheet. It is the only thing that will tell you RPO's. The SPID (RPO) sticker did not start until 1984.
Old Jun 4, 2003 | 04:06 AM
90TA's Avatar
Nothing weird about the VIN#.
It is not a prototype.
1G2AS87 = Firebird
1G2AX87 = S/E
1G2AW87 = Trans Am
H = LG4 305 V8
The 56xxx6 is nothing more than what it is. I would say offhand it was built mid July '82. Look at the cowl plate on the radiator support. It would read:
C 07(?) 2FS87 L 56xxx6
List the rest that is below the above.
It will have a few codes for you.
Like 83firebirdS/E said no SPID until '84 and look for the build sheet under the seat. If not there, it could be at a dozen other places or not in the car at all. You could probably make a list of visible options, and someone will match them up for you.
Old Jun 5, 2003 | 12:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok now that we know on 82's what digit is the package/model digit, how can we find the first part of the code on the car if the plate on the cowl under windshield is unreadable and if the door sticker has been gone for years ??
Old Jun 5, 2003 | 12:48 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
I've found build sheets on 82-84 cars under front seats and under the trunk carpet. Just some different spots to look.
Old Jun 5, 2003 | 01:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no dice there, have had rear apart and odds of it still being up front somewhere are pretty slim, car has been apart in the past, totally repainted, molested car, body has already begain rustintg out again in the rear half, through in a couple places around tubs and large area in spare tire compartment, can see ground easy as cake from inside, i dont think any surviving paper is gonna be found in this car
thanks
90TA's Avatar
Look on the title or registration (if you have it), last 6 digits will match last 6 digits on cowl tag on radiator support.
If you don't have a title, post all of the info on the cowl tag and I'll give you the VIN.
Old Jun 5, 2003 | 03:43 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
dont have title yet or any registration papers, i just got done removing all of interior except for actual dash and came up with no sheet, so.....
C 08E LFS87L 56xxxx
26D 21L 21U W
AR9
D S 276442
all i can get from this is that its number xxxxxxcar built at the plant it was built at, and that its originally light blue painted, and that its reclining european style bucket seats, 26D is interior i think but is unlisted, hmm.. and 08E is unlisted too, W is water base paint
thanks for anything
i just want to at least make sure its a normal 82 trans am
Old Jun 5, 2003 | 04:00 PM
90TA's Avatar
Records show the VIN# for sequence number 56xxxx:
1G2AW87H1CL5xxxxx
26D = Dark Blue
08E = Built 5th week of August
Old Jun 5, 2003 | 04:08 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thank you
Old Jun 6, 2003 | 01:01 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Correction: The VIN should be
1G2AX87H1CL5xxxxx
Old Jun 6, 2003 | 11:33 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok so now its not just a trans am im messing with, but is actually a trans am special edition
what is the car exactly ?
thanks
Old Jun 6, 2003 | 01:32 PM
90TA's Avatar
Fast68
The 1G2AW87H1CL5xxxxx I posted for your car IS correct.
1G2AX87H1CL5xxxxx IS incorrect.
Your car is a Trans Am, Not a Special Edition.
Old Jun 6, 2003 | 01:34 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
good deal, thanks
Old Jun 6, 2003 | 03:43 PM
90TA's Avatar
Re: 1982 firebird s/e weird vin # prototype?
The VIN # you listed should read:
1G2AX87H2CL5xxxxx instead of
1G2AX87H3CL5xxxxx
Old Jun 9, 2003 | 08:33 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
A simple carfax request shows that 5xxxxx is a Trans Am.. 1G2AW87H1CL5xxxxx
http://www.carfax.com/cfm/check_orde...2AW87H1CLxxxxx
jeez, guys, no need to go the long way around next time
gt
Old Jun 9, 2003 | 10:33 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
http://www.carfax.com/cfm/check_orde...AW87H1CL5xxxxx
gt
interesting,
so if carfax uses the sequential unit portion of the
VIN code to determine first half of VIN code then that must mean that there is no other 5xxxxx sequentially built car of any kind ?
im not sure how they could figure up the first half with just a sequential unit number of a random car in existence,
thanks
Old Jun 10, 2003 | 12:20 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
VIN:1G2AX87H3CL5xxxxx
Made in: United States
Manufacturer: General Motors
Model Year: 1982
Make: Pontiac
Carline Series: Trans Am Special Edition
Engine Code: 305 CI V8 LG4
Restraint System: Manual Belts
Assembly Plant: Van Nuys
Production Sequence: 5xxxxx
Carline Code: 82-84 does not have a Carline Code.
Body Type: 2 Door Coupe
Check Digit is Invalid
I agree with 90TA the vin sould have a 2 instead of a 3
VIN:1G2AX87H2CL5xxxxx
Model Year: 1982
Make: Pontiac
Check Digit is Valid
But actually that is a Trans Am Special Edition, this is from a program that I wrote, see sig to get it. Unfortantly without a RPO code sheet that is all I can tell you.
Old Jun 11, 2003 | 03:38 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
interesting,
thanks
With our GM cataloging system at work here you only need the last 8 characters of the VIN. Once in a while you may get a couple of choices, but they are always different carlines (buick, pontiac, etc) I deal with Ford & Chrysler & they work the same way.
Old Jun 11, 2003 | 04:10 PM
On Probation
Re: Re: 1982 firebird s/e weird vin # prototype?
1G2AX87H3CL5xxxxx
Ok thanks everyone.I'll check my car and find out if it's a 2 or 3 in the vin 3.But just incase if any of you guys are able to get me some rpo codes from the vin # ill pay some cash $$ thanks
Old Jun 11, 2003 | 08:08 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: Re: Re: 1982 firebird s/e weird vin # prototype?
wont be able to get any original RPO info like that on the car if it was sold in the US... GM did not do us the favor of keeping any records like that
good luck
Old Jun 12, 2003 | 04:23 PM
On Probation
1G2AX87H3CL5xxxxx
your right i made a typo.thanks
Old Jun 12, 2003 | 04:30 PM
On Probation
1G2AX87H3CL5xxxxx
Old Jun 27, 2005 | 11:52 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oops
delete this reply thanks
Cleotiz
Jan 6, 2018 08:56 PM
tom1985
Apr 19, 2016 07:55 AM
CORV3TT3
DIY PROM
Aug 23, 2015 11:26 AM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
