Are the 3.4L heads the same as the 2.8's?
I'm almost positive the 3.4's got better heads.
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
at advance auto parts, its 300$ for both heads. Heads + Better cam and 1.6 roller rockers should give a pretty noticable performance increase.
Car: 91 Camaro
you're not talking about the aluminum ones are you? i might be thinking of something totally different but the ones i'm thinkin of use a different intake.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you must be thinking of the fwd 3.4 w/the bbc style splayed valves. if you go this route, heads up must be from fwd. this setup has been done on a 4th gen 3.4 motor.
Car: 91 Camaro
ok....yea, that's what i was thinking about. it would be nice to be able to run those easily though!
Engine: 5.7 / 7.4
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
