Are the 3.4L heads the same as the 2.8's?
Old Jun 9, 2003 | 01:18 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
are they the same? or do the 3.4 heads have bigger ports?
Old Jun 9, 2003 | 01:25 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'm almost positive the 3.4's got better heads.
Old Jun 9, 2003 | 01:30 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
will they fit the 2.8L's?
at advance auto parts, its 300$ for both heads. Heads + Better cam and 1.6 roller rockers should give a pretty noticable performance increase.
Old Jun 9, 2003 | 02:12 PM
Xceleratemaro's Avatar
there the same size and they will work on either...the 3.4 head has thicker valve seats for a bigger cam so you can run higher spring rate
Old Jun 9, 2003 | 02:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They will bolt up, and have larger spring seats.
Old Jun 9, 2003 | 04:06 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you're not talking about the aluminum ones are you? i might be thinking of something totally different but the ones i'm thinkin of use a different intake.
Old Jun 9, 2003 | 08:35 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you must be thinking of the fwd 3.4 w/the bbc style splayed valves. if you go this route, heads up must be from fwd. this setup has been done on a 4th gen 3.4 motor.
Old Jun 9, 2003 | 10:00 PM
Car: 91 Camaro
ok....yea, that's what i was thinking about. it would be nice to be able to run those easily though!
Old Jun 9, 2003 | 10:26 PM
KED85's Avatar
Got a pic of that?
MUST LOOK BITCHIN!
It is a great idea, but for under the hood of these F bodies, FER GET ABOUT IT!
Not worth the aggrivation
Old Jun 9, 2003 | 11:02 PM
Engine: 5.7 / 7.4
Link to that project, very interesting
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
