Gas Tanks
Old Aug 29, 2003 | 08:56 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Transmission: 700 R4
Gas Tanks
I took the gas tank out of my car to replace the fuel pump (i thought) and found that the sending unit was actually the problem. It had rusted into about 5 pieces and I had to get a new one. The fuel pump will also be replaced, but the problem I have is the inside of the tank is rusted too, the neck seems to have a bend in it from when we took the tank out of the car, and I'm not altogether sure that sealers can be trusted in a fuel tank. So what I want to do, even though it's costly, is get a new tank. Does anyone know where I can find a tank for less than $200? I would even take a used one if it's VERY clean.
Old Aug 29, 2003 | 10:21 AM
demonchild's Avatar
ive heard that the 4th gen tanks fit into our car and since they are plastic, they don't rust. i would look into that so you can find a good one at a junk yard for cheap.
Old Sep 5, 2003 | 12:03 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
they are metal. This fuel tank is out of 94 TA
Old Sep 5, 2003 | 12:14 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Actually, I'm pretty sure that the LS-1 F-body gas tanks are plastic and they hold 1.5 more gallons. I will be doing this conversion soon myself. Plastic f-body tanks can be had for under $200 at local junkyards.
Old Sep 5, 2003 | 01:26 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
99+ F-Bodys got plastic tanks.
Old Sep 5, 2003 | 01:47 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
does anyone know the weight differance between the plastic and the sotck metal one?? i might consider doing the swap when i replace my crappy fuel pump.
Old Sep 5, 2003 | 01:55 PM
Scott_92RS's Avatar
Car: 1992 RS
I've heard, but have not confirmed, that the plastic tank only weighs 10 lbs less than the 3rd gen tank. The stock tank is fairly light from what I remember.
Scott
Old Sep 5, 2003 | 04:34 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Oops
I'll weigh mine(metal) this weekend and I'll let you know.
Old Sep 5, 2003 | 07:21 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
I'll should be buying my new tank tomorrow...I'll ask em' what the weight difference is.
Old Sep 7, 2003 | 01:15 AM
demonchild's Avatar
good to know that there is a plastic 4th gen tank, but will it fit into our cars as a bolt on.
Old Sep 10, 2003 | 11:14 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
OK, so they don't have my exact tank...I'll be ordering it instead (looks like) so I didn't get to ask anything about weight difference or even if the plastic fits the third gen.....oh well.
Old Sep 26, 2003 | 10:31 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
The 4th gen plastic tanks will work in a 4th gen but the filler necks
are different lengths. I was considering one insted of a fuel cell in my Iroc.
Old Sep 26, 2003 | 10:46 PM
demonchild's Avatar
Old Sep 27, 2003 | 12:15 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
are they baffled? is there anythere i can get a friggin baffled tank for our cars? also, on the plastic tanks, is there any way to sump it?
Old Sep 27, 2003 | 02:15 AM
I'm sorry (brain fart). The 4th gen tanks will go rite in a 3rd gen car but I think the 4th gen tanks have a shorter filler neck.Which can be lengthend by cutting and adding hose.
Old Sep 28, 2003 | 06:04 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Dont forget that the 99 and up LS1's use a returnless system, so I think they only have one fuel line from the tank. 98 has a return line if Im not mistaken.
The 99 and up LS1's also have there fuel pressure regulators in the tank too.
Old Sep 28, 2003 | 08:50 PM
_max_'s Avatar
the 1998 on up tanks are plastic but they are also fuel on demand and wont work you will have to use a 93 to 97 tank and get a good fuel pressure regulator they run higher fuel pressure then you will need
Old Sep 28, 2003 | 11:29 PM
demonchild's Avatar
well isnt it possible to just use the fuel system from a thirdgen in the 4th gen plastic tanks?
Old Sep 29, 2003 | 07:35 PM
Randy92Z's Avatar
Engine: Miniram 383
You mean use the third gen sender assembly in the 4th gen plastic tank? Dont know, as long as the o-ring and lock ring assembly are the same on the 4th gen tank.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
