Installing ProBuilt tranny and ACT torque converter, question
Old Oct 20, 2003 | 04:53 PM
vjo90RS8's Avatar
Car: 2002 Z28
I have decided to install my ProBuilt Street/Strip tranny and ACT 9.5" 2400 stall torque converter during thanksgiving break. I have recently done alot of reading on tranny swaps on the boards and have a pretty good idea of how to do everything but i have one question. With the ACT torque converter i was told that i need to use shims between the flexplate and the torque converter so that the converter doesnt sit to far up on the input shaft because it could damage the front pump. The clearance needs to be between .090" and .125" but im not sure exactly what i am measure....the clearance between what???. Im sure once i get under the car i would be able to figure it out but i might as well ask now so that i am ready for everything once the swap starts.
THANKS, i cant wait to get this stuff in!!!!!
Old Oct 20, 2003 | 05:02 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Maybe the clearance between the flexplate and the little blocks on the TC where the bolts go in. The place where they mean to shim it.
Old Oct 20, 2003 | 05:34 PM
vjo90RS8's Avatar
Car: 2002 Z28
well, that is where you are suppose to add shims, but i know the measurement is taken somewhere else.
Old Oct 20, 2003 | 06:39 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I think that you need to install the converter in as far as it will go and then measure the clearance between the converter pads and the flexplate. If the clearance is greater than .125", calculate how much you need for a shim to get clearance of .125" from the shim to the converter.
Say for example you have .200" clearance between the flexplate and converter pads with the converter all the way in. You would need .075" of something between the flexplate and the converter to make sure that the converter is no more than .125" up on the input shaft.
Old Oct 20, 2003 | 06:40 PM
Pro Built Automatics's Avatar
You take this measurement between the flexplate and the torque converter at the bolt pad. It should measure .090 - .125". If it more you need to reduce this clearance by adding a washer at the three corners. All three washers (if needed) must be "exact" same in thickness (+ or - .001"), to get this clearance within spec. If you make this too tight it will destroy the unit, too loose and you can break the rotor assembly in the front pump. If you need help call me at 800 7763288.
Old Oct 20, 2003 | 10:02 PM
vjo90RS8's Avatar
Car: 2002 Z28
ok, i got it, THANKS.
one more question, you do this after the bellhousing bolts are tightened and crossmember is on right?
Old Oct 20, 2003 | 11:06 PM
Yes!
Old Oct 21, 2003 | 12:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
cool, i cant wait, 5 more weeks.
Old May 24, 2005 | 02:04 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I lucked out. I just checked mine and I have exactly 1/8'' of clearance. I placed the bolt in the hole and counted the threads. Looks like its going to work.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
