Cheap TIG Welder
Old Oct 31, 2003 | 08:50 PM
johnsjj2's Avatar
Car: 1991 Z-28
Cheap TIG Welder
Easy TIG welder idea. Anyone see potential problems with this.
http://www.turbomustangs.com/forums/...&threadid=8872
I thought of using this to weld up my tubing for the turbo going on the Maro.
Old Oct 31, 2003 | 09:12 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Holy Crap, Junkyard wars eat your heart out. I may have to try that tomorrow.
Old Oct 31, 2003 | 09:21 PM
johnsjj2's Avatar
Car: 1991 Z-28
Well, I've got 2 old furnaces in the garage, so the blower motor out of one should power it. I just need the rest.
Old Oct 31, 2003 | 10:17 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i would not trust that for anything in the world, i would feel more scared to use it. id dump the money into buying a real tig welder and do it the right way, thats just asking for trouble.
Old Oct 31, 2003 | 11:05 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
wuss
i would use it as long as it works.
Old Nov 1, 2003 | 08:34 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
sorry i just like using the correct tools to get the job done right, instead of jerry-rigging something up to do the job. if that makes me a wuss go ahead i dont care.
Old Nov 1, 2003 | 09:08 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
TimZ2882, I agree, but if I was a skilled tig welder I would put one together just to see how it would weld for fun. I might anyways, do I really need to buy a big expensive tig to find out I suck? if I learn how maybe I will be more interested in the tig investment. its like tig training wheels lol
The other thing is I really want to know if it could be applied in a practical way with an air compressor and proper gun to make a plasma cutter?
A plasma cutter has such a limited use and such a high cost, if this setup could be used to build a decent plasma cutter then I am sold already.
since I know about as much about plasma cutting as I do about tig welding just jump in anytime here, anyone???
Old Nov 1, 2003 | 04:39 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Heh. Nice idea! The welds look pretty nice. A modern welder will have a high freq start, so you don't need to scratch start the arc, but you save $1k with this
Old Nov 2, 2003 | 12:20 AM
demonchild's Avatar
holy crap that is freaking awesome. im going to make one just to see if i can blow myself up.
Old Nov 2, 2003 | 06:30 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
holy shzzznit thats awesome.... I think I have a spare alternator and a old lawnmower laying around my garage
Old Nov 2, 2003 | 11:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good idea but I have similar thought but use a $100 arch welder.
Matt
Old Nov 3, 2003 | 01:27 PM
johnsjj2's Avatar
Car: 1991 Z-28
I know nothing about how a plasma cutter works, so someone else can figure out a way to make that on the cheap. This TIG idea seems pretty good. I still need to find all the parts though. The TIG gun this guy is using are going on eBay for about $50. For a savings of $1200, I will build one.
Old Nov 3, 2003 | 01:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im amazed.... i cant believe that even works... lmao..
cool.
im still spending my next paycheck on a real welder though...
Old Nov 3, 2003 | 01:43 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im taking a stock option to buy a hood and a cheap gas wirefeed from ebay
Old Nov 3, 2003 | 05:11 PM
johnsjj2's Avatar
Car: 1991 Z-28
Tom, I'm in the same boat. I'm pulling out a loan on my 401K to finance the turbo setup, as well as a bunch of woodworking tools.
Old Nov 3, 2003 | 07:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
We had a talk about this over here & $30 tig torch.
https://www.thirdgen.org/techbb2/sho...hreadid=203110
I found the tig torch for $30 and it got me started thinking.
I think the arch welder into a tig would be, safer, cheaper and the parts are made more for what you will be doing.
Just gotta add a pedal and get a bottle.
Id love to be able to turn my mig iinto a tig that wag.
Matt
Old Nov 3, 2003 | 07:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It hard to beat the one at CC. I searche the web forever and for the options it has, its the best one for the money. Being gas ready, it can take the big 11lb spool and the 4 power setting are to die for.
[url]http://www.columbiacoatings.com/toolsandequipment.htm[url]
For mild steel, stainless steel, and aluminum.
Weld with gas or perform flux cored gasless operations.
Features 4 heat settings, variable speed wire-feed regulation and
automatic thermal protector with warning light.
Optional 7-1/2'' reel adapter lets you use 11 lb. wire reels.
Welding current range: 25 to 85 amps
Input: single phase 115 volts, 60 Hz
Open voltage: 19 to 30
Duty cycle: 16% @ 75 amps
Draws 15 amps @ 115 volts
Weldable wires:
.023'' to .035'' steel and stainless steel
.030'' to .035'' aluminum
.030'' flux-cored
I have welded everything under the sun with it and it has done nothing less but perform like a champ.
I got the 110 but the 220 is nice also once you check the details. I can not find a "cheap" welder even close to mine in options for the money.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
