how to put a BBC in a gen 3 F-body
Old Nov 23, 2003 | 05:23 PM
IROC-Z2814's Avatar
well I found a website that has an article from an older HotRod magazine. its www.9bolt.com I also am posting the info on here because I plan on dropping a 454 high performance in my 1988 Camaro.
Transplanting a Big-Block Chevy into your 3rd Gen F-Body
This article is taken from HOT ROD magazine. May 1988 issue:
This article is taken from Stephen Cranford http://cranford.home.texas.net 6/99
Dropping a big-block Chevy V8 into a late-model GM F-Body can be a
rewarding but frustrating experience. There's no question that big-block
power breathes new life into any swap, but F-Body transplants present a
variety of problems that can be difficult to overcome. Technically
speaking, it is an easy swap, since factory frame mounts and engine
brackets can be used and all the accessory hardware is readily available
through local GM dealers and specialty equipment manufacturers. Most swaps
are mechanically easy to complete, but almost all of them suffer from
overheating and fuel delivery problems. These cars are essentially bottom
breathers with little or no front grille to admit cooling air. The engine
fits rather snugly and even the heavy-duty factory radiator is hard-pressed
to keep its cool under normal driving conditions. Increased cooling
capacity via the use of special aftermarket radiators (available from
Modine or custom built by local sources) is essential not only to maintain
proper engine operating temperatures, but also to help prevent high
underhood temperatures that cause fuel percolation, vapor lock, and rapid
deterioration of underhood components such as belts and hoses.
As shown in the accompying charts, the engine is a bolt-in using stock
brackets and frame mounts. A low profile intake manifold and air cleaner
are neccessary to maintain adequate hood clearance. Spark plug access and
steering gear clearance is tight, and the distributer requires a slight
clearance dimple on the firewall to facilitate easy installation and
removal. Late-model HEI distributors won't fit without making significant
alterations to the firewall. The stock throttle cable is long enough, but
you may need longer radiator hoses depending on your selection of
radiators. A factory 5-quart Chevelle oil pan (PN 14091488) clears the
crossmember nicely, and Hooker Industries makes the appropriate chrome
header set. If you plan on keeping the air conditioning intact, the late
model shorty compressor will require mount alterations to keep it properly
positioned, and you'll need either a two-groove or three-groove big-block
pulley to drive the accessories. The serpentine belt system on very
late-model F-Bodies won't fit in this application.
Automatic transmission make the easiest swaps, but you can still use a
manual trans if you wish. The stock bellhousing isn't compatible with large
diameter flywheels so you'll need to use a scattershield from McLeod or
Lakewood. They now have mounting provisions for the late-model hydraulic
clutch slaves that will ease the pain of fabricating clutch linkage. We
can't imagine running a T-5 transmission behind a big-block, but Super
T-10's and Doug Nash 5-speeds offer plenty of strength. Manual
transmissions will require an '82-'84 Z/28 4-speed rear crossmember and
mount with the appropriate torque arm mount for the transmission you are
using, but automatics can utilize rear crossmember kits from B&M. Serious
big-block power could also wreak havoc with the rearend. An automatic will
cushion the rearend somewhat, but you may have to consider installing a
Dana 44 or a 12-bolt with an aftermarket mount kit such as those available
from Summers Brothers. The added weight of a big-block is just about
perfect for lowering the front of your F-Body, but you should have the
front end re-aligned once the swap is completed. Hooker makes headers for
the swap, but the rest of the exhaust system will have to be fabricated.
The swap is essentially a bolt-in, but you'll need to address the cooling
and fuel delivery problems to derive maximum enjoyment from it. A larger
capacity radiator, accessory electric fans, and some means of evacuating
hot underhood air are all critical elements. Ram air cooling ducts directed
into the engine compartment may be of some help in keeping temperatures
under control, and if you're into hoodscoops or ducts, you can use them to
bring in more cool air. The stock fuel system will probably work well if
you keep the lines insulated and prevent localized hot spots in the engine
compartment, but a powerful engine running at high speed will require more
fuel capacity. An auxillary rear-mounted electric booster pump near the
fuel tank will help, but some applications might also requires an increase
in fuel line size.
As with any engine swap, there are plenty of details that require special
attention, but the smooth torque of the big-block really makes the effort
worthwhile. Big-block Camaros forever, right?
BIG-BLOCK F-BODY PARTS LIST
PART
PN SOURCE
Mount, frame, two required
14039437 Bracket, engine mount, left hand GM
334970 Bracket, engine mount, right hand GM
14039436 Spacer Plate, left hand (to raise engine for GM
14089455 clearance) GM
14089456 Spacer Plate, right hand (to raise engine for GM
14023147 clearance) GM
14023148 Two-groove big-block front pulley GM
3985999 Three-groove big-block front pulley GM
3930827 Big-block Chevelle oil pan GM
2226 Turbo 400 front-drive yoke Hooker Industries
20295 Chrome header set B&M
30299 TH200/TH700 to TH400 changeover kit B&M
20296 TH200/TH700 to TH350 changeover kit* B&M
20297 Special HD Driveshaft for TH400 kit B&M
----- TH400 kickdown switch Banks
TH350 F-Body torque arm mounting bracket kit
*TH200 uses a stock driveshaft, TH700 uses a stock '82 TH200 driveshaft
F-BODY BIG-BLOCK FLYWHEEL/STARTER COMPATIBILITY
396/427 Engine
FLYWHEEL STARTER
Stock HD Stock HD
Manual Trans.---366860 14085720 1109534 1108789
Auto. Trans.----471591 361950 1109534 1108400
454 ENGINE
FLYWHEEL STARTER
Stock HD Stock HD
Manual Trans.---NA 3963537** 1109534 1108789
Auto. Trans.----NA 336717 NA 1108400
*also compatible with stock starter 1109534
Sources:
Gale Banks Engineering McLeod Industries, Inc.
546 Duggan Ave. 1125 N. Armando St.
Azusa, CA 91702 Anaheim, CA 92806
(818) 969-9605 (714) 630-2764
B&M Automotive Products Lakewood Industries
9152 Independence Ave. 8700 Brookpark Rd.
Chatsworth, CA 91311 Cleveland, OH 44129
(818) 882-6422 (216) 398-8300
Hooker Industries, Inc. Summers Brothers, Inc.
1024 W. Brooks St. 530 S. Mountain Ave.
Ontario, CA 91762 Ontario, CA 91762
(714) 983-5871 (714) 986-2041
Old Nov 23, 2003 | 06:09 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
yup
we know
this is covered atleast once a week
Old Nov 23, 2003 | 10:59 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Originally posted by 1991tealRSt-topGuy
yup
we know
thats about seven different kinds of rude.
and considering we go over it about once a week, and condsidering he went to all the trouble to post this article, this thread maybe should get a sticky?
Old Nov 24, 2003 | 06:13 AM
better yet, how about the FAQ board?
Old Nov 25, 2003 | 04:48 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
You dont need alterations to the firewall for the HEI.It fits just fine
Daz
Old Nov 25, 2003 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ageed. It belongs on the FAQ. Along with V6 to V8 swaps.
But, I personally lack the power...
Old Nov 26, 2003 | 10:20 AM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I def. think this should be a sticky. It falls under V-8's. I am doing a swap right now as we speak, hope i can get it done in a week.
Old Nov 26, 2003 | 11:11 AM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
Cripley
Aug 17, 2015 03:35 PM
sreZ28
Aug 14, 2015 07:48 PM
89lsc
Aug 14, 2015 04:58 PM
Street Lethal
Aug 13, 2015 08:28 PM
