406" setup comments?
Old Jan 7, 2004 | 04:59 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Will order stuff next week.
Motown block 4-bolt
4340 crank
4340 H-beam rods
Forged pistons JE/SRP
9.0-9.3 comp
Jegs 197 cc heads 2.05/1.6
Complete ported superram
ZZ9 cam with 1.6 RR
52 mm TB
ACT 9.5" 2500rpm convertor
Pro-build Limited street TH700
SVO #30 injectors
730 ECM (upgrade to $58 code later this year with bigger injectors)
9 psi Procharger 600B and 6.1 FMU
Any comments on the setup?
The car will be a nice daily driven...........
Old Jan 7, 2004 | 07:57 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: 406" setup comments?
Motown block 4-bolt
4340 crank
4340 H-beam rods
9.0-9.3 comp
ZZ9 cam with 1.6 RR
52 mm TB
SVO #30 injectors
All looks nice.. The Only 2 things I would do Diff. is
The JEGS 197 cc heads
id look into AFR 210's or Brodix Track 1's
and why not just swap to a 7749 sy/ty ecm. of is the $58 code the 7730 conversion for that. I forget Its been awhile since Ive read up on it.
Im doing a symiler setup.
418cid
Eage Fordged crank
Eagle H beams
JE pistons. stayin around 9:1
Either AFR,Brodex or canfiled heads.
and twin Turbos.
Just gota get off my A$$ and start the turbo headers and coat everything now.
Old Jan 7, 2004 | 07:59 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're running $58 or a 749 ECM, why would you need a FMU??
Old Jan 7, 2004 | 08:03 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I will use the FMU until I run the $58 code in my 730ECM.
I dont want to change everything at the same time. Will drive with 730 $8D code first and then upgrade injectors and to $58 code...
I was thinking of 220cc heads and maybe a larger cam but I must pass emission and its a daily driven car so I want it to be nice to drive.........
Old Jan 7, 2004 | 11:47 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The smaller heads will really choke that engine. I'd go with the AFRs. It shouldn't be a problem with emissions. Keep the cam within reason and make more power with the blower. I'd probably use a 58mm TB too instead of the 52. The blower will want all the intake airflow it can get.
Old Jan 8, 2004 | 04:50 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I wont rev past 5800 rpm so I dont know if my heads will be much of a restriction.......
cam spec 212/224 @0.050 ,515/,555 1.6
I probably need to upgrade to 12 psi pullies to get 9 psi with 406 cui..........
/N.
Old Jan 12, 2004 | 12:41 AM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
sorry to butt in, but can anyone refer me to what you guys mean when saying $8 this and $58 that.........?
Old Jan 12, 2004 | 12:44 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Its diffrent codes in the PROM or chip.
example.
$6E is for -89 MAF
$8D is for 90-92 MAP
$58 is from GMC typhoon allows to program with boost.....
more info is at the DIY PROM board.......
/N.
Old Jan 12, 2004 | 10:26 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
TB too small,
and the 30 lb injectors are too small.
Old Jan 12, 2004 | 11:03 PM
87350IROC's Avatar
Car: 87' IROC
Why the Motown block?
Old Jan 12, 2004 | 11:41 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
TB too small- yes maybe, if I find a used 58mm I'll probably buy it but it have to wait dont have the $$ for it now..
#30 too small- dont think so, some people have#24 on their 406 and they are in the low 11's........when I go $58 code I'll probably getting $50's....but not yet....
Motown block- the only one I find..........
/N.
Old Jan 13, 2004 | 01:06 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Since you said emissions I can't say much against it.
If I was buying, and keeping your exact setup heads, cam, blower... I wouldn't waste my money on a aftermarket block. I'd get a 2-bolt 400 or either a 4-bolt 350 and stroke it. Lot of money for something you won't be putting out enough power to take advantage of.
If I was buying, and not using your exact setup, I'd setup that cam greatly, get a larger blower, larger injectors, larger heads and use the motown block as intended. Your talking close to the same costs, only difference will be the huge difference in horsepower. However, emissions kills that, so I can't say much. I have none here.
Old Jan 13, 2004 | 01:17 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Cam will probably be a NX276HR 276/288 224/236 @0.050 0.502/0.520 113 lobe.
Hopefully it will pass emission, I think it will be a fun streetcar
Old Jan 13, 2004 | 01:19 AM
30 lbs/hr injectors are fine. 450 horsepower is the limit for 24s, but 30s can go up to 550.
There are a lot of advantages to the Motown block, if you can afford it. It will offer better ring seal, better head seal, and less chance of cracking the deck. This won't add up to big power numbers, but it is good for piece of mind.
Old Jan 14, 2004 | 02:28 PM
87350IROC's Avatar
Car: 87' IROC
Yea, but who wants to pay that much for a block you are only putting 400-500 hp too. I see your point, but a good used 400 core would be fine.
Old Jan 14, 2004 | 11:55 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
450-500 N/A I have a procharger too.............
Want it to be bulletproof...
Much money, yes I know... but its cheap for me to buy US parts now, 1 USD =7 sek, used to be 1 USD = 10 SEK so the price has reduced 30% last year......
/N.
Old Jan 15, 2004 | 12:30 AM
stevedave454's Avatar
Car: 91 S10
correct me if im wrong, but on a boosted motor you can get away with smaller heads and cam, of course higher flowing heads/cam help with HP, but isnt not as big of a deal as an N/A motor
also i would go with a factory 2-bolt 400 block, have it converted to 4-bolt, and get a bigger blower (D-1)... always go big on the blower, i think its better to run a big blower at low boost than it is to run a small blower at higher boost levels as the air doesn't get heated up as much, and so theres less of a chance of detonation... and of course if you ever want a little more power swap the pullies for more boost
Old Jan 15, 2004 | 12:38 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The Jegs 197cc matches the powerband of the superram.....No need to get bigger heads wont rev that much...
Do you know if there is a way to urgrade a blower at ATI?
Old Jan 17, 2004 | 08:11 AM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
Regarding the heads,, make sure your low lift flow .400 and below is as good as possible.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
tmellott89
DIY PROM
Oct 14, 2015 02:06 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
