H.O. Alternators
Old Jan 13, 2004 | 01:27 AM
87t-5.0transam's Avatar
H.O. Alternators
Does anyone know where to get H.O. Alternators for our cars my alternator is getting pushed just a little to hard and i wanted to find something that pushes 140+ amps. Preferably wholesale or online. Thanks
Old Jan 13, 2004 | 02:32 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
dominick@tds.net
email dominick iraggi...he makes custom alts that put out huge numbers at idle for a good price. Come with 1 year warranty or for an extra $100 they have a lifetime warranty. Mine's a 280 amp that is supposed to put out something like 40% of that at idle.
but im not sure if you should need a HO alt for your setup...have you tried upgrading your magic three wires yet?
Old Jan 13, 2004 | 11:36 AM
Polecat's Avatar
Re: H.O. Alternators
call Rick at H.O Alts...he is an awesome guy!
http://www.h-o-alternators.com/
Old Jan 13, 2004 | 12:46 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
www.4alterstart.com
alterstart@aol.com
just ordered mine yesterday.
200 amps for about 250 shipped w a 2 year warranty.
should be here friday.
i had to email them about the 200 amp one, they might have a 140 listed on the site though. also check ebay under the seller name "alterstart"
Old Jan 13, 2004 | 06:12 PM
umm not sure what the three magic wires are but the wiring that i have is some nice stinger wiring. I know that i want a alternator with more kick because of two things. The 105 amp thats in there overheats when i turn up the system and causes the system to shut off and when that doesnt happen, at night all of my lights dim badly. the alternator that's in there was put in about a year ago so i know that it isnt going bad from old age. I also know that im going to a custom box soon with 2 10w7's with 2 matching JL amps. When that happens i know that ill need a new alternator for sure. it would just be nice to sit at a light and not watch my battery meter pulse with the music. It has also created a drain on my battery and i've had to push start a couple of times until i got a new batt. but let me know what the magic three wires are and ill see what happens.
Old Jan 13, 2004 | 09:14 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
alt to batt
batt to ground
chassis to ground
Old Jan 14, 2004 | 03:08 AM
cool
i'll check those. but daaaammmmn that is a nice system you have there i take it you are for SPL considering your running 2 18's? And i thought my system was loud sh*t, well thanks again also say those need to be replaced what kind of wire should i use? New automotive wire or special 4 gauge like the stinger wiring? *** if only i had the money for that kind of system and i thought 1500 bucks was alot lol
Old Jan 14, 2004 | 03:14 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: cool
you dont need any sort of fancy car audio power wire for anything...basically wire is wire, car audio wire is just more bendable. I would say 2 gauge should be good enough. If you're hard up for money go to a local welding shop and buy some welding cable, it comes mainly in 1/0 gauge and only in black at most places. A little harder to bend but much cheaper.
My car isnt just an SPL car but I'm planning on hitting above 155 with it hopefully. Ive been upgrading and upgrading for the last 4 years and every once in a while i buy a quality product and it carries over for my next upgrade. So basically this time around all i had to buy was the sub amp, subs, and new battery. Car audio is a very addictive game, its easy to drop $10k on a system and have it sound like a$$ but trying spending $1k on it and make it sound the best it can, then work up from there. Its all about trial and error. My personal taste is to have a loud car (stereo wise) rather than a fast car, its much safer and its me in less trouble
Old Jan 14, 2004 | 12:55 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
4 gauge should even be sufficient for short runs such as the grounds since you arent runing too much power, and 4 gauge cable is alot easier to come by than 2 gauge. Check walmart for 4 gauge.
yeah i just dumped some money on 1/0 gauge wiring to redo my ground when the alternator comes in, its not the wire that gets you, its them damn lugs..theyre like a buck a piece.
But this cable should get me through any upgrades i plan on doing.
Replace the big three and tell us if that helps at all.
P.S. first time i saw the battery/ground wire i was in disbelief over how small it is
Old Jan 14, 2004 | 02:13 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I believe you are mistaken in where your problem lies.
Old Jan 14, 2004 | 10:17 PM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I bet a few good capacitors would help cure your problem. Your amps are probably shutting down b/c your over driving them, or the preamp is being overdriven in the amp, too much signal will make the preamp section of them amp overheat, and cause it to shutdown, or fail. You may also need power wire with a higher current carrying capacity. Caps would really make your alternator, run cooler, since the caps will store up most of the current that will get sucked to the amps.
Old Jan 14, 2004 | 10:58 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
OMG the misinformation is SO BAD!!!!!!!
Old Jan 14, 2004 | 11:18 PM
What misinformation?
Old Jan 14, 2004 | 11:27 PM
br()bert's Avatar
Car: 85 firebird
1, IF you have a drain on your alt now adding caps will cause more of a strain on your alt now because caps need to be charged,correct solution? upgrade your 3 wires like boomin said. THEN if problem still is their upgrade alt.
2,over driving the pre amp signal?
2Caps make your alt run cooler, see number one.
Thanks for playing
Old Jan 14, 2004 | 11:58 PM
Thanks for playing
caps will not cause a drain on your alternator. Caps store energy, so that when the bass hits, and the amps pull more current, almost all of the current will quickly discharge out of the caps and feed the amps. A cap can store way more energy than an alternator can put out. A cap needs a steady flow of voltage, current will be there when its needed, also the capacitor acts as a buffer for the power being used from the alternator, it smoothens out the sign wave, why do you think that capacitors are used in computers, and almost every electrical circuit used? Do your homework, or take some serious calc. based physics, and you'll see what I'm talking about.
2nd. If your sending too much signal to the preamp section of an amp, your overdriving it, this can make it run hotter, because its being forced to take more than it wants. With preamps out of aftermarket head units, running to the amps, they're usually fine. But if your signal is weak, and you overdrive the amp by having the level(gain) up to high, its going to make the amp run hotter. Remember that an amplifier is always putting out its rated rms wattage, the wattage the amp puts out is not varied, but the signal is, so having the gain up to high, is straining the amp, because it may have more than it needs.
3rd. Running better power wires is a good idea, and whats the three about? Theres two wires, +, - are you including the remote wire, because that can be a 22 gauge and not affect how the amp works, or how hot the alternator runs. The alternator will run hot if its being asked to put out close to 100% of its current all the time, which will also shorten its life. And I highly doubt he needs a higher amperage alternator, most car stereos on the high end, with mosfet power supplied amps, only pull between 30-50 amps, up to the thousand watts of continous rms power, more than that then the current used will go up.
In my cavalier with 560 watts rms, a 1.0 farad cap and a stock 65 amp alternator, with the system on full blast, the alternator gets hot, but doesn't over heat, and on my ammeter, the stereo pulled no more than 30 amps, while the computer and car pulled a consistant 25-30 amps, so the highest the gauge would ever read would be 65 amps, with 4 gauge wire, this was never a problem, a good rule of thumb is too feel your power wire before the amps, if its warm, you need larger gauge wire, if its cool, your probably fine.
Old Jan 15, 2004 | 12:15 AM
br()bert's Avatar
Car: 85 firebird
the fact that you dont even know what the three wires are proves my point, and the statement you made in the original post was referring to the signal put into the amp not "clipping" as you just posted now. Caps are junk plain and simple. They are an extra drian on a system that is already not up to par. Seems you need to learn more about car audio or go to a site with less informed people. Oh and by the way, just because your amp wire doesnt get hot or warm doesnt mean its "good enough" . This sounds just the like thread on how Legacy amps are better than orion, pioneer,rf,mtx. LMFAO I love newbies. So misinformed! I have no problem with you being misinformed, ignorance is bliss, isnt that what they say? The problem is your coming on here spreading information that is incorrect, and alot of people who dont know any better will asume its correct. Give it time, you'll see 99% of the people on here that have been on here for awhile will disagree with you. ps. Since your uncle is an "electrical engineer" you should know exactly what three wires i was talking about.
Old Jan 15, 2004 | 12:35 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
caps will not cause a drain on your alternator---wrong...when the cap discharges the alt has to re-charge it aswell as the primary battery in the system which will limit the life of your alt big time.
adding a cap to a weak electrical system is like putting a band-aid on a severed finger...it will help but it doesnt fix the problem.
if 87t-5.0transam wants to upgrade down the road to a system that draws more current. It wont cut it to add many many caps it will just draw the voltage down more and more. Some amps are capable of drawing over 800 amps of current, a cap is just like a small battery that recharges quickly. If your alt cant power your system, then it is draining your battery aswell and it is time to upgrade. If you have gone to extreme with your current requirements that your alternators cant provide enough juice, then add batteries if you must but caps are useless. theres a reason that you see 40 alternators in some competition vehicles and not 40 caps
as far as feeling your power wire to see if its warm...ive never heard of that being a rule of thumb. I consider that stupidity that you would design your whole system and plan it out that poorly that you have to guess weather or not your power wire is the right size.
Old Jan 15, 2004 | 01:24 AM
boomin boy you obviously don't understand how caps work, take some physics my friend. Saying that caps drain your battery is like saying that amps don't use power. Thats how dumb of a comment that is. Also if a capacitor doesn't hold current and energy, then why are they used on compressors, a/c air conditioners, and any heavy duty equipment that needs to start something and keep it going? They also recharge alot smoother and faster than one understands. You don't understand caps at all. They use a slight amount of power to use, but don't act as a bandaid, "your a funny guy, boomin boy."
Also, large caps, can build up and hold more current than most alternators can produce, making them even more advantageous.
Old Jan 15, 2004 | 03:31 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
im not saying that caps drain your battery, im saying caps put an added strain on your alt...when the discharge, what is going to charge them other than the alt?
i never said they didnt hold current and energy...im simply saying there is no need for them in a car audio setting unless you like to waste money.
Low loud bass notes.
Think.
How long do they last for?
1-2s each?
How long does 1F cap supply for?
10-20ms?
How does a cap keep up?
Hmmm...
What happens when it's discharged and the bass note is still
playing?
.....even more drain on alternator......
Old Jan 15, 2004 | 04:00 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
these are steps that the logical person would take to having a good electrical system:
1) upgrade magic three wires under hood...its cheap easy and affective
if you still have problems...
2) upgrade your vehicles main battery
problems still..
3) get your stock alt re-wound to higher output or buy a higher output alt
still not enough juice
4) add an auxillary battery and isolator to act as a reserve (rarely needed)
if this doesnt supply your amps with enough current..
5) keep adding more batteries (only needed in extreme cases)
if spending $200 on a stiffening cap will make you feel better about your system, its not a bad idea...its more of a placebo affect, like the people who buy the $100 rca cables:lala:
Old Jan 15, 2004 | 07:56 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Smiles are fun.
Now that “Rule of thumb” is just so wrong on so many levels. BTW, do you have any idea of how two small of a gage power wire will kill an amp? You can get a substantial voltage drop across a run of wire and it may not get hot, or warm.
Old Jan 15, 2004 | 09:00 AM
subzero's Avatar
cap not draining an alternator?...please do caps help in some circumstances? somewhat...are they usefull in most high applications where a BIGGER alt with alot more juice is needed?..not at all..Do they put a strain on the charging system..absolutely!..DO I have one in my ride?..no..Do i install many ?..no do I recommend many to customers I do installs for?..no...is there a pattern here?
Old Jan 15, 2004 | 01:20 PM
"if spending $200 on a stiffening cap will make you feel better about your system, its not a bad idea...its more of a placebo affect, like the people who buy "
I spent 85$ on my 1.0 farad with a digital display from partsexpress, and no its not a few ms. With the power disconnected from the cap, the cap will power the amps for about 5 seconds, then the power drops off.
U guys are still missing the concept, the drain used to re-energize the cap, is minimal in comparison to the drain of the amps taking current from the alternator, caps help save the alternators, because the time that the alternator has to recharge the battery, and put more current is increased, there by increasing the life of the alternator. Also when using the cap, the energy stored in the cap, is used for the amp, instead of more being taken from the battery, caps "buffer" the whole electrical system from the spikes of current from the amps, put a cap in a system boomin boy, and run an ammeter, and see how much smoother the current moves. What kills alternator diodes, rectifiers, bridges, and the regulator, is large constant spikes of current. Which is what systems without caps have, thats why I've been able to run this much power through a stock 65 amp alternator for over three years.
This is from parts express:
Experience Tighter, Quicker and More Defined Bass!
Most automotive alternator/battery systems simply lack the ability to produce the large amounts of instantaneous power your car audio amplifier craves! These computer grade power caps store energy and then very quickly release it, on demand, to your power amplifier(s). The result is a tremendous increase in bass punch and transient response. We recommend at least 1.0 Farad of capacitance per 1,000 watts of continuous amplifier output power. Stiffening capacitors can be wired in parallel to increase value. All models feature 24kt gold plated terminals and include two mounting brackets with hardware, hex wrench, charging resistor and owner's manual with installation instructions. 1 year mfr warranty. Specs: *20 VDC/24 VDC surge *ESR: Less than 1.5 milliohms *Tolerance: -10/+50% *Temp range: -40° C to +95° C. *Dims: 3" diameter x 8-5/8" length.
Get the power and performance you never dreamed possible from your amplifiers!
Stiffening capacitors can help your amplifiers deliver up to 50% more output on those demanding peak bass notes. Most automotive alternator/battery systems simply lack the ability to produce large amounts of instantaneous power. This is exactly the type of power that car audio amplifiers crave. Adding a stiffening capacitor to your system can add tremendous bass punch and improve transient response.
Stiffening capacitors FAQ's
What is a stiffening capacitor?
Computer grade power caps (also known as stiffening capacitors) store energy and then very quickly release it on demand to your power amplifier(s). The term stiffening capacitor as a generic term refers to any large capacitor (100,000 Microfarad and larger) placed in parallel with an amplifier and battery.
How does it work?
A stiffening capacitor charges like a battery. But unlike a battery the stiffening capacitor is designed to quickly release power on demand. This quick burst of power aids your amplifier in producing deep bass notes when it needs it. In between deep bass notes your battery and alternator re-charge the cap allowing it to be ready for the next deep bass note. This battery voltage assistance reduces voltage induced amplifier clipping, increases transient response, increases bass punch, and increases amplifier life.
One of the other benefits of stiffening capacitors is the ability to reduce line loss. Line loss is created by the power cable itself. Long runs of power cable associated with mounting amplifiers in automotive trunks creates line loss, especially during deep bass notes. Stiffening capacitors help maintain appropriate system voltages at the amplifier.
If you don't understand that your a fool, maybe this will help educate you guys.
Boomin boy, find a picture of a car with 40 alternators on the motor, I'd like to see that, the most I've seen was 10.
Old Jan 15, 2004 | 04:53 PM
br()bert's Avatar
Car: 85 firebird
I think your missing the point as i said in my other post, you'll notice that people on here will disagree with 90% of what "YOU" say because your information is incorrect. You post alot of crap that the cap man. put out themselves. The info is to sell caps plain and simple. Its not facts its a marketing line. The fact is cars are nothing more than a small battery.If you need more juice for your system and have already addressed the 3 wires issue than a bigger alt is the solution NOT a cap. I think your the fool .. I see your posts full of bull**** nonsence like leagacy being better than rf,mtx,orion,kenwood. Then i see the "material doesnt matter when doing an instal"then the "feel the wire and see if its hot if its not your fine" YOu are the fool and the one who needs to be educated. We've all seen the pics of your radio shack equipment Please educate yourself before you come back on this site and try to even reply.
Old Jan 15, 2004 | 07:33 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
this is 16 300 amp alts
Old Jan 15, 2004 | 07:46 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
cronsformula350 if you choose not to believe anything i say, thats fine...but atleast listen to subzero he's an installer. They're paid to know what they're doing
Old Jan 15, 2004 | 09:15 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
-the truth about caps-
"The only purpose for a cap is to prevent a change in voltage. Just like inductors oppose change in current. Caps are used to "stiffen" the power supply to an amp, but it is more like putting a bandaid on a broken leg. For extremely short bursts, caps can help with "light dimming" in your vehicle, but that is it. They don't do anything else. They don't "add" more power to your stereo or electrical system, they merely try to stabilize the voltage going to your amps, and since they are passive devices, they don't do that very well either. If you want voltage stabilization, there are only a couple products that do this. One of them is the Jacobs Electronics Accuvolt. It is an active voltave regulator that eliminates variations in voltage, and filters noise. But if your electrical system is not capable of supporting the demands of your system, the Accuvolt won't help either, in fact it will worsten the problem by drawing more current the lower your vehicle voltage goes. It still does more than a cap. The only real solution is a bigger alternator. Period. Power in=power out. Besides, with the cost of high-end caps, you won't spend much more money on a solid high-output alternator (about $210, give or take). "
"Capacitors oppose a change in voltage, just as inductors oppose a change in curent (ELI the ICE man from electronics 101). Caps do nothing for current. The only devices that do anything for current capabilities are batteries (passive) and alternators (active). Adding a bandaid (capacitor) can help for very brief bursts, but they are not effective storage devices at all. With a typical .003 ohm internal resistance for a 1 farad cap, it is only effective for .003 seconds (one time constant R*C= 1 time constant), where the cap has lost 62.3% of its initial charge. By .015 seconds (5 time constants), the cap has lost 99.99% of its initial charge, being rendered completely useless. As a "current stabilization" device, they aren't even useless. They store a fraction of an amp. Their engineering is based upon voltage stabilization. That's why they are used in power supplies, because they do a decent job at stabilizing output voltages, as long as the current is present (hence the jumbo inductors in power supplies). I have heard every urban legend imaginable about capacitors, but it boils down to one thing: caps don't do very much at all. Current draw is current draw. If you draw more current than your alternator produces (including vehicle demands), your battery tries to compensate. That is the first warning sign. When your battery starts losing energy, your electrical system starts wavering (lights dim). Adding a $100 bandaid (a passive bandaid at that) isn't going to fix the problem. If you aren't generating the current to begin with, nothing will permanently solve the problem except to generate more current, and that means upgrading your alternator"
"The properties of a capacitor determine how it will work. ELI the ICE man is what all 1st year electronics students learn to help them remember what caps and inductors do in an electronic circuit. The capacitor is used to oppose a change in voltage in AC circuits, because the current leads the voltage through a capacitor. The current goes through the power wire connected to the cap (and the battery and amplifier). If there is no drop in the vehicle's electrical system, then the cap just sits there without doing anything. When you tax the alternator past its cpabilities, the vehicle voltage drops, causing a shift on the plates of the capacitor. The plates on a 1 farad capacitor are HUGE, and store a significant amount of electrons at a potential determined by the electrical system of the car (the alternator- 14.4 volts). When this voltage dips, the cap discharges its stored energy to try to keep the voltage constant (at 14.4 volts). When it does so, it releases all of its energy quickly (.015 seconds to discharge 99.8% of its initial charge). This provides a simulated "voltage source" for the amplifier, thus stabilizing the input voltage, if only for a fraction of a second. The current never goes through the cap.
The current does suffer during this process, due to the fact that the alternator can not maintain the current production necessary for the stereo system. Once that happens, the battery tries to fill in, which is why the voltage drops (battery voltage starts at about 12.8 volts, and goes down as the stereo beats it up).
The only reason why the alternator and battery are at different voltages is because the charging source needs to be >5% higher than the battery, plus the voltage the connecting wires drop on the way to the battery). The amp will draw the current it needs, regardless of the voltage present, until the voltage drops below 10 volts or so, when the amp shuts off. Otherwise, you would not see as many symptoms when you push your alternator hard.
The capacitor's only job is to maintain voltage in the stereo system, nothing else. It's fundamentally flawed design prevent it from doing this very well at all, except for extremely short bass bursts. The alternator still gets pounded, and the electrical system as a whole still gets abused when excessive current is required for the stereo system. If the amp is designed to draw 150 amps, come hell or high water, it will draw 150 amps, even if it means driving the vehicle's electrical system down to 9.5 volts to do it.
As I have stated on many posts, capacitors are bandaids. The only purpose for them is to provide extremely short periods of stabilization for burps and other quick bass demands. They do not offer solutions for anything except peace of mind (until more serious electrical problems arise). If you are drawing too much current from your electrical system, you will eventually face much more costly bills than your $100 cap (alternator, battery, master fuse panel, etc). That is my $25.02 (a little more than .02 )"
Old Jan 15, 2004 | 09:16 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
P.S. - next time you see a post about caps pass this along and save the kid 100-200 bucks
Old Jan 15, 2004 | 10:44 PM
LMAO
boy this has been fun. Cap's do what they are meant to do but because they are so expensive and dont really help the amount of power in the system in the beginning they really dont matter so guys dont worry about it i knew that before i started this thread. thats why its asking about H.O. alts not which brand of cap i should get.
Now i think it is cute that if anyone new anything about head units they never would have said that i was overdriving my preamps a Pioneer DEH-P8500MP has 3, 4volt pre-outs. heh lol now about overdriving my amps my 4ch V12 is less than half way up and my V12 sub amp is about 3 quarters of the way up so i know that im not overdriving them. The three magic wires might be the problem but im still wondering if that'll fix my dimming lights and that the system just about sucked my battery dry. Would the wires be causing a problem in charging the batt? because say im driving on the highway doin 70 with my system off my batt indicator will be 1 tick above 13 but if im bumpin my music it will be sitting at 13 or right below it. Now would that be because the wires are crappy or am i overdriving my alt. Now i was told it was 105 amp i have no clue whatever the normal factory replacement alt for our cars is, is what i have. That and i watch my batt indicator likes to bounce with my music when im idling at the lights. im in the middle of a major drivetrain change so i havent gotten to look at them yet but i will go to walmart or even a weld shop to check out the wires and probably replace them. Now that is said. If my lights still dim and my batt indicator still jumps into the yellow zone THEN... should i get a H.O. Alt?
Old Jan 15, 2004 | 10:52 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: LMAO
upgrading the 3 wires under the hood will allow your system to charge better. Having one small wire in your charging system is like having a bottle neck in your exhaust, its only as good as the weakest link
if that still isnt the problem, i would look into getting a higher output alt
but you would be surprised at all the problems the big three can fix
Old Jan 15, 2004 | 11:44 PM
Changing the wire from the alternator to the battery will help make it more efficient, but will still not increase the output of the alternator, seeing that the amp is sucking most of the power from the battery. Changing the ground and amp + wire would do the most good.
Old Jan 15, 2004 | 11:49 PM
br()bert's Avatar
Car: 85 firebird
Old Jan 16, 2004 | 12:19 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if a 65 amp alternator has 16 gauge to the battery it wont put out 65 amps...so improving the wiring will increase the output
Old Jan 16, 2004 | 02:20 AM
I have an 8 gauge wire running from my alt to ammetter to battery. Tell me how changing the wire increases the output of the alternator too, cause thats not possible. Changing the wire would make the current transfer more efficient, but not increase the output of the alternator. It would decrease the line loss. And the only other way to increase the output, is to increase the number of winds on the armature, and use larger gauge wire; use a larger rectifier, and increased diode bridge, to even further double the output, as what half the alternator produces is, doubled by the diode bridge. And opt for a heavier duty voltage regulator also, for increased durability.
Old Jan 16, 2004 | 02:45 AM
BruteForce's Avatar
Car: V6 RS-R Camaro
Engine: 3.5l H.O.
Transmission: manual 700r4
87t-5.0,
This is the Alt you would need. You can buy it through Summit racing for $165.00. Its rated at 140amps and is made specifically for your car as a high-output upgrade. It has the factory OEM wire connection plus comes with a heavier power lead (pictured) AND the unit is chromeplated.
The unledgeable tag in the picture reads:
Powermaster
Part #37861
set volt 14.7VDC
Output @ Idle: 86amps
Output @ highway speed: 141amps
Your stock alt is rated @ 105amps at highway speed.
Old Jan 16, 2004 | 02:54 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Originally posted by BruteForce
87t-5.0,
Powermaster
Part #37861
set volt 14.7VDC
powermaster makes some very nice alts
"I have an 8 gauge wire running from my alt to ammetter to battery. Tell me how changing the wire increases the output of the alternator too, cause thats not possible. Changing the wire would make the current transfer more efficient, but not increase the output of the alternator. It would decrease the line loss. And the only other way to increase the output, is to increase the number of winds on the armature, and use larger gauge wire; use a larger rectifier, and increased diode bridge, to even further double the output, as what half the alternator produces is, doubled by the diode bridge. And opt for a heavier duty voltage regulator also, for increased durability."
if you're running a 100 amp alt it is capable of 100 amps...but if you're running too small of wire to the batt it will not put out what it is supposed to. Its not that difficult to understand.
if you have 3 inch exhaust with a 2 inch tip...it will only flow as good as 2 inch exhaust
Old Jan 16, 2004 | 07:05 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
yummmmm i like that alt!!! guess i'll be replacing my rust *** piece of crap one with that maybe huh?
oh- and btw- capasitors act like a air cushion... the air gets pushed out, but the air still has to go back in to fill it back up... all it does is supply a tiny bit extra current when there is a hit... more than anything, the charging system just needs to be up to snuff- 3 wires changed to larger size to increase efficiency (read less line loss from the undersized factory wires)
Old Jan 16, 2004 | 11:49 AM
My 65 amp alternator is in my 84 cavalier. I have the 135 amp alts in both my f bodies.
Old Jan 16, 2004 | 04:43 PM
onebadwagon's Avatar
that is actually not true, not to start anything, with exhaust, a 3 inch system with a 2 inch tip will flow dramatically better than a 2 inch system, mainly because by the time the exhaust gets to the tip, it has cooled somewhat and occupies less space.
adam
Old Jan 16, 2004 | 04:54 PM
br()bert's Avatar
Car: 85 firebird
heres another comparison, its like getting a REALLY thick milkshake and using a straw, sure you get some but not as much as you would with a spoon. Kinda what the stock 3 wires are compared to replacment thicker ones
Old Jan 16, 2004 | 06:26 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i'm gonna agree with the "magic 3" wires upgrade. i run around 600+ rms of class a/b amps (around 90 amps worth of fusing). these are not easy on an electrical system. but i have no dimming problems what so ever. with my old system and car, i neglected to do these upgrades (i was still new) and was running a setup that was probably only around 2/3 as powerful and i had big dimming problems. caps are band-aids, and having the digital readout can actually furthur hurt their ability to do the job they supposedly do. go to carsound.com and check out some of the information richard clark (love him or hate him, he is very knowledgable in the car audio field) has done one caps. as for the type of wiring, someone hit it right on the head with welding cable. its just about as flexible and decently resiliant to underhood chemicals (although putting loom over it wouldnt hurt either). it just doesnt look pretty. but for 1/4 or less price-wise to the fancy stuff, i'll deal.
Old Jan 16, 2004 | 07:50 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
adam
touche my friend
Old Jan 16, 2004 | 09:25 PM
heh........
Ok maybe its just me but did i forget to mention the 4 Gauge +Amp wire running from my batt to my 4 way distro and then 8 gauge running to my amps and also 8 gauge from my amps to the chassis for ground. All of it being stinger wiring. The main power wire has an 150 Amp fuse and was installed about 4 months ago by me. The amps are grounded securely and are being powered just fine. My amps are not shutting off because of my wire (I know that for sure cuz i sure as hell dont need 0/1 gauge yet) they are shutting off because i dont think they are getting enough power which is probably because of the magic three or possibly alt. So.......... for some reason i dont think that i would need to replace it but that just could be me....
Thank you BruteForce that is a very nice alt im gonna take down the info for it and after i take care of the magic three then ill look at getting one of those.
so lets make a list of the probable causes for them shutting down and my lights dimming just to make sure everyone's on the same page......
Magic three- Probably the problem
Alternator- Possibly also needed
1FD Capacitor- Waste of Money
Pre-Amps -4v apiece.... ya right.....
Amplifier Wiring- 150A 4 Gauge Stinger...um...NO
Old Jan 17, 2004 | 12:18 AM
br()bert's Avatar
Car: 85 firebird
my amps turned off one night, turned out i had a bad ground.
Old Jan 17, 2004 | 07:49 PM
not the ground
i used 8 gauge rings terminals that i screwed into the trunk area which directly connected to the chassis and i checked them to make sure they hadnt gotten loose.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
