4th Gen Interior/Exterior compatibilty List
Old Jan 28, 2004 | 05:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
4th Gen Interior/Exterior Compatibilty List
I think this would cut down the amount of repeat questions as well as being quick reference guide for the members.
Old Jan 28, 2004 | 06:20 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Sticky...Try to keep on the subject and I'll leave it. Thanks.
Old Jan 29, 2004 | 07:22 AM
88txiroc's Avatar
Really no need for another sticky on this forum.
People just need to check the FAQ board. I will leave this thread up here for now, but it should be moved to the FAQ board once it has some answers.
Old Jan 29, 2004 | 10:38 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Just to start -
4th gen seats are a direct bolt in. If you get power seats from the newer car, then just wire them up like you would any other power accessory...you may even have the stock power seat wiring under your carpet.
Consoles...do NOT get the 93-96 camaro console and expect it to fit right. It leaves a large gap between the radio pod and console and doesn't fit the look of the dash at all. The 93-96 Trans Am console has 1 cup holder and the 97 - 2002 console has 4. A word of warning - these consoles are NOT direct bolt ins as many will tell you. Expect to take a rotozip to it if you want to clearance things. You may also need to move your shifter over to align it with the console opening. I have never seen a completely flush fitting 4thgen console in a 3rdgen - and I've seen quite a few from these boards that look perfect in pictures but are not. Expect to do some work if you want it even remotely close.
Here are some comparison pictures of 3rd and 4th gen consoles.
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-mvc-016s.jpg
Car: 1987 GTA
Transmission: 4L60e
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-mvc-014s.jpg
Old Jan 29, 2004 | 11:33 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The seats are a direct bolt in like 3.1EyeCandy said but the back seats are smaller and you will have a slight gap between the back of the rear seat and the plastic. Nothing to worry about but I thought I would mention it. Also with the ones I have the gap between the console and the front seats is a little biger also.
Old Jan 29, 2004 | 12:07 PM
Zepher's Avatar
4th gen steering wheels also bolt up with no problems.
Don't know about the airbags though, since my cars don't have them.
Old Jan 29, 2004 | 09:07 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
-4th gen dashes (with some modification and wire splicing) do a search
-rear ends (with 4th gen wheels)
-4th gen wheels (only if you use adaptors(do a search for vendors), but no need on the rear if your running a 4th gen rear end)
-seatbelts
-door panels (with some modification and cutting of panels) do a search
-rear coil springs (ive been told)
-drive shaft (most 4th gens had aluminum) Im not sure if the v6 ones will work??
-LS1 and LT1 (alot of extra work and parts but can be done) see engine swap forum.
-T5 to T56 trannys (extra stuff needed) do a search
Old Jan 30, 2004 | 09:08 AM
GTA4ME's Avatar
Exactly what I had in mind!
Old Jan 30, 2004 | 11:21 AM
JR86-TA's Avatar
Car: '86 Trans Am
Also:
4th gen side mirrors with slight modification.
There are talks of the 4th gen plastic gas tank working... I am not sure if anyone has completed it or not, though.
Old Jan 30, 2004 | 11:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
rather then mention everything and say do a search, for this thread to be effective, YOU should do the search, and after you sorth thru the 1000s of "how do i" threads that end with, "do a search" take thoes few good threads, and POST THE LINK HERE
then zepher or some mod can take all the answers create a new FAQ thread without this clutter and will have a 4thgen swap refrance thread.
Old Jan 30, 2004 | 11:07 PM
prophecy xi's Avatar
I am attempting to install a 4thgen clothe interior i got for 300 bux, console, seats, and dash. I seen you have done this before zepher. My question is the guages are all elctronic while i have the original 700r4 from my 89 formula. mechanical tach and speedo. the 4 th gen is all one plug. is there a company that makes custom guages for this kind of fit.
By the way zpher your lt1 t/a is the most bitchin 3rd gen ive seen.
Old Jan 31, 2004 | 02:50 AM
Zepher's Avatar
Only way to do it is to do it yourself, no custom plug in adaptor is out there, yet.
Old Feb 3, 2004 | 09:32 PM
FLYNLOW92rs's Avatar
I personally have a 4th Gen gas tank in my car, so yes it can be done......
Old Feb 5, 2004 | 04:15 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
4th gen 97 manual console to B&M megashifter = disaster waiting to happen ( I cracked my console, its basically too big).. it may be possible, but I add that to my list of 3rd gen failures.
Old Feb 15, 2004 | 03:22 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
-seatbelts
This post was interesting... I actually want to do a lot of this to my car! I was concidering selling my car and just getting an '02 t/a ws6, but I think I'll hold out and maybe just mod the interior instead...
Old Mar 1, 2004 | 08:41 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
how bout that 4th gen rear....
Old Mar 10, 2004 | 08:06 PM
Car: '81 Trans Am
Engine: 6.6L
yah i have the rear up there already....thing is its abit longer but perfect if your ganna run 4th gen wheels too.
heres more that will fit....
rear lower control arms
panard bar
t5 and t56 aftermarket tranny mounts are interchangable(not sure about stock ones)
Old Mar 28, 2004 | 09:31 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
4th gen dash/console and guages fit and work with some moddding.
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-interior.jpg
Old Apr 4, 2004 | 03:50 AM
89firechicken's Avatar
i found that the corvette mirrors that were on the c4's work and there heated as well
Old Apr 15, 2004 | 02:42 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
the rear, panhard bar, LCA's, springs, and shocks all work. I did the swap, well worth it. you only need the wheels if you don't like the tires sticking out of the wheel well.
Old Apr 15, 2004 | 04:05 PM
Car: '81 Trans Am
Engine: 6.6L
I think someone should clarify he only means the rear springs, rear shocks and rear LCA....not the front end stuff too.
Old Apr 15, 2004 | 10:37 PM
Car: 1982 Trans Am
Engine: 383 chevy
hmm.. good idea. what he said. I dunno about the front. methinks no.
Old Apr 15, 2004 | 10:50 PM
Car: 1987 IROC Z
Somone post the part number or a link to the part needed for the dash conversion from analog to digital signal. I know that dakota digital makes it, just don't know the part number.
Old Apr 15, 2004 | 10:58 PM
dieseldennis's Avatar
Car: 1987 Camaro Z28
Engine: 5.7 HO TPI
Do all 4th gen fbodies have Aluminum driveshafts? If no, Which cars should I look at? What kind of difference will I notice if any?
I know that a post in here says they are swappable into my 87 Z28 but is it as simple as a regular ol' R&R, or is there a mod or two I need to do?
Thanks All
Dennis
Old Apr 16, 2004 | 11:25 AM
Engine: 5.7 HO TPI
I just called my used parts guy and he has a couple driveshafts from a 94 and 95 model. But they come from a standard transmission car. Are they different sizes than a auto tranny one?
Dennis
Old Apr 19, 2004 | 02:36 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
E brake handle
Anyone know if the 4th gen ebrake hadle works? I think it is close at the very least but I was just wondering if the bolt hole lines upon the metal or not. Mine is getting a little cracked in the leather at this point. No sense spending money to get it recovered. What is a good price to pay for them also?
Old Apr 22, 2004 | 02:27 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
LS1 Aluminum driveshafts came in the 98-02 F-bodies, their the ideal swap, their 3" in diameter, weigh about 11 lbs and have a vibration dampener. Not all LS1 f-bodies had them, I think if the car was an auto and had gearing of 3.23 or higher, it had a aluminum driveshaft, any lower gearing on a auto ls1 vehicle was given a steel driveshaft. These are direct bolt ins for our vehicles unless your thirdgen has a th200c (or whatever the early automatic was) or the four speed saginaw.
It doesn't matter if the driveshaft came from a auto or standard, they are the same length. The v6 steel shafts in the fourth gens are also the same length and are direct bolt ins.
The aluminum driveshaft that came in the lt1 93-97 f-bodies was the 1le aluminum driveshaft, it was 2.5" (or 2.75?) in diameter, weighed a little more than the ls1 shaft and lacks the dampener. Still a good upgrade over the stock steel.
All driveshafts in the fourth gen f-bodies are direct bolt-ins no matter the engine or transmission unless of course you have a saginaw or th200c equipped thirdgen.
Old Apr 22, 2004 | 02:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by pasky
LS1 Aluminum driveshafts came in the 98-02 F-bodies, their the ideal swap, their 3" in diameter, weigh about 11 lbs and have a vibration dampener. Not all LS1 f-bodies had them, I think if the car was an auto and had 3.23 gearing (or was it 3.03?) they came with a steel shaft. These are direct bolt ins for our vehicles unless your thirdgen has a th250 (or whatever the early automatic was) or the four speed saginaw.
All driveshafts in the fourth gen f-bodies are direct bolt-ins no matter the engine or transmission unless of course you have a saginaw or th250 equipped thirdgen.
its 200r4, not th250.
Old Apr 22, 2004 | 02:45 PM
pasky's Avatar
Fixed and thanks, I always forget the name of that thing.
Old Apr 22, 2004 | 07:48 PM
Car: 1987 IROC Z
hey.. thats a good idea...
Old Apr 22, 2004 | 11:47 PM
Car: 1982 Trans Am
Engine: 383 chevy
wrong. it's TH200c. the 200r4 is a V-6 700r4 tranny. it would still yield the same shaft length as the 83-02 cars. 82 and early 83 saw the saginaw/muncie/th200c trannies.
Old Apr 22, 2004 | 11:51 PM
pasky's Avatar
Fixed.....again
Old Apr 22, 2004 | 11:56 PM
Car: 1982 Trans Am
Engine: 383 chevy
cool. sorry to be a pain, but it took me a while to figure out which one it was, too. wasn't until i popped open haynes, chilton, AND helms and saw that it's a th200c, not 200r4. 200r4's can be built stronger than a th400. CHP did an article on it.
Old Apr 23, 2004 | 12:31 AM
pasky's Avatar
Its cool man, I want it to be as accurate as possible, its annoying seeing the same questions over and over on these boards from the new junior members.
Old Apr 26, 2004 | 08:07 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
I am wondering what years of both camaro and firebird had the black dashes and console compared to those with the grey dashes and console.....also what is the compatability of fourth gen seat belts in a third gen???
Old Apr 29, 2004 | 07:57 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
V6?
Will the ls1 driveshaft work with the v6? and is installing the 4thgen centerconsule hard?
Old Apr 30, 2004 | 09:15 AM
Car: 1987 IROC Z
T56 swap ? I don't know if I should bring that up here or not. Im sure their is thread about this elsewhere.
Old Apr 30, 2004 | 09:19 AM
Car: 1987 IROC Z
4th gen 6 speed console ( the one with 3 cup holders) + B&M ratchet shifter = NO
Mine cracked my console so bad that I have returned to stock..
Im not going to say that it cant work, I am just saing that the shifter is too big to work when shifting manually.
Old Apr 30, 2004 | 02:37 PM
7plagues's Avatar
Well my car is manual so wouldnt that change something? just wondering... i still have to find the consule too.
Old May 9, 2004 | 01:24 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
One quick note for Power 4th Gen Seats with inflatable Lumbar and inflatable Kidney Side Bolsters:
I just installed '00 Trans Am seats in my 89 GTA.
Already had most of the wiring and tubing. Had to cut the 89 wiring to steal the fuse and connector. Removed the '00 wiring connector. GTA's have a tube and 4 wires going from driver side to passenger side. '00 TA's need 6 wires and 2 tubes. Basically Orange with black stripe is +12V, Black is ground. Fuse the +12V. +12V and Ground come in on the driver side and is seperate from the 4 wires jumping side to side. The +12V (orange and black) has to go into the driver seat, and to the passenger seat. Ground (black) does too. Two more wires must be added that go directly from one side to the other. A vacuum tube must also be run (but it's not carrying vacuum - the inflating pump is under the passenger seat for both seats). Then just be sure to wire it so that the same color from one side is connected to the same color wire on the other. Then, splice in the tubes paying attention to the connector again keeping the same sides connected together.
Also, if you have a split folding rear and install a non split rear, there will be two posts sticking out of the middle hump that can be left there, but they are quite visable.
Old May 19, 2004 | 11:45 AM
88IROCARMY's Avatar
4th Gen Automatic Trans Shift Handles can be used on the 3rd Gen. I have a 4th Gen Firebird "Side -Button" that replaced my 3rd Gen Camaro "Top-Button".
4th Gen inside mirrors with the map lights can be used on 3rd Gen.
4th Gen radios (I think???)
Old Jun 11, 2004 | 09:05 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
If anyone cares... the outer door handles fit like a champ. I just snatched some off of a v6 firebird in the junk yard yesterday and put them on my car. They don't have the indented block on the handle.. it's smooth. Looks much better IMO.
oh yea... and less miles/use on the handle = no wiggles. Handles are solid, no more rattling.
-Bud
Old Jun 11, 2004 | 09:14 AM
Car: Camaro
Engine: 3800
excuse the dirt action going on in the pic, I just ran out and took it
Old Jun 20, 2004 | 12:05 AM
weberusn's Avatar
Car: 91 Camaro RS
are there any how to's on 4th gen dash installs?
Old Jul 8, 2004 | 06:40 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
can you retake the pic because of the text-file action?
Old Jul 9, 2004 | 12:49 AM
Car: Camaro
Engine: 3800
geocities... you can put up pics if they are renamed *.txt Anyway.. uploaded on here:
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-4thgenhandle.jpg
Old Jul 9, 2004 | 11:09 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Hmmm i like the handle. Are they plastic?
Old Jul 9, 2004 | 07:55 PM
Car: Camaro
Engine: 3800
The handle I got (not sure if they are all the same) are 100% identical to thirdgens... just minus the rectangular indention (cosmetic). It's smooth.
-Bud
Old Jul 10, 2004 | 06:32 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Is the automatic console still the same deal with needing modification, and/or moving the shifter? I was thinking of swapping to either a 91-92 console, or the 4th gen.
