How to get better acceleration?
Old Feb 14, 2004 | 01:28 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
I'm a stupid newbie, I will warn you of that right now. I was racing my 85 Camaro and it totaly sucked. I got beat every time I raced tonight. All I know about my car is that its pretty much stock. Its got a K&N air filter on it and also a flowmaster. I wanna know what I could buy to get better acceleration outta my car. What parts should I be looking for? What cheap/little things can I do? I got an ADS Superchip, but from what I hear, they suck..Any help guys?
Thanks!!!
PS: Sorry for being stupid. I don't know car talk. I wish I did.
Old Feb 14, 2004 | 03:03 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I think the best bang for the buck to get "out of the hole acceleration" is to change your rear end gears. Just my 2 cents
Old Feb 14, 2004 | 09:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I own an 85 IROC, LG4 as well. Check my mods for some ideas, especially the carb stuff. The tech board will show you how to do those mods. I have no experience with chips, but I've heard that on a carbed car, they're not really worth much. Advance the timing on your own and save some money. If you want to learn more about cars, hang around the boards, ask a lot of questions (members here are cool about helping newbies), also do searches. You'll find that many of your questions will be answered there.
JamesC
Old Feb 14, 2004 | 09:53 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
thank you for your help guys, I'll look in the tech board!
James Curtright
Old Feb 14, 2004 | 10:07 AM
ede's Avatar
ede
you'll feel more with a gear change than most mods you can do for the same money
Old Feb 14, 2004 | 10:29 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
How much money will I have to dish out for one?
Old Feb 14, 2004 | 10:40 AM
JamesC's Avatar
Out of curiosity, what transmission are you running: 700R4 (auto) or T-5 (5 speed)?
JamesC
Old Feb 14, 2004 | 10:50 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
700R4
Sorry, I didn't think to mention that.
Old Feb 14, 2004 | 04:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You need a better set of gears!
My 85 Z28 came with a 3.42 posi very reponsive at any speed, I miss that car. All the other rear ends Ive seen are for crap highway gears. If you have a TPI its a 3.23 posi disk which is alright. If you have a carb most likely you will have the standard 2.73 open or a disk setup with more crap 2.77 or so highway gears. You need to pull the cover off the differential and find out.
A 3.42 setup will be the cheapest most bang for your buck item you can you can get. I got the 3.42 setup for my bird $100 at the bone yard, made a world of difference over the 2.73's. When I did the swap I honestly thought someone dropped a 502 under the hood while I wasent looking, it made that much of a difference.
Side note: Since I had the camaro 1st then latter got the bird I had no idea GM put these crappy gears in these cars for weeks I was wondering what was wrong with the bird since it had no power compared to the camaro.
Old Feb 14, 2004 | 10:42 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
So, if I got one, would I need to buy anything else to go on my camaro so it could handle it? If so/not, how much would it be to have everything installed?
Old Feb 15, 2004 | 12:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
a good dual plane intake with a decent carb and a good set of headers are also a good bet (following gears, if thats the path you wish to take)
Old Feb 15, 2004 | 07:02 AM
JamesC's Avatar
As has been stated, pull the diff cover and find out what gears you're running. By the way, my carbed car has 3.23's stock. Anyway, you need a gear check to determine what carrier you'll require. 3.08's down require a series two carrier, 3.23's up, a series three. Check Summit or Jeg's for prices on gear sets. Guys who've swapped gears step in here. I "imagine" total cost--gears, installion kit, and labor--would run in the $300 to $450 range. A cheaper option would be to purchase a rear with the gears and brakes (possibly even a posi) you want. I have a yard nearby with a drum 3.73 for $150, for example. Though this is less important, you'll need speedo gears if you care about knowing how fast you're going. That swap, as I understand it, is simple.
The following are GM numbers stamped on the ring gear:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
These are the RPO codes that might help you narrow you search--but I WOULDN'T count on them:
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
GT4 = 3.73
JamesC
Old Feb 15, 2004 | 09:55 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Thanks for all your help. Though I'm still a newbie, I am learning! You all have been a real big help!
Old Feb 15, 2004 | 10:19 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Since you are a newbie to this area I'd highly suggest you forget installing a set of gears and just find a V6 bone yard setup. Its actually cheaper then installing a set of gears provided you can swap the rear end yourself. Of course this is all pending until you find out the actual ratio.
Old Feb 15, 2004 | 10:23 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Well my father is the lead mechanic at the local Acura dealership. Whatever I want to do, he will probably help me. He doesn’t know that I want to do this right now. I just want to know what to buy, and how much to expect. Would going to a V6 have better performance than my current V8? Sorry, more newbie questions.
Thanks!
James
Old Feb 15, 2004 | 10:37 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
no
ssc told you to find a v6 setup cause a lot of them came with 3.42 gears stock
Old Feb 15, 2004 | 10:43 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A V6 rear end is the same except for better gears. Find an 89+ one and it will have better axles if thats what your looking for. Doesent really matter to me which I use as long as it isnt a 2.73 axle. Its just alot easyer to drop in an enitre rear end then change the ring and pinion. With your dads help I bet you guys could knock it out in about an hour and a half. I do swear if you have 2.73's or 3.08's a 3.42 will give you exactly the performance you want.
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
DIY PROM
Sep 16, 2015 09:15 AM
