th200
Old Feb 23, 2004 | 04:19 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
th200
what is the exact length of a th200 driveshaft from an early 80's camaro? i need one for a th-350 swap. thanks
Old Feb 23, 2004 | 07:56 PM
MCas7's Avatar
Here, check this link out. I hope it helps.
http://www.prestage.com/Tech+Info/Transmission/324.aspx
Old Feb 24, 2004 | 05:12 PM
bubbz89's Avatar
Car: 1990 RS
anyone have any hard numbers?
Old Feb 24, 2004 | 07:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Not on hand but mine is laying in a corner collecting dust at the shop. I can measure it tommorow if no one else chimes in between now and then.
Old Feb 24, 2004 | 07:11 PM
bubbz89's Avatar
Car: 1990 RS
thanks
Old Feb 25, 2004 | 07:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Originally posted by bubbz89
thanks
No problem. It's 51in from the end of the yoke to the end of the yoke. This should be a good measurement for a competent driveline shop but if not the shaft is 46 3/4, center of U-joint cap to center cap is 49 1/2 (this is the measurment most shops use)and the complete driveshaft ready to install should be 56 1/2in.
Old Feb 25, 2004 | 07:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Just remember thats a 200c/TH350 short tail shaft measurment.
Old Feb 25, 2004 | 07:35 PM
bubbz89's Avatar
Car: 1990 RS
awesome man!!! i really appreciate it!!! btw, is yours for sale?
Old Feb 26, 2004 | 02:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Not at this time, I had 2 of them sold one after the camaro was wrecked. I'm still debating if I'm going to drag this car again, I did have a TH350 in it at one time, if I decide to race it I'm going back to the TH350. I do recomend the hurst kit though, It comes with more goodies for the conversion.
Old Feb 26, 2004 | 04:52 PM
bubbz89's Avatar
Car: 1990 RS
i was looking at the b&m kit, what are the differences?
KrisW
Jan 3, 2008 12:59 AM
hectre13
24
Mar 11, 2007 09:58 PM
TransamSBC
Dec 26, 2006 04:45 PM
poncho9789
Apr 19, 2002 01:02 AM
Calderone
Sep 15, 2001 11:01 PM
