no blinks??
Old Mar 19, 2004 | 01:27 PM
chevyrumble83's Avatar
Car: 1983 Z28
no blinks??
hey guys! what would make the blinker not blink? when i turn mine on the signal just stays on and no blink for both left and right, even the dash areos dont even blink. how do i get them to blink?? its driveing me nuts blinking them manualy with the signal switch lol. oh strange thing is that when i put on the hazzard they all blink
please help me out!
Old Mar 19, 2004 | 05:24 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
A) Possible - Low voltage; is the car running and charging properly?
B) Most likely - One or more burnt out bulbs per side will also cause them them to not flash.
C) Least likely - The flasher unit is bad and needs replaced.
Old Mar 20, 2004 | 11:04 AM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
I have the same problem with just the right side. I remember a post not long ago about it. It could be one of the ground connections for the lights as well. Since it's finaly warm here, I might actually try to fix mine lol.
Old Mar 20, 2004 | 01:48 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
OK, I got mine working. Here is what I found on mine. This was for my Firebird. I assume you have a Camaro, but the sockets should be identical so this might work.
The front signal light socket had a bad ground. The terminal was corroded and brittle. So the "tab" that makes contact in the socket broke off. I bent what was left slightly so it made solid contact. Works great!
I also checked the ground to the chassis. I unbolted it and used my polisher and ground off the corrosion and rust off of the bolt, washer, body and terminal.
Now everything works the way it should. I'll probably still need to get a new terminal or socket, but it works now, so i'm not worried about it.
Hope that helps.
Old Mar 20, 2004 | 04:21 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
You used line B from Petes 84Z28. The most common cause is a bad bulb but as you found out, the socket was defective. I found that if you turn on your four ways, you will find out which bulb is not blinking and go from there.
Old Mar 21, 2004 | 11:43 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
both my front ones don't blink....? they are brand new apc blue xenon bulbs..... worked before I started messing with the wiring trying to wire in another set..... whats up with this? bad ground? back ones flash on hazard, but stay solid when on signal and same with the dash light, while the front ones dont become illuminated.
cheers
Blake
could it be a relay>
cheers
blake
Old Mar 22, 2004 | 04:11 PM
Car: 1983 Z28
blake mine does the axact same same as yours i am going to try hunting down the wires this weekend i will let u know if i find the problem.
anyone know were the grounds are located???
also if the relay was broke would the hazzard blink?? were is the ralay? how can u tell if its broke?????
about power>> my battery if from my old cavi (car broke and just bought battery so i could not waste my money) its a bit small and my battery gauge only reads right at the half way mark when car is on. could a smaller batter effect anything??
Old Mar 24, 2004 | 04:28 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
found my problem. because i dont drive my car yet, its a project. I had taken out the day time running light module. I tested my wires and got to a point where it wouldnt light up the bulbs, so I got close to the source. and seeing that there was noting that the dark and baby blue high beam flash wire's lead to except a empty prong, which happened to plug into my daytime running light crap. well I pluged one prong out of the two in, and bang. it worked..... so in the end, I went through 3 hours to wire in another set of bulbs, then probably another 3+ hours looking for a problem. then took off what I did to see if it would work. realized it didn't still and spent another 3 hours looking for problem. found problem, re wired 2nd set of bulbs into my car..... total 12hrs lol
good times!!!
cheers
blake
ps hope that maybe you have somethign of the same situation?
I'm taking it that you have a bad connections some where, my grounds were in different spots for each bulb, so I would rule that out, unless yours isn't? check your relay? those are my guesses, I konw all the path routes of those damn wires. what i did was at the interior fire wall where the wires come together, they are separated nicly on a pigtail, so I ran a bare ended wire which would be cramed in with either my baby blue wire or dark blue wire and then touch the positive terminal on my battery to see if the high beam flash would come on. and shure enough for me it did, so I know it had to be something inside.
try it out
cheers
blake
Jk_Under
Sep 2, 2015 10:59 PM
BahamutRS
Sep 15, 2001 02:51 PM
Jeremy_84_F41
Dec 1, 2000 06:11 PM
