Engine Mod Problem!!!
Car: 1991 Camaro
Transmission: t-5
OK, so I recently put an LT1 Cam, Vortec Heads, and a GM High performance intake on my 1991 TBI 305. When i finished the assembly I tried to start it, nothin. So then i played with the distributer a tad and it fired up, ran real rough. Finally got it timed I set it at about -6 BTDC. Took it for a spin and in ran like absolute crap. Backfired, hardly any power till about 4000 rpms, even then not much. I tried a few different times with the timing set at different places and it seemed to run best at -6 BTDC. I cant think of what is causing it to run like crap. I would really appreciate some input. Thanks. -Adam
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
Normally with a cam like that you'd want to advance the timing not retard it 6* and be sure to unplug the est wire when setting timing. You are in desperate need of a chip too.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1991 Camaro
Transmission: t-5
The chip is on the way, I wrote the guy at tbichips.com today. So it may just be the computer acting up because of the new cam? The Vortec's are stock, I just didnt have the money to do any work on them. Ill try the timing adjusment. thanks.
Car: 1991 Camaro
Transmission: t-5
So it turns out im retarded, not my timing..No pun intended. I did have it advanced all along. I dont know why i said otherwise. So that gets rid of that idea.
sounds like what happened to me. all mods done at once cept tuning. i needed a lot more fuel. tuning was a necessity. no way around it. tried a vafpr and that helped but still too lean in cruise mode. vafpr helped WOT. drivability was terrible. welcome to world of eprom.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Brian does nice work. He did my chip. I'm satisfied for now. Put the timing at 6* and then increase fuel pressure and you're good to go.
Car: currently thirdgenless!!!
Really Slow,
Are you able to download data? You will need a Winaldl cable to download some logs to send to Brian. Constant tweaking of the chip will be necessary to get it running right. That is the stage I am in right now. The other choice is to learn chip tuning yourself and dial it in over time.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Engine Mod Problem!!!
