what are the biggest largest high impedance injectors?
Old Apr 21, 2004 | 05:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I was just wondering because I found these:
http://www.racetronix.com/Racetronix..._Sale-55h.html
Old Apr 21, 2004 | 08:00 PM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Injectors
Yes, I dont think they go any larger. The biggest I had found until now where 55#.
Old Apr 21, 2004 | 09:39 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Poke around the buick sites. I've heard there is a "pencil" style injector that runs 55-60 lb and is high Z (Saturated). BW
Old Apr 23, 2004 | 03:33 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
https://www.turbo-link.com/tlink/details/catL107.html
60PPH injectors you'll see some higher ones soon. Why not look into modding the ecm? Don't know how much peak and hold style drivers would be for the TPI ecm, but may be something looking into.
Old Apr 25, 2004 | 04:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im not looking, I just was noticing. thought others might be interested. Had no idea if there were bigger.
Old Apr 26, 2004 | 12:49 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Search turbobuick.com on the general buick tech board :-)
(sorry i cant find the link offhand)
U can get 65, 72 and 75# as well :-)
U will pay thru the noise. but u can get them :-)
Most realisitic answer are the 60# like Grumpy likes to run and Im most likely getting for my TTA when its all said and done :-)
Old Apr 26, 2004 | 05:15 PM
Bitchin89RS's Avatar
Car: '89 RS
Engine: LT4
I saw in a Chevy Hot Rod mag, that there was a '01 trans am that ran 8.58 in the 1/4, with over 1000hp that had 120lb/hr injectors, or so it said..
Old Apr 26, 2004 | 06:19 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Yeah but they were most likely low impedence like my 83lb/hr injectors are.
Steve
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
db057
Sep 4, 2015 07:57 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
