V6, just died and won't start
Old May 8, 2004 | 11:21 AM
jwisse1's Avatar
Car: 1987 Firebird
Engine: 2.8 MPFI
I have a 1987 2.8 MPFI Firebird. I was driving on 2 occasions when I hit a bump and the car just died. The first time it satrted back up a week after, but this time it has not started in almost a month. I have replaced the MAF sensor, checked fuel flow ( it is good) and have spark. So why don't I have a running car. Any info will be greatly appreciated.
I have been through the engine compartment and can not find any loose connections. The engine is turning over, but it just will not rin. After it died there was a rumbling noise out the exhaust. Almost like it was back firing, but no bangs , just rumbles.But that has stopped now, all there is, is the engine cranking over but not running. I will check the location of the rotor with piston1 T.D.C. Any other advice will be great. By the way tried pulling codes and all I got was the MAF sensor and I replaced that already.
The spark plugs are clean, the engine is not flooded. the injectors are working.
Old May 8, 2004 | 11:32 AM
92RSSlowmaro's Avatar
Well, I cant diagnose your car with the given information, but you say it died after you hit a bump? First thing to do is a thurough inspection of the engine bay to look for compenents and/or connectors that may be loose.
You say your getting fuel, and spark. Im assuming your getting compression as well? Might have knocked something like a coil lead loose. Or maybe your dist gear jumped/snapped a tooth?
Maybe you wired the sparkplugs backwards?
J/K... let us know more.
Old May 8, 2004 | 11:35 AM
Also, If it were me i'd bring the #1 cyl to TDC and check the location of the rotor on the dist.
Who knows, you may have just knocked some stupid sensor loose.
Old May 8, 2004 | 01:20 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Is it Cranking?
IF it isn't turning over, it could be a loose ground. If you have spark and fuel, timing would be the next thing to question (as stated above). We really need more info. Have you tried pulling codes?
Old May 8, 2004 | 05:15 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Is it flooding itself? Are the plugs sucked in oil or gas?
Old May 8, 2004 | 09:09 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
You say you have fuel flow, but that doesn't mean the injectors are firing... bump + loose connectors or shorted wires.
Old May 11, 2004 | 02:44 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Does your car have the ol GM VATS? I'll bet that if the other stuff all checks out, then the wire that comes off the key cyclinder in your steeing column burnt apart and just makes contact once in a while.
This is what happened to me. It took me about amonth and a half to figure it out.
It also happened to a buddy of mine who had a 1990 GTA.
The cylinder was redesigned so the wire will not wear out.
Old May 13, 2004 | 02:26 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
timing chain
Old May 13, 2004 | 05:44 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Yes, check the VATS if your car is equipped with it. I had the same problem and found it in a day by accident. Damn thing. It's a black box located under the dash and says secure key or something on it. The wires go straight from that box to the steering column. But if that doesn't solve your problem, what is your fuel pressure. I know you said that you check the flow but you didn't say what you fuel pressure is.
Old May 13, 2004 | 06:19 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
multiple threads
Same problem just speard out...
Keep everyone in the loop.
V6 still not running .....second thread
Distributer .....current thread
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
