'85 305 died, 350 swap issue ?'s
Old Jun 21, 2004 | 12:04 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
First off, I searched for an answer ("350 swap" and "305 350 swap") and didn't find one, so I posted this.
I have an 1985 Trans Am with around 135K miles, and the 305 is starting to die. I have a '56 Chevy shortbed project truck that I bought 6 weeks ago, and it has a freshly rebuilt 350 4 bolt main mounted up to a TH400 tranny. The truck is in the middle of a ground up resto, and I will be selling it (won't get to it for another 3 years or so, and it's taking up space in the garage... bummer) but I thought I could use the 350 that's in it and drop it in my Trans Am instead of rebuilding the 305. Are there going to be any issues mounting it up to the TPI intake or the auto tranny? I'm not sure what year the motor is, but all I know is it's a 4 bolt main. Is there a way to find out if it will work with my 700 without taking it out of the truck to see if it will fit?
Also, with the current prices of gas and since this is a daily commuter, how much gas mileage will I be getting with the 350? I'm getting around 25 MPG on the highway with the 305, and I friend of mine says he's gets around 23-25 MPG on the highway with his 350/auto, but with the 45 cubes difference, I find that hard to believe. Does anyone else get that much?
Thanks!
Old Jun 21, 2004 | 12:59 AM
JesasaurusRex's Avatar
K um everything should bolt up the same. Id use the old flex plate off the 305 and torque converter or what ever the hell auto trannys have. Just reuse the flexplate and everything behind it from the 305 onto the 350 and u should be good.
Old Jun 21, 2004 | 09:46 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Well, the 400 Turbo will kill your gas mileage. Your best bet is to put your 700R4 onto that 350 and youll be doin good. 305's and 350's, besides cubic inch and stroke differance arent too much differant. SO, as long as you go back to the 700R4, then you should be OK, but a 400 Turbo is geared for towing and such and around 55 MPH your running like 3500 RPM or a little more, so they kill gas mileage. Hope I could help.
Old Jun 21, 2004 | 01:24 PM
Bore difference not stroke.
Old Jun 21, 2004 | 09:02 PM
onebinky's Avatar
If its post 87 heads you will have to elongate the holes on the intake manifold to get it to bolt up.
You will need the 22lb injectors that came with the 350.
You will need the 350 PROM, the 305 will not work well.
You will need a 350 knock sensor. It's tuned to a different frequency range than the 305 sensor due to the different bore thickness.
You will likely need to reuse the F-Body oil pan, which could pose a problem depending on if the new 350 is set up for drivers or passenger side dipstick.
Should be about it. I'd also follow these other guys advice and stick with the 700R4. A 350 and no OD is gonna kill your gas mileage.
Old Jun 21, 2004 | 09:25 PM
super_kev's Avatar
Car: '85 TA
Read again... I said that the 350 was being pulled from a '56 pickup that had a TH400 mounted to the 350. I wanted to make sure the 350 in the pickup would work with the 700R4 without having to seperate the TH400 from the 350 and finding out it the 350 wouldn't work. I didn't say I was going to use the TH400. Thanks for the replies, I'll be swapping the 350 in soon.
Old Jun 22, 2004 | 11:14 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i didnt see anything about using FI...
Old Jun 22, 2004 | 12:27 PM
onebinky's Avatar
I did
Old Jun 22, 2004 | 02:15 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
doh.... shhhhh our lil secret.
Old Jun 24, 2004 | 07:45 PM
408maro's Avatar
Car: 92Rs 25th ann
Transmission: auto
well if your in cali i think your engine cant be older than the vehicle it going into,might want to check on that
jklein337
Sep 19, 2018 06:23 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
