July 10th Rt 41 trackside EFI POW WOW
Engine: all 225+ RWHP
Transmission: all OD
Is this still a go? At Denny's house we amazingly had about 5-6 of us in one place...
There would be me , Nape, whos got the blueZ(90 Iroc maybe?)i forgot again lol, Plant Protection and Kevin?
Who else?
Are we still planning on doing this?
If you are attending Rt41 on the 10th for racing, please sign up in the sticky
thanks and later
JEremy
Who else?
thanks and later
JEremy
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I still plan on coming, I have nothing to tune myself so I will be able to help out the other guys. Just a couple notes, if you want a chip burnt for simple changes, at the very least have a chip with you. I would also reccomend a moates adapter so you can easily put the chip to use. Nothing major here, I don't feel comfortable altering your tune and you shouldn't feel comfortable with me altering your tune. For those of you that want to use the WB, you will need a bung welded in your I-pipe, somewhere between your cat and the y. Don't want to mess around pulling your stock o2 out, my wiring isn't long enough anyway. Datalogging through the ECM is the best method of getting your readings, but this requires you to splice into your ECM for the WB output and ground and have your prom changed. A VOM will work, but it will be ballpark. I'm sure the other tuners can throw something in here.
Bruce will be there :-)
aka Grumpy to you prom board folk :-)
He has confirmed
bye
JEremy
He has confirmed
bye
JEremy
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
I'll be there and should have a PROMinator in by then. If its not in then I'll just bring it with to show you guys, unless somebody would want to solder it in on the spot
hmmmm
Someone have an inverter for their car that works?
Mine, never helped me any and I've friend the others lol
Got the Romulator and laptop but nothign to power my pocket programmer per se?
I know the tower has power, but not exactly convenient.
later
Jeremy
later
Jeremy
I have an inverter that works very well. Fairly heavy duty, the whole case is basically a heatsink and it has a fan in it. I'll bring that with me; my laptop's battery doesn't hold charge.
Jim
Jim
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Yo Jeremy.
I'm really sorry dude but I forgot that the Busch race is this Saturday at Chicagoland Speedway.
I've had my tickets for months and can't back out now. We'll have to get together for another EFI POW WOW. I'm pissed that I can't be in two places at once
Linson
Oct 1, 2015 09:50 PM
. But I will be there.
