1.6 rockers on stock 305 tpi?
Old Jun 30, 2004 | 12:03 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I can get a free set of 1.6 rockers from my buddy.
Currently i have a bone stock peanut cammed 305. Is it worth it to throw these on since they are free?
How much morelift will they provide?
Any input would be great. thanks
Old Jun 30, 2004 | 12:13 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
they will definitely help.
take your current lift, divide by 1.5 then multiply by 1.6 for your new lift.
Old Jun 30, 2004 | 12:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Like Travis said, the gains are definitly worth it. The lift is the big issue. And with slow ramp rates and mild profiles such as the peanut cam, the "added" duration is actually very decent, as far as simple rockers are concerned.
Old Jun 30, 2004 | 03:02 PM
9D1BURD's Avatar
Car: 1997 Z28
thanks for the replies guys, i guess i will go ahead with it.
Old Jun 30, 2004 | 03:39 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Of course you do realize that one mod change always leads to another...and another...its like LAYS potato chips. Nobody can eat just one!!
Old Jun 30, 2004 | 05:23 PM
mitchc's Avatar
Make sure your spings can handle the added lift the rockers will make.. If you have .500 lift now you will have .533 so you will add .033 lift.
Old Jun 30, 2004 | 08:38 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
If you read the post all the way through, you will notice he said he has the peanut cam, which is no where near .500 lift.
Old Jun 30, 2004 | 09:57 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
.350 and .384 to start(if im looking at the right cam). .373 and .409 after. Are they self aligning, or roller/ roller tips??
Old Jun 30, 2004 | 11:54 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
He said his cam is stock... his springs should be able to handle the lift just fine.
Like the previous poster said, make sure the rockers are self-aligning or they are gonna require guideplates and hardened pushrods.
edit: fruity one beat me to the lift part... however the second part still applies.
Old Jul 1, 2004 | 12:00 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If its the 91 305 in his sig, he has self aligning. The best budget piece that isn't aluminum would be the Magnum rocker arm by Comp Cams. It's a roller tip, not full trunion roller. It is steel so it has better fatigue resistance than aluminum.
They do offer 1.6 S/A versions.
Old Jul 1, 2004 | 07:55 AM
FruityOne's Avatar
The rockers are 1.6 roller tip, self aligning. They are on my car right now.
We're doing a cam/heads swap on my L98 and with the 1.6rr's I'll have too much lift. So I am going to 1.5 rockers. Just a set of stock ones for now, I don't have the cash for a nice set.
BTW, I got them for like $50 with the engine rebuild, I figured it was worth it. Said engine rebuild has a mere 2,000 miles on it. I bought it when I didn't know a thing about casting numbers. Had the engine balanced and blue printed. Too bad the "engine vin code 8" engine they sold came with TBI 193 swirl port heads, and a crappy TBI cam with .384/.395" lift w/1.5r, and 190/195 duration @ .050. On a 117lsa I think.
It sucks, REALLY bad. But now I've got a LPE 211/219 cam, ported L98 with upgraded valve train to handle the lift, ported intake + AS&M SS runners, and hooker 2055's headers to go with the flowmaster(ugh!) 3" cat-back.
Old Jul 7, 2004 | 11:05 PM
89PONT.FORM's Avatar
Car: 89 FORMULA
Engine: 305 T.P.I.
CAM HELP
HEY WHATS UP GUYS IM NEW ON HERE AS WELL AS A NEW THIRD GEN OWNER WELL MY QUESTION IS CA I PUT A CAM INTO MY STOCK 305 TPI IF SO WHICH CAM AND HOW BIG?. PLEASE I NEED HELP THANX
Old Jul 8, 2004 | 12:26 AM
FruityOne's Avatar
First things first, caps are annoying as hell. Please turn them off as it makes you look like you are shouting.
As for your camshaft, how prepared are you to do some MAJOR work? The intake must come off, as well as the water pump, timing cover, and you must drop the oil pan a bit so you don't tear the seal. The Radiator, A/C Condensor also have to come out as well. You may need a new harmonic balancer, or you'll need to remark the old one.
For a camshaft I wouldn't exceed 210 duration @ .050", and I would stay greater than 114* Lobe seperation. Nor would I exceed .475" lift with the stock valve train.
Old Jul 8, 2004 | 05:14 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
If you don't have enough experience turning wrenches, don't put a cam in the car. You 'll need the cam/springs/retainers at the very least, and new valve seals are a good idea, and so is a new timing set. Don't forget all of the gasket, plenty of time, and a lot of patience. You're gonna want to stay below .480 lift and around 220 duration on a 112-114 with TPI. Keep in mind that a cam will not yield and decent gains without the bolt-ons to support it.
IMO you should start with the free mods, then do the bolt ons then decide which way you want to go.
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
