Built my own leak down tester
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Well looked around all day for a place that sells a leak down tester and only found that Napa sells it for $110. I wasn’t about to pay that so I want to home depot and bought all the fittings and made my own, what do you guys think?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
In case anyone else is tempted to do the same http://www.xs11.com/tips/misc/misc3.shtml
Car: 1989 Iroc-Z
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
The female disconnect keeps the gauge portion sealed until you hook it to the hose going to the cylinder. You adjust the regulator for whatever pressure (he specifies 100psi) and then hook it to the cylinder....the .040 orifice serves as a restrictor to control the airflow and the gauge reads how much pressure the cylinder will hold at that given flow rate. Higher pressure equals less cylinder leakage.
Open valves will show near 0 psi and a good sealed cylinder will be in the 90+ psi range (using 100 psi feed.)
Engine: 383 Carb
Right, sealing it up and then watching the pressure bleed off doesn't really tell you much.
Car: 1989 Iroc-Z
Oh okay, I get it now. I guess opening the valve slightly would be too inaccurate, so I will have to figure out some way of making a restrictor.
EDIT: The smallist drill bit i could find was 1/16 = 0.0625 = ~1.588mm, do you guys think it matters that much if it is not .04?
A bigger hole will make it less sensitive. It'll probably still be good for burnt valves and what-not, but really slow leakage like through a borderline head gasket may be a little harder to see.
For really small bits, try looking in the Dremel section. they have some pretty tiny ones sometimes.
Car: 1989 Iroc-Z
In the dremel section I found a 1/32 and 3/64 drill bit.
1/32=~0.031=~0.79 Millimeters
3/64=~0.047=~1.19 Millimeters
So the question is which drill bit to use? Anyone have a suggestion?
Engine: 383 Carb
Either one would probably be close enough. Try a hobby store though, they have all kinds of tiny drill bits.
Engine: 383 Carb
KD Tools P/N 901, includes 14mm and 18mm spark plug to 1/4" NPT adapters. Costs about $5. Or you can use a P/N 2992 which is the same thing in a 14" hose. I'm sure there are other sources as well.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
