Members With Dual Electric Fans and an Aftermarket "Wonder Bar"
Old Aug 11, 2004 | 10:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm considering going to dual electric fans, and I want to make sure there's no interference with my Globel West piece--as another thread suggested there might be.
JamesC
Old Aug 11, 2004 | 12:32 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I have dual electric fans out of an LT-1 Powered F-body installed in my car. When I installed my TDS wonderbar it ended up very close to the fans, but it all fits ok. I don't know if the Global West piece is significantly different, but I think you'll probably be ok. I can't guarantee it, but you should be able to make it work
-Paul
Old Aug 11, 2004 | 01:11 PM
Mark 89Formula's Avatar
I've got the Global West brace and the dual electric fans and have no clearances issues.
Old Aug 11, 2004 | 01:44 PM
JamesC's Avatar
Mark,
Are your dual electric fans stock?
JamesC
Old Aug 11, 2004 | 01:53 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Original dual fans and TDS wonder bar.... perfect together.
Old Aug 11, 2004 | 02:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
factory twins and a factory wonder bra....ha ha....
no probs
Old Aug 11, 2004 | 02:35 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Factory dual fans and Global West piece here - close but no issues.
-Schultzy
Old Aug 11, 2004 | 03:18 PM
JamesC's Avatar
no probs
That wonder bra is probably why you have twins
Schultzy,
That's exactly what I wanted to hear. Thanks all.
James
Old Aug 12, 2004 | 01:05 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
-Schultzy
Same here. To change out a fried fan motor, the bar has to be lowered to get to the fan bracket's bolt
Old Sep 10, 2004 | 07:38 PM
slowTA's Avatar
Car: '88 Formula
To pull the fans I just unbolted the small 10mm bolts that hold in the whole lower bracket. The fans drop down enough so you can get to the larger bolts. Maybe then you can pull them out the top too?
Old Sep 14, 2004 | 09:04 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
How do the dual lt1 fans do as far as cooling? My single fan doesn't do the job anymore...especially if I have the ac on.
Old Sep 14, 2004 | 09:13 PM
quadgoat's Avatar
Car: 1992 Firebird
Compared to my stock single electric they're awesome! I feel like it's one of the best things I could have done to the car. There's some modification involved in installing them (you can search for my screenname and find my post about installing them) but I think it's definitely worth it in the long run!
-Paul
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
