turbo or supercharger for 3.1 ?
Old Sep 11, 2004 | 12:12 PM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
do they make Turbo chargers or super chargers for the 3.1 camaros? just courious and going over my options
Old Sep 11, 2004 | 02:18 PM
stu
Guest
Posts: n/a
You can put a turbo on any gasoline motor you want. I suppose you could do it with a supercharger as well, but it'd be much harder without a kit.
Old Sep 11, 2004 | 02:40 PM
Car: 92 camaro RS
how much custom fabbircation would be involved and would it be easier than a full motor swap
Old Sep 11, 2004 | 03:11 PM
stu
Guest
Posts: n/a
Oh, I have no idea man. I know next to nothing about your car. I would think that a full motor swap would be cake compared to custom mounting some random supercharger.
Old Sep 11, 2004 | 03:41 PM
Car: 92 camaro RS
alright thanks anyways
Old Sep 11, 2004 | 08:57 PM
Doward's Avatar
It's a huge ordeal to custom make a turbo setup.. I'm working on a V6 turbo tho. Kits soon .
Old Sep 11, 2004 | 09:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
The 2.8 and 3.1 are bother and sister in the GM 60 degree V6 family, there is a 3.4 too but that is a whole other can of worms unless you are talking about the 3.4HT crate motor. Anyhow consider that a 2.8 in the FWD Cavaliers are more than similar to the one in your ride. THen look at this:
https://www.thirdgen.org/techbb2/sho...hreadid=238864
Old Sep 11, 2004 | 09:41 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
btw the 3.4 ht is no longer available from GM but you can get a short block from a wrecking yard 3.4 sohc motor and some from 4th gen camaros.
Old Sep 12, 2004 | 03:15 AM
83 Crossfire TA's Avatar
Superchargers are actually relatively simple to deal with… the hardest part is to figure out some kind of bracket that will hold it steady and fit in the space you have. Turbos are a bit harder since that involves more then 2x the plumbing and still requires you to solve packaging issues.
WRT to “custom mounting some random supercharger” it’s really not that big a deal. Most aftermarket setups don’t really need much more then a flat plate to mount to just like an accessory. The OEM blowers tend to be a little more work since they typically expect to be able to bolt to the stock engine configureation, but it still can be done. In this case it’s an M-90 out of a t-bird on a 5.0 in an LTD:
(pic of my brother’s car out of the current MM&FF)
Elephantismo
Feb 13, 2019 12:51 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
cking99
Sep 22, 2015 11:33 AM
