Nitrous wire up problem
Old Oct 27, 2004 | 07:59 AM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
I was installing my nitrous system into my car last not but could not make it run. Do you need a relay to make the system run? I would really like if someone has a wiring diagram or something i can follow so that i can correctly connect the system.- Eric
Old Oct 27, 2004 | 08:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
What system do you have.
I am using a relay for mine (guy at the parts store, tried to sell me a flasher, that would have been interesting!). Are you using a microswitch to activate it at WOT?
Old Oct 27, 2004 | 08:27 AM
a73camaro's Avatar
One way of doing it.
Old Oct 27, 2004 | 06:53 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
I have the super power shot, Yes i got the wot switch. What do you mean by (enable,go baby go, full throttle) You have to have 3 different switchs to activate the nitrous system? Also do you need to have a fuel pressure switch?Does it matter what wire goes to to negative or possitive on the solenoid?Will my system work like this???
Old Oct 27, 2004 | 08:46 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
You probably don't need the fuel pressure switch, but from previous posts on here I would say it's a good idea and I would do it. I can't remember the exact post but a year ago or so I read about a guy that suddenly started to lose oil pressure and the OEM fuel pump/oil sender cut off the fuel and he was under a nitrous shot at the time... so he had nitrous and air going in with little fuel through the solenoids and from the injectors... not good probably.
As for the 3 switches that's just a Gone in 60 Seconds movie pun... one switch to arm the system, then a button (go baby go) on the shifter ****, then a WOT switch after that to finally get it started.
As for the negative wire I imagine you'll need to hook it to somewhere. After all we're not wiring series on car audio subwoofers.
As for the negative and positive connectors I got no idea. I've never installed or even seen a solenoid up close so take all my advice as a grain of sand.
Old Oct 27, 2004 | 09:02 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Hay dewey what relay are you using on your system??? Have any part #s??????
Old Oct 27, 2004 | 09:36 PM
JesasaurusRex's Avatar
Relays are for the rich , both noids have 2 wires. Crimp one of the two wires from each noid together. Have one pair going to ground, have another pair going to a on/off push button. Now the button u want the other open end going to a 12v source. VOILA NITROUS
Old Oct 27, 2004 | 10:35 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I just grabbed a 4 pin relay from the parts store, it was like $7.
I have a friend running without a relay also, but i just like the relay idea. That way all the draw from the noids is not going though the micro-switch. It might not be need, but for $7 it lets me sleep better.
Old Oct 27, 2004 | 10:52 PM
83 Crossfire TA's Avatar
That’s probably fine for some of the smaller setups out there, but not for some of the bigger ones. A great example is the great big honking NX solenoids… you don’t want to be running that many amps running through wiring in the passenger compartment and the activation switch. Spend the $5 and get a relay
Old Oct 28, 2004 | 05:28 AM
EvilCartman's Avatar
Car: '82 Z28
Another thing to watch for is that the solenoids actually work. On my cheater setup, the nitrous solenoid was defective and wouldn't open fully. Soon as I changed it out for a known good one, whoa baby One more thing is to have a good power source.
Old Oct 28, 2004 | 06:58 AM
twisted sanity's Avatar
Car: 1986 Z28
Engine: 305ci
the relay is there to stop the microswitch burning out, i always fit one, just incase the contacts decide to weld themselves closed one day
Old Oct 28, 2004 | 07:29 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
i would like to have a relay in between there. I get witch ever relay that is there, just to make shure that it is a 4 pin. Does it matter how many amps relay it is?
Old Oct 28, 2004 | 07:33 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I'm at work, so I can't tell you the amperage on my relay. But you need to figure you need more than the noid draw. Then the inline fuse, should blow if you draw too much. You might need to contact NOS to get the amp draw of your noids. then you figure what relay you need, and what fuse to run.
Old Oct 28, 2004 | 07:42 AM
Car: 1986 Z28
Engine: 305ci
cheap n nasty one form a shop, probably about $5- solenoids the ones we supply with kits are 40a, usually used for wiring up fogs or spots
Old Oct 28, 2004 | 07:45 AM
Dewey316's Avatar
Car: 1990 Camaro RS
edited:
Yeah, 40a should be find, the fuse would blow long before you could do anything to the relay.
Old Oct 28, 2004 | 07:49 AM
Car: 1986 Z28
Engine: 305ci
most solenoids draw less than 10a, its just that 40a relays are a lot more common and a lot cheaper:lala:
Old Oct 28, 2004 | 07:50 AM
Dewey316's Avatar
Car: 1990 Camaro RS
lol, I had just edited my post while you posted that. I re-read it, and realised you were talking about the amperage of the relay, not noids.
Old Oct 28, 2004 | 07:52 PM
biggtime's Avatar
I always put the full throttle switch between the relay and ground. JMO
Old Oct 28, 2004 | 08:54 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Well i went to the parts store today and looked at the relays. I saw a 4 pin relay that was used for a flasher and had some markings that were: c
l2
I think it was something like that. Is that the one? If so what wire goes were?
Old Oct 28, 2004 | 09:38 PM
Car: 1986 Z28
Engine: 305ci
the microswitch can still melt even if your switching earth so u still need the relay, and the flasher one will have an inbuilt flasher unit, i will try and get the details/pt no for a relat and post it later guys
regards
paul
Old Oct 28, 2004 | 09:57 PM
biggtime's Avatar
One more thing i forgot, The hobbs switch cannot handle load either, this is how I wire them with relays. (on fogger systems we wire them the same way but use a continous duty solenoid instead of the relay).
Potter Brumfield/tyco 40 amp relay #VF4-45F11
bosh relays use the same tab numbers
Relay #86 tab, full throttle switch, hobbs switch (if used), then ground.
Relay #85 tab, 12volt+ from arming swich, (should get its power from a key on power source)
Relay #30 tab, 12 volt 40 amp fused supply (usually direct from bat or solenoid )
Relay #87 tab, to nitrous solenoids
Other wires from solenoids go direct to ground.
Old Oct 28, 2004 | 11:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
FWIW,
my relay is part number
V520-40 it also shows TWV520-40 and AR-401 , it is only a 30amp
85 - ground
86 - +12v from switch
87 - +12v from Battery
30/51 - noids
Old Oct 29, 2004 | 02:05 AM
Car: 1986 Z28
Engine: 305ci
saves me journey- what's a hobbs switch when its at home guys?
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 17, 2015 02:52 PM
