X-Mas Came Late!!
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
X-Mas Came Late!!
Look what came in the mail!!!!
I am going to run C4 HD 13inch setup in the front and a LS1 rear setup in the rear. (You may notice that the rotors on the left are LS1 Fronts not rears, they will be exchanged)
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Did those Raybestos calipers come loaded with ALL the hardware? I'm looking into doing a rear PBR conversion. I have all used calipers with backing plates, but I'm not sure if I'm missing anything or not. I'm considering either Cardone or Raybestos.
Car: 1989 Iroc-Z
The LS1 rear calipers came with pads, hardware and caliper carrier.
Slow, let me know if you think you're missing anything, I have a few parts calipers on hand just in case.
Ed
Ed
Car: 86 Iroc-Z28
Engine: FB385
I know this may be a tall order, but could you list the part# either on here or via email for me? I want to use LS1 reas and the C4 13"s up front as well. I just got my car on the road two weeks ago and before summer comes I want the suspension to be done. I am looking to do this in the next couple of weeks. I know I have talked with you about brakes before Ed, so if you are still willing to help me out that would be cool. Thanks for any additional info guys. Later
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Good setup, just like mine cept I got the GS calipers and plain solid rotors
Now if I could just find the time to install them
Car: 1989 Iroc-Z
86IROCNJ,
I am working on a comprehensive part number list I'll have it posted in a few days.
KagA152,
All the parts are Raybestos brand are very competitively priced. I don't know the cost exactly because it was all a Christmas present from relative who works in the business. A good place to get parts for a good price is www.rockauto.com
KagA152,
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
hmmm, i didnt know raybestos made drilled/slotted rotors. i was wanted to get some for my setup (same as yours) but was kind of weary of the majority of the no name brands because ive heard they like to crack. $70 a rotor seems very reasonable to me
Car: 86 Iroc-Z28
Engine: FB385
Thanks a lot 89 Iroc Z, I did a few searches and found a handfull of threads where you and Ed had found that these 13" C4 HD brakes would work, but there was no specific parts to go by. I have a good idea of what all is needed but part#s would be great. The rotors you have there look to be of pretty good quality. I was thinking of going with Eradispeed rotors but I might as well just buy a whole brake kit from Baer for what they want for those rotors. Like I said, your setup is exactly what I had in mind instead of purchasing Baer's front and rear kits. For the most part these are the same/similar. Do you plan on using an adj. prop valve with this setup? Later
Car: 1989 Iroc-Z
Here are the part numbers for the C4 front brakes. Don't worry I will update it to fill in some blanks and to add the LS1 rear brake part numbers. But this is a good start.
Scroll wayyy down, for some reason this forum software puts a huge gap in.
<TABLE FRAME=BOX CELLSPACING=0 COLS=7 RULES=GROUPS BORDER=1>
<COLGROUP><COL WIDTH=257></COLGROUP>
<COLGROUP><COL WIDTH=31></COLGROUP>
<COLGROUP><COL WIDTH=72></COLGROUP>
<COLGROUP><COL WIDTH=80></COLGROUP>
<COLGROUP><COL WIDTH=119></COLGROUP>
<COLGROUP><COL WIDTH=146></COLGROUP>
<COLGROUP><COL WIDTH=252></COLGROUP>
<TBODY>
<TR>
<TD WIDTH=257 HEIGHT=34 ALIGN=CENTER VALIGN=MIDDLE><B> </B></TD>
<TD WIDTH=31 ALIGN=CENTER VALIGN=MIDDLE><B>Qty.</B></TD>
<TD WIDTH=72 ALIGN=CENTER VALIGN=MIDDLE><B>GM Part #</B></TD>
<TD WIDTH=80 ALIGN=CENTER VALIGN=MIDDLE><B>AC-Delco #</B></TD>
<TD WIDTH=119 ALIGN=CENTER VALIGN=MIDDLE><B>Raybestos Part # OEM Grade</B></TD>
<TD WIDTH=146 ALIGN=CENTER VALIGN=MIDDLE><B>Raybestos Part # High Preformance</B></TD>
<TD WIDTH=252 ALIGN=CENTER VALIGN=MIDDLE><B>Comments</B></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=34 ALIGN=CENTER VALIGN=MIDDLE><B>1989-1994 12-Inch Front C4 Corvette Setup</B></TD>
<TD COLSPAN=6 ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1> </FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Caliper (JL9)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>1</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12520229</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>172-2139</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>RC4286 / RWC4286</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1> </FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Caliper (JL9)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12520230</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>172-2140</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>RC4285 / RWC4285</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Caliper Carrier (JL9)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10181205</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Caliper Carrier (JL9)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10181206</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Rotor (JL9)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>2</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10097654</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>177-684</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>55997</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>BR55997L / BR55997R</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=34 ALIGN=CENTER VALIGN=MIDDLE><B>1989-1996 13-Inch Front C4 HD Corvette Setup</B></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Caliper (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12520231</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>172-2141</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>RC11226</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Caliper (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12520232</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>172-2142</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>RC11225</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>OR you can use GS caliper</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1> <BR> </FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Caliper (GS)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12528689</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Caliper (GS)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12528690</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE> </TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Caliper Carrier (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10181207</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Caliper Carrier (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10181208</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Left Rotor (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10052203</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>177-678</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>56494</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>BR56494L</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Right Rotor (J55)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>10052204</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>177-679</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>56495</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>BR56495R</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>1LE rotor (For Hub)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>5994</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>Used to make hub to mount C4 HD rotor</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE><B>Parts For Both Setups</B></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Brake Pads (Standard)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12518935</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1> 171-735</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>PGD412M</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Brake Pads (Preformance)</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>12480043</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>BD412M</FONT></TD>
</TR>
</TBODY>
<TBODY>
<TR>
<TD HEIGHT=17 ALIGN=CENTER VALIGN=MIDDLE>Caliper Bolt</TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>4</FONT></TD>
<TD ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=1>??</FONT></TD>
</TR>
</TBODY>
</TABLE>
Edit: Table is back up, I had to use open office because Microsoft excel sucks at outputing HTML.
Last updated: 02-23-2005, More updates to come
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
<TBODY>
<TR>
</TR>
</TBODY>
</TABLE>
Car: 91 RS
Are these calipers about the same as the 1LE units? Would the C4HD rotor work with the 1LE caliper and carrier if one fabs the correct adapter bracket. Has this been done before? This would be basically to upgrade the 1LE setup to 13" rotors. And of course hubs would have to be made.
Thanks DM
Thanks DM
Thanks DM
Thanks DM
Ed
Car: 91 RS
Originally posted by ebmiller88
IMO, that's really a LOT of work for not much of a difference. Yes the calipers will work but if you want to use 1LE carriers, you'll have to make a whole new bracket for it and then figure out the dimentions with the added space of the hub. Why not just use the HD setup with the 1LE caliper and go from there? IMO it's just not that efficient for you to do all that work when the setups already figured out.
Ed
Ed
So to make the 13" rotor work I would need: rotors, hubs, caliper carriers and carrier to spindle brackets.
Thanks DM
Car: 91 RS
Thanks again Ed. I guess in retrospect I was more interested in if the calipers had the same power and if the only differance was in the rotor diameter. I remember seeing an upgrade years ago in Baer's catalog for a 12" 1LE to 13" brake upgrade and I think it only involved rotors and brackets.
Probably so, and honestly not worth it. You won't see much difference at all going from 12" to 13".
dimented24x7
Sep 6, 2015 03:51 PM
If I'm around when you're installing them call me if you could use an extra hand.
