4th gen A pillar fits!
Old Feb 25, 2005 | 10:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive thought about it for 3 days, and been staring at them all evening. hacked, cut, grinded, and dremeled my way.
they will work. just need to find a good spot for some black trim screws to mount them. im going to cut down my dash pad, and i should be close to being rolling again.
wish me luck. im gonna try my best to make it to the local cruise in tomorrow night.
yeeeehaawww!
Old Feb 25, 2005 | 11:14 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i want pics because i plan on doing this also....
Old Feb 25, 2005 | 11:29 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i didnt take a before and after pic, but ill post some up the 1st of the week.
Old Feb 26, 2005 | 09:06 AM
FastElectrics's Avatar
Car: 89 Camaro RS
question.. why use a 4th gen a-pillar.. whats wrong with the one that goes there?
Old Feb 26, 2005 | 09:21 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
2002 dash. everyone that does the conversion doesnt use this piece, AFAIK. a few people have made filler plates, but i wanted a different look.
Old Feb 26, 2005 | 11:42 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
can't use stock 3rd gen pillars, as there's a gap left between the pillar and the dash. The 4th gen unit has essentially the same curvature, and will fit in, modification must be made to the base of unit, cut to the contour of the dash and made to fit, the angle at the top sometimes needs some minor re-working too. I know this only cause i was working on the same thing about 4 months ago, proved that it was going to be easier than i intially thought, its not a direct swap, but neither was the 4th gen dash in the first place, i would have shared the info, but wanted to be the first. jk. actually i just didn't think about it.
Another key note, the problem area is viewed from the outside of the car, while the angle will match up close enough, there's a gap on the side where the window would meet up with the pillar, if you look from that side, you can see behind the pillar and see the steel support. luckily, my cars black, so the metal behind is black also, doesn't stand out like crazy. But it could depending on what color your car is.
i.e white.
Old Feb 26, 2005 | 12:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
you are abosolutely correct about the gap from the outside. im either gonna use some universal door weather strip, or im going to use my stock trunk seal, becuase i replaced mine a while back when the car was painted.
i think a seal will cover this gap nice.
try it out.
dash pad is now cut and looks factory.
im off to the parts house.
Old Feb 26, 2005 | 03:44 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Good to hear they fit. Been meaning to pick up a pair for the last few months, as thats the last thing that needs to be done for my dash install to be complete.
Wouldn't matter about that gap for me. I alreay have that gap with my stock A pillars for some reason. Its like a 1/2" space and the cars blue so its very noticeable. Maybe the 4thgen Pillars will actually be an improvement for me.
Old Feb 26, 2005 | 05:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
they fit, but dont forget i have about 3 hours of mods to them. i have some wheelwell clips holding them in where the 3rd gen a pillar would "slide" on. there is an inch gap in the rear, which i cut the 3rd gen a pillar and filled the hole.
its starting to look pimp. i may be finished with it tomorrow.
Old Feb 27, 2005 | 01:11 AM
Car: 89 Camaro RS
ok, thankyou.. that make 100% sense.. So thats very cool then that you got it to fit.
Old Feb 28, 2005 | 10:57 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
porkchop sammiches, show da pics!
Old Mar 2, 2005 | 11:58 AM
EriksonFL's Avatar
Car: 92 Camaro
Transmission: 700 R4
I second that
Old Mar 2, 2005 | 04:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
you guys wont believe how well they fit after roughing them up with a dremel.
i used some universal weatherstrip to fill the gap. it ALMOST looks factory.
been workin too much lately. havent even driven it since i put the dash in. hopefully ill get some time off tomorrow or friday.
Old Mar 30, 2005 | 12:24 AM
86BluePearlIroc's Avatar
Car: 86' Iroc-Z
Transmission: stock w/ B&M Stage 2 shift kit
Can i see a picture please, i have been trying to fit mine one for a while now, could you also let me know if your dash pad fits nicely, mine keeps popping up, i need to figure out another way to keep it down and flush with something other than velcor
Old Mar 30, 2005 | 10:36 AM
Faded's Avatar
Car: '91 Firebird
I grabbed some from the junkyard last week. I held them up to a trashed 3rd gen's A pillar with no dash and they do look like very close match.
Old Feb 8, 2006 | 02:57 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
how about some pics?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
cam-mike
Aug 24, 2015 07:23 AM
