Look what i did to my car
Old Mar 10, 2005 | 08:39 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Heres what it looked like before
Heres what it looks like now
Old Mar 10, 2005 | 08:44 PM
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
uhm...is that backwards? or is there some other purpose?
Old Mar 10, 2005 | 08:45 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
dash swap?
Old Mar 10, 2005 | 09:03 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Nah im just changing the whole interior to black and installing this
Old Mar 10, 2005 | 09:05 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Its been a major pita i started at the back of the car and worked my way forward pulling everything out and putting it back in. But it will be well worth it in the end everything will be tip top.
Old Mar 10, 2005 | 09:08 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Heres a couple of othe pictures of my progress.
Old Mar 10, 2005 | 09:10 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Im still adding black leather seats,new steering wheel im buying the grant elite and black seatbelts.
Old Mar 11, 2005 | 01:13 AM
stitchop's Avatar
Car: 91 firebird
Love those door panels, they have such a clean look compared to mine. Also the grant elite looks awesome in a 3rd Gen. keep us posted.
Old Mar 11, 2005 | 03:27 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
I had the dash out on my '84 T/A last fall. Fixed a lot of rattles and I found some screws that weren't tightened from the factory. 1980's build quality!
Whats that metal box behind the map pocket on the dash? Did your car come with the factory amp and sub-woofers in the quarter panels? Thats a pretty rare option.
Old Mar 11, 2005 | 03:39 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Yes it has the factory amp but i havent seen any subwoofers. On the dash it has a gain control **** with a button next to it. When i bought the car it already had a aftermarket radio installed and he had disconnected the factory amp.
Old Mar 11, 2005 | 04:24 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Man my car must have been a blast from the factory. It was ordered with 305 TPI, 5speed,TTops,WS6 package,Performance sound package,no power anything bare bones but with the deluxe interior. Also my car was originally silver not black which i dont see very many silver thirdgen formulas.
Old Mar 11, 2005 | 07:19 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Are you painting anything such as the arm rests/door panels or replacing them with black ones? I'm curious how long the paint last if it is in fact painted.
Old Mar 11, 2005 | 07:38 AM
lxcamaroxl's Avatar
Car: 92 Camaro (R)eally(S)tock
Transmission: Auto 700r4
Siiiiick
Old Mar 11, 2005 | 09:55 AM
colonboy14's Avatar
Car: Trans Am
Are you getting rid of that 5 speed shift plate?
Old Mar 11, 2005 | 02:48 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I used dye on everything. The 5speed plate is getting sold with the complete console.
Old Mar 13, 2005 | 10:55 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Ok im finished except for the steering wheel,shifter boot, and i got a set of pedals that i will be adding.
Heres before pics
Old Mar 13, 2005 | 10:57 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
And here are the after pics
Old Mar 13, 2005 | 11:10 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
nice.. hopefully you can get us some non-blurry shots :P
good job
Old Mar 13, 2005 | 11:12 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I have more pictures here the batteries were running low thats why its blurry some of them are some them arent. http://www.cardomain.com/memberpage/654826/12
Old Mar 15, 2005 | 05:13 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Heres a couple that are not blurry.
Old Mar 15, 2005 | 06:26 AM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Looks great!! You did an excellent job. Definitely looks slick in black!
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Also took some outside pics when i took the interior pics might as well ***** up my own thread.
Old Mar 15, 2005 | 11:22 AM
Stevo's Avatar
Car: Pair of 92 Z28s
how exactly do you dye your interior?
Like is there a certain product you used?
Old Mar 15, 2005 | 12:18 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Wow!!.......that looks great! Is that new carpet? If so, where did you get it from? It is looking awesome!
-Justin S.
Old Mar 15, 2005 | 08:20 PM
Sonar_un's Avatar
Car: '86 T/A
looks great in its non-blurryness!
Old Mar 15, 2005 | 09:05 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
My T/A also has the factory radio w/subwoofers. The subs are POS "Bostwick's" on a 5" size. The amp and slider only seem to work with the stock head unit. When I put in an aftermarket head unit, using the same wires, the subs would not work.
I want to replace the subs with some new ones, but cant find any on a 5" platform.
Jim.
Old Mar 15, 2005 | 11:01 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
There was another thread about the amp and subs. They said they are actually 5 1/4 inch and not 5. You can find the 5 1/4 inch just about anywhere. Heres the link to the other thread where they were talking about it. https://www.thirdgen.org/techbb2/sho...hreadid=264126
Old Mar 16, 2005 | 01:42 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
did you use the fabric and vinyl dye stuff to dye it? What did you use?
Old Mar 16, 2005 | 01:49 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I used Dupli Color Vinyl and Fabric Dye on the door panels and,center console door,map pocket and the carpet. Then i used Krylon Fusion for all the plastic pieces in the interior. And i used bottle of wax & grease remover to prep everything. Word of advice dont try to dye the shifter boot it didnt work worth a crap.
Old Mar 16, 2005 | 05:25 AM
CrazyHawaiian's Avatar
Car: too many ...
Those door panels are so much better than the Camaro ones ...
Old Mar 16, 2005 | 01:47 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
are you happy with how the carpet turned out when you dyed it? I've been thinking of changing my carpet to black....
Old Mar 16, 2005 | 05:05 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The carpet looks good you just have to do several coats and let it dry in between to let it soak in. Also i recommend getting one of the little nail brushes they sale at auto parts stores and using that to brush the carpet while you are dying it. Spray a lil brush a lil. I didnt brush it while i was doing it and it got stiff.
Old Mar 16, 2005 | 05:56 PM
laiky's Avatar
That looks Awesome!!
i think i would like a black interior, how is the dye holding up? i'm curious how the rug, vinly and plastic will look after some wear and tear. That looks so much better than my blue interior!
Old Mar 16, 2005 | 06:35 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Dont know its only been a week still looks good. The way i figured is it was a pita to do the whole interior at once. But if one piece has a problem its an easy fix to do just one thing.
Old Mar 21, 2005 | 03:12 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
alright, no one else has asked, so I guess I might not be paying attention.
Why are all of your panels so rich and glossy. I have used the duplicolor on another car, and it did not come out like that.
I see you used the krylon on the plastic pieces. Did that come out that rich from the paint, or do you have it heavily armor alled, or whatever.
The reason I asked, is that I have just aquired a black interrior parts car, but they are all covered in carpet. I don't know why. I would rather just dye my current panels black, if they would look as good as yours.
on a side note, anyone ever think about sanding the grain off of the panels. I did it on an extra piece I have, and I think it would look cool. Kinda like the fiberglassed look.
Old Mar 21, 2005 | 04:07 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
nice job man im guessing krylon fusion the pannels look just like mine but yours a more glossy.. thats a huge shifter dude
Old Mar 21, 2005 | 05:52 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Well the 6speed console is about half the height of the 3rd gen console so it made my stock shifter a couple of inches longer. I plan to get a short throw shifter and one of the short sticks and then cut it down a little bit. Then it will be perfect.
Old Mar 22, 2005 | 04:59 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If you used the Duplicolor on the carpet, it will wear back to it's original color within a few months. Mine looks like butt right now. I'll be switching to new black carpet this spring when I take everything back out to paint her...
Old Mar 22, 2005 | 05:02 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I had the exact same problem and am solving it the exact same way. New black carpet is on its way. That Duplicolor stuff seems to work great on everything else, though.
Old Mar 22, 2005 | 05:27 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The carpet is only temporary i planed on buying new carpet this summer. Plus in the next couple of months i will porbably not even drive 500 miles in it. Its just my weekend car and it stays in the garage. I could see it becoming a problem in a daily driver.
Old Mar 25, 2005 | 04:33 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Gawd thats a purdy Formula
I'm going to do my Camaro the exact same way. Shiny black and chrome inside and out.
Old Mar 26, 2005 | 10:22 PM
so what door panels are those? Are those stock formula?
Old Mar 26, 2005 | 10:26 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
f355: Do you have power locks or manual locks? I noticed you have manual windows with the GTA-style doorpanels, which is what I'm doing as well. I also have manual locks, but I haven't seen block-off plates for the power lock switches (or door trim without the holes for the lock switches).
Attached Thumbnails Look what i did to my car-c-documents-settings-kevin
Old Mar 26, 2005 | 10:30 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Yes they are the deluxe package it was a option for formula's and GTA's. My car has manual locks and windows.
Old Mar 26, 2005 | 10:31 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Hey firebird 383 did u buy those off of ebay recently?
Old Mar 26, 2005 | 10:39 PM
GarageToys's Avatar
Originally posted by f355bird
...My car has manual locks and windows.
Can you snap a pic of your door trim for me? Is there just a blank piece of plastic that snaps-in where the power lock buttons would be?
...Hey firebird 383 did u buy those off of ebay recently?
Yes I did- from thirdgenranch (LFN AT U on the boards). They have little pockets at the bottom but I'm going to have to remove them because they'll interfere with the window crank. (They were off a power-window car and I'm going to have to cut the holes for the cranks)
Old Mar 26, 2005 | 10:51 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Here is 2 upclose pics of the covers on the door handle and this is the same both sides
At the front hole is just smooth
The back hole has the bird symbol
Old Mar 26, 2005 | 10:54 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The first time those panels came up on ebay i posted a bid and they went up to like $250 dollars and some one didnt pay so he relisted them and by that time i had already redid my panels so i didnt bother. Those panels looked really good in the picture he had.
Old Mar 26, 2005 | 11:06 PM
GarageToys's Avatar
Thanks for the pics- that's exactly what I wanted to know.
Actually, he had 2 sets of black GTA panels. I was watching that first auction where they went to $250 too. Those panels didn't have the map pockets and were actually missing the little plastic covers for the screw holes. Mine were auctioned off the next week. They were mint, included all the screw covers (and the brackets to convert from regular door panels) and for some reason only went to $103.
Old Mar 27, 2005 | 05:21 AM
Spdfrk1990's Avatar
That turned out nice. You do need a short shifter tho that thing looks like it belongs on a s10.
