Post your latest gas mileage results!
Old Mar 31, 2005 | 09:18 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
Ever since my torque converter started properly 'locking' up.. I've been getting killer gas mileage in my opinion.
the first day my TCC was activated... I got 29.5 MPG on a 100 mile trip, at a fairly constant 85mph (unless I knew a cop was coming!) -- g0d bless the rx65.
Just today, I checked it again... and I made that same trip at an average of 90... peaking at 100, and for a few minutes I drove at 75mph... this time I got 30mpg! And I'm due for an oil change...
Just wondering what kind of mileage are you guys getting now that the temperatures are warming back up!
edit: before the TCC repair, I got 15mpg max on the highway.
-Steven
Old Mar 31, 2005 | 09:20 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
10 MPG
Old Mar 31, 2005 | 10:43 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
about 400 kilometers to a tank of gas = 245 miles
Old Mar 31, 2005 | 10:46 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I get like 8 - 10mpg, what was wrong with your torque converter? How did you fix it? I really want to get a little bit better milage outta my car.
Old Mar 31, 2005 | 11:08 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I get about 15-18. Blame it on the crappy Calif oxygenated fuels and 91octane max.
we have 87,89, and 91.
How about gas prices right now?
I just filled up today and it was $2.71 per gallon for 91 oct. *87 looks to be around $2.50 average per gallon in So Calif.
I'm heading out to Parker, AZ next week with my truck and am curious how much better mileage I will get coming home with Arizona fuel
Old Mar 31, 2005 | 11:13 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
10mpg in mine (on a good day) when foot isnt on floor
Old Mar 31, 2005 | 11:27 PM
ScrapMaker's Avatar
my torque converter had never locked up, the entire time I had driven my car... I just thought that 15mpg was the normal mileage..
I would be at 2500-3000rpm on the highway... but now that the TCC locks up, I'm at 2000 even at 80mph....
my steering column wiring, or something under the dash was screwed up. when I had my steering column replaced, it came with a new wiring harness for the column, and somehow that fixed my TCC AND my cruise control at the same time... pretty good improvement...
so for $200 I got a new turn signal mechanism (not the actual switch--just the part that interfaces with the column, and also allows me to engage the brights)... I also got a junkyard column installed, plus the cruise control and TCC to work... pretty good, huh?
that $200 investment has by accident already saved me $200 in the few months that I've had my car back...
I go through 3-4 tanks a week. and I drive back and forth from Waco to Austin every week, a 105 mile drive... I only use 3.5 gallons of gas to drive there... so 7 gallons there and back... at 80+mph of course!
if my tank is 12 gallons, I have a 360 mile range at 80mph.
if my tank is 14 gallons, I have a 420 mile range at 80mph.
I smell gas real bad too... because I have a horrible vacuum leak...
I was messing with my hoses one day, and I caused a very bad leak, and my mileage dropped back down to 20mpg or so...
when I 'fixed' it... (its still only reading like 15 on the mityvac)... my mileage went back up to 30.
I bet if I fixed my vacuum leak completely, changed the oil, got rid of my exhaust leak, and other small tune up procedures... I could get 35 mpg...
also if I drove 40 mph (that's optimum driving effenciency,) I could probably get much, much more mileage... but I'll never drive that slow... never!
Old Apr 1, 2005 | 12:35 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
My mileage has dropped slightly since my 33.6 bragging some months ago. the exhaust leak is louder, winter fuel, etc.
I'm heading back to Ft bliss Monday and from there to Iraq. When I get back I'll be doing some work on it. Headers, 3.4, newer tranny, roller rockers, so on and so on.
Old Apr 1, 2005 | 04:54 AM
Car: IROC Z
Engine: 5.7
gas here is 89.9 for 1 litre over 1$ for premium
Old Apr 1, 2005 | 09:30 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Originally posted by RTFC
I get about 15-18.
That's all you get Dean? I get ~270 miles per 12 gal fill up. If I spend all my time on the freeway, I get just shy of 400 for a tank. Last time I went out to AZ, I got 32 mpg on the tank that I got when I left home in SF valley.
If I remember right though, you have some small mods done, right?
Old Apr 1, 2005 | 09:44 AM
RedTtop5spd's Avatar
Car: 99 SS
I use about a tank a week doing two 40 minute drives and the rest of it short trips. I'm averaging 29 miles per gallon.
Old Apr 1, 2005 | 11:15 AM
Doward's Avatar
I haven't had the Camaro out much - but with the new WB02, I'll be getting some decent cruise mileage - ESPECIALLY with the .63 Overdrive V8 WC T5
Wheras 70mph used to be around 2400-2500rpm, now it'll be around 2000 rpm. A solid 500rpm drop in cruise rpm will be nice on the free way
Old Apr 1, 2005 | 02:16 PM
wpaskar's Avatar
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
My car gets pretty trashy milage...both from my driving style and the things wrong with the car. I call it "sporty" driving...I am always the first person off the line at red lights and I just like the sound of a floored engine. Once I fix my exhaust manifold as well as complete some other engine repair, I expect that to go up a bit...right now I drive about 300+ km on a tank
Old Apr 1, 2005 | 02:37 PM
ScrapMaker's Avatar
a 5 speed runs at 2500rpm at 70??
in my auto, at 75-80mph, I'm right at 2000 rpm...
Old Apr 2, 2005 | 01:18 PM
1slow8t3's Avatar
Car: 83 v6 firebird
Engine: None right now
Transmission: none right now
Axle/Gears: 3.08 one tire fire
not sure how many mpg's it is but last weekend I got 504 km's to the tank! usally average 400-450kms/tank
Old Apr 2, 2005 | 01:58 PM
ScrapMaker's Avatar
227 miles = 500km
Old Apr 2, 2005 | 03:30 PM
Car: IROC Z
Engine: 5.7
i think this is right
100km=63 miles
63miles*1.63=100km
110mph=180kmph (look at your speedo)
110*1.63=180kmph
227miles*1.63 =370 kms
504km/1.63 = 309 miles
Old Apr 2, 2005 | 04:18 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
It mostly my driving habits also. My foot is always into this thing even with 3.23's on the highway. If I do cruise out somewhere for a distance (Like from Orange Co. to Calif Speedway- about 40 miles each way) I will go through at least a half a tank of fuel. But I am also doing at times 125+. There are some wide open stretches there on early weekend mornings with no cars around.
It 'probably' gets more like about 20-22 when the wife and daughter are in the car with me, but I am still doing about 80. 90% of the miles on this car are my wife running around town at speeds under 40mph.
Old Apr 2, 2005 | 05:01 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I'm getting about 7.5km/L (~17.5mi/gal) consistently doing 90-95% city driving and laying on the gas pretty hard.
Gas right now, here, is peaking at CAD$1/L (~USD$3.12/gal) for regular.
Old Apr 2, 2005 | 07:37 PM
1slow8t3's Avatar
Car: 83 v6 firebird
100km=63 miles
63miles*1.63=100km
110*1.63=180kmph
I was rhinking of doing that but I diden't want to rin out to the car to check! I am hoping the it gets a little bit better when I do the fuel injection swap on it!
Old Apr 2, 2005 | 09:36 PM
ScrapMaker's Avatar
for some reason I thought a mile was 2.2 kilometers...
my bad
Old Apr 3, 2005 | 12:18 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Lets see then..
I've done 226kph in the Camaro. (15-20 mpg)
231.5kph in the truck (8-12mpg)
248 kph on a bike (? mpg)
270kph in the Vette (3-5 mpg, @ $5 per gallon-this car is very expensive to drive)
I like the Canadian system, It sounds much more impressive
Old Apr 3, 2005 | 12:25 AM
Yeah, but when it's 80 degrees in the US, it only 26.5 degrees in Canada. It's unbearably cold.
Old Apr 3, 2005 | 12:44 AM
Ovrclck350's Avatar
24.3 MPG HWY with the Targa top ON
20.2 MPG HWY with the Targa top off
16.7 MPG City mixed.
Of course, my car tells me instantly how many MPG I'm getting
Old Apr 3, 2005 | 12:48 AM
ScrapMaker's Avatar
a vacuum sensor?
Old Apr 3, 2005 | 01:00 AM
Ovrclck350's Avatar
Originally posted by ScrapMaker
a vacuum sensor?
Old Apr 3, 2005 | 01:15 AM
ScrapMaker's Avatar
as far as I know... the only way gas mileage information is obtained is through vacuum sensor, and a computer...
Old Apr 3, 2005 | 01:18 AM
How about a couple of flow meters (feed and return) and an odometer?
Old Apr 3, 2005 | 01:22 AM
Ovrclck350's Avatar
The ECM calculates how much fuel flow based upon throttle position, RPM, Vacuum, the injector constants, and speed. It also counts how much time you spend at each "INSTANT MPG" which it calculates about 6 times/second.
This is in my car BTW.
And here's a pic of INSTANT MPG...kinda blurry, and I was about 1/2 down on the throttle.
Old Apr 3, 2005 | 01:58 AM
ScrapMaker's Avatar
gotcha...
its weird how some cars run so hot...
most cars don't ever get over 200F but if I let my bird sit for about 10 minutes, it easily hits the 230 fan switch
Old Apr 3, 2005 | 04:09 AM
Ovrclck350's Avatar
gotcha...
Yah, that was after I had let mine sit for 15 minutes on a 100 degree day.
Old Apr 3, 2005 | 07:26 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Ya, my 5 speed runs 2800 RPM at 80, I have a WinALDL Screenshot of that
You guys are making me want to fix the camaro even more than I already did. I get like 8-10.75mpg in my truck
Old Apr 3, 2005 | 12:27 PM
ScrapMaker's Avatar
hey, how hard is it to make that cable? is it just straight wires from the ALDL port, to the serial port on a pc/laptop? (obviously you'd have to wire correctly...) but are there any capacitors, resistors, etc, needed to make this cable?
then you just run winALDL on your pc, and bam!? you have all that info?
can you get all the sensor readings that you can get from a good scantool? it would rock to hook up a laptop and troubleshoot while driving.
Old Apr 3, 2005 | 02:04 PM
Car: 95 Z28
ya, you can do everything you just said I can upload a screenshot later but its on my laptop. I actually just bought the moates USB cable from him www.moates.net needs part ALDL1 and USB something. 2 part cable. just get the OBDI thing and the USB adapter.
Old Apr 3, 2005 | 02:31 PM
Ovrclck350's Avatar
http://www.akmcables.com/assembly.htm
Old Apr 3, 2005 | 02:59 PM
Car: 99 SS
It's real easy to build the cable. It does help with diagnosing, keeping your car running good, and getting good gas mileage.
Old Apr 3, 2005 | 03:43 PM
ScrapMaker's Avatar
so you can access the same things as a scantool can?
does it have "suggested" values for sensors, or will I have to find them on the net?
Old Apr 3, 2005 | 03:48 PM
ScrapMaker's Avatar
hrm anyone know if winaldl will work with my car?
I can't find a 1990 3.1 on here... but I see other 3.1s will this work?
compatibility list
Old Apr 3, 2005 | 03:58 PM
Car: 95 Z28
Probally, I got it to work on a 91 Blazer. You just go through the ECMs till the 25 or whatever number up top starts blinking green, if it blinks red its not the right one.
I noticed my idle was lower with it plugged in though, and made my friends car stall out cause the Idle dropped a lot
Old Apr 3, 2005 | 04:00 PM
Car: 95 Z28
Here are screenshots of when I had my cable. Notice the Speed
Good Ratio
Old Apr 3, 2005 | 04:01 PM
Car: 95 Z28
Good Ratio. SOrry for so many posts, the attachment thin wasnt cooperating
Old Apr 3, 2005 | 04:17 PM
ScrapMaker's Avatar
can winald graph speed or record stuff over time?
Old Apr 3, 2005 | 05:07 PM
Car: 95 Z28
Ya, it can datalog. I couldnt get it to open in Excel, but I've seen people do it
Old Apr 3, 2005 | 05:46 PM
Car: 99 SS
You can save the data and then open it in excel. I've done it a few times. Just remember what all you were doing at various times with the saved data and plot values against time so you know what's going on when you do different things.
Old Apr 3, 2005 | 05:52 PM
Car: 95 Z28
I always got an error when trying to open my logs in Excel :shrug: It wasnt the right format by default
Old Apr 3, 2005 | 06:15 PM
ScrapMaker's Avatar
hrm I've seen some ALDL programs that even graph over time... I wonder if there are any besides winALDL that are free?
Old Apr 3, 2005 | 06:16 PM
Car: 99 SS
To open in Excel, open Excel and find the file you want to open. It'll be a text file, so you may need to click on the "files of type" and select text file or all files. Then just click next on all the message boxes that come up. That should get it open in Excel.
Old Apr 3, 2005 | 06:21 PM
Car: 95 Z28
Didnt really work for me. They "OPENED" but they were just garbled text
Old Apr 7, 2005 | 02:42 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
so far I have only went through two tanks of gas one was 31.4mpg with about 60%hwy
the other was around 32.6mpg with about the sme hwy
but that was also with the carb float set too high and the timing a little far advances so it knocked like a pig plus I kept forgetting to shift into 5th... stupid me I know
but once I get the carb worked out as well as the timing and a few other things I'm hoping for the 35's or so avg, but this was also on that stupid winterized fuel stuff
but then again I drive a honda
Old Apr 7, 2005 | 02:45 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
why are you running premium fuel?
if your car is still mostly stock and the timing still in the same possition as it came stock whats the point?
