4th gen HVAC vacuum lines
Old Apr 7, 2005 | 07:34 AM
knhghs's Avatar
Does anyone have a PHOTO of the 4th gen vacuum lines and where they attach to the 4th gen connector, or a diagram? There are 6 connection points for the vacuum lines on the 4th gen switch and they are numbered 1-6. I know which 4th gen vacuum lines connect to the 3rd gen lines. I just need to know what positions the 3rd gen lines go on the 4th gen switch.
Old Apr 7, 2005 | 08:39 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i need that info too, someone help us out, thanks...
Old Apr 7, 2005 | 10:38 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
you can find everything in a search ! i would give you the info, but its at home and i dont have it in front of me at this moment
Old Apr 7, 2005 | 12:57 PM
knhghs's Avatar
Did numerous searches. Theres nothing here that tells me what I need. All I'm looking for is a picture of the 4th gen tubes connected to the 4th gen HVAC selector.
Old Apr 7, 2005 | 01:17 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Here are the pics you need. I could not find the info either so I went out and bought the 4th gen vac hose.
1 - Orange
2 - Purple
3 - Green
4 - Yellow
5 - Red
6 - Black
Old Apr 7, 2005 | 01:47 PM
knhghs's Avatar
Thanks a million, Groundrat! That is exactly what I needed. Thank you, thank you, thank you!
Old Apr 7, 2005 | 01:53 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
im confused... thats a 4th connector right? so do we just match up the colors with the 3rd lines???? and then connect them... thanks
Old Apr 7, 2005 | 02:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
GM is really good about keeping color codes the same across models and years...
so with some luck, you can just match up the colors and it'll open the correct air doors.
Old Apr 7, 2005 | 02:36 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
thanks alot, im gonna try and make some electronic switches to replace the manual levers...
Old Apr 7, 2005 | 02:47 PM
knhghs's Avatar
Unfortunatley, I've heard the colors DONT match. Supposedly, the conversion from 3rd to 4th gen is:
3rd---------------------------4th
orange--------------------orange
tan-------------------------purple
no connection------------green
blue------------------------yellow
red-------------------------red
purple---------------------black
Old Apr 7, 2005 | 02:53 PM
groundrat's Avatar
Car: 91Z28
A good visual for you.
Old Apr 8, 2005 | 11:18 AM
knhghs's Avatar
HVAC controls work fine now. Just need to rig the temp **** to the cable. Thanks again groundrat
Old Apr 8, 2005 | 12:05 PM
Faded's Avatar
Car: '91 Firebird
I'm going to the junkyard tomorrow to pillage some more parts off the only junked fourth gen within 100 miles. =P
Anyway, where is this bi-directional valve located at behind the dash, specifically?
Old Apr 8, 2005 | 11:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That hvac diag looks familiar...
Faded.. I'm not sure on a4thgen but, other elder GM cars used on as well.
The corsica I pulled my hvac assy had on and it was located behind the radio area, against the firewall on the 'tube' that connected the floo5r ducting to the defrost ducting.
Lumina, GP, beretta (and forgetting some others) had the bi-level selector iirc.
the corsica was the only one I saw the vac servo up close and it appeared the same as whats on a 3rdgen in appearance.. aside from the extra vac line.
I'll say regardless of what you find to use.. it probably will need a 'custom' bracket of sorts to mount the servo.
The servo mod is on my mile liong 'round-to' list though...
Just my observance... could be far from reality...
Old Apr 9, 2005 | 01:24 AM
Kandied91z's Avatar
anyone know how to simply extend the lines and not have a leak?
Old Apr 9, 2005 | 08:18 PM
groundrat's Avatar
Car: 91Z28
You can get the adapters for the vac lines at you local auto parts store. They are the same ones that you would use under the hood.
Old Apr 10, 2005 | 09:22 PM
Faded's Avatar
Car: '91 Firebird
Ok I found it. Got it off a 94 Camaro.
Yes it does need a custom mont. The 3rd gen one clipped on; the 4th gen one just slides on. I cut the plastic mounts off the 3rd gen servo and JB Welded them to the 4th gen unit.
Old May 24, 2005 | 04:30 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Can someone elaborate on the green 4th gen vac line for me? What changes when the original actuator is replaced w/bi-directional one, and why would someone replace it with a bi-directional? So if this green line isn't used, does it effect anything on the 3rd gen hvac unit?
Thanks.
Casey Meyers
Mar 2, 2016 10:46 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
