Closed Loop idle with headers...
Old Apr 14, 2005 | 08:42 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I did an idle test/scan tonight in my garage, and was just looking at the data. Looks like it was staying in open loop when i was just idling, then went closed when i hit the throttle up and down. After a few seconds after that, it would go back to open loop. It did this as it was warming up as well. BLM was about 118 during idle and went upto 128 while i was reving it. Ths NB was running around .3-.4 volts, but was bouncing around nicely.
I have the NB O2 sensor in the collector, left side where the bung is when i got the headers. I put my WB right near there in the top of the Y-pipe, less than 6" from the NB location. Do you think the exhaust cools down enough to not let the NB sensor function? I am running a Bosch 1 wire factory replacement unit. I been reading about the heated 3-wire sensors, and I am leaning towards the ACdelco part. Think that would help?
Old Apr 15, 2005 | 10:16 AM
Ronny's Avatar
are the headers coated? mine are.
i am using same NB bosch you are and i have it directly behind collector in the exhaust pipe. goes CL at about 160-165 CT. my WB is mirror image in opposite pipe. if you are not using a coated header is it possible it is dissapating heat too quickly? my A/F shows lean at startup (WB) and stays lean in CL(BLMs) until the manifold is heat saturated. my OL start upA/F and choke needs some work.
Old Apr 15, 2005 | 11:19 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
on the lean warmup - Just be sure to calibrate O/L idle and such with the Air pump disconnected from the manifolds.
If the ECU sees the O2 voltage within the .35 to .55 volts range, it'll quickly detect that the sensor has cooled down and go open loop. Cooling down or overheating or bad grounding are the only things I've seen make it work and then not work like that (doubt it's overheating, and doubt it's bad grounds). Maybe poisoning or coating could cause a similar reaction.
Old Apr 15, 2005 | 11:34 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
I had to convert to a 3-wire heated AC-Delco O2 sensor to get rid of the same problem you're seeing right now. Heated sensor eliminates exactly what you're seeing!
Old Apr 15, 2005 | 01:52 PM
ULTM8Z's Avatar
Same here.
Old Apr 15, 2005 | 02:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Bosch NBs have had a known problem for years.......
Get a Delco 3 or 4 wire heated O2 sensor, and you shouldn't have any problems.
Old Apr 16, 2005 | 01:05 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Slightly off topic fellas, but had a problem with my headers and plumbed an o2 fitting on the pass side collector to run the nb o2. Could I just plumb a fitting into the driver side header to run a wb o2? is there an optimal spot for either? Thanks fellas, new to tuning, so bare with me
Will
Old Apr 16, 2005 | 07:32 PM
Car: 1988 IROC-Z
My headers have the Sterling Silver coating from Jet-Hot, they really run cool. And I dont run the AIR system at all, i kaizaned that junk when I did the header install. My Bosch O2 sensor isnt that old, I put it in about sept of 2003. when the new headers went it.
I have read some old posts about the Bosch sensors, and I been leaning towards the 3-wire heated Delco units. I think that is what my '92 S15 truck runs. Most all new vehicles running heated sensors.
Now where did I put that p/n for the AC unit.......
Old Apr 17, 2005 | 12:38 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
AFS-74 is the delco number of the 3 wire that is recommended by a few on this forum.
Old Apr 18, 2005 | 09:26 PM
Car: 1988 IROC-Z
Thanks for the number, eric. Does Advance Auto sell that unit, or will I be heading to my local GM dealer?
Old Apr 18, 2005 | 09:29 PM
eric305TPI's Avatar
I'm certain that they can get it if you ask for it. I know Hi-Lo will
Old Apr 22, 2005 | 12:05 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I bought an AC-Delco NB from a Chevy Dealer. When I opened it, it had the Bosch logo on it.
Old Apr 22, 2005 | 03:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Last month I purchased an AFS-20 one wire NB O2 from the local Chevy dealer. Has the AC/Delco trademark/logo on it. This sensor is used in a whole lot of vehicles from CCC f-body's, to EFI f-body's, to a host of other GM vehicles.
RBob.
Old Apr 22, 2005 | 05:18 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Will
You'd due best to sample both sides, ie at where ever both collectors tie together.
Or run dual WBs.
The WBs don't need to be right up by the exhaust ports. As a matter of fact mounting them back some distance, like near where the cat was, is helpful in reducing particulate matter contamination. I've run my behind where the cat was, for years now, without a problem, whereas I've heard of few failing when right up by the engine. If you get too far back, then they're be a little delay in reported AFR changes.
Old Apr 28, 2005 | 12:03 PM
BlackWidow's Avatar
Car: 1989 IROC-Z Camaro
Engine: 383 Stroker
FYI: I had the same problem when I first started scanning and was told to get a heated O2. I just bought a new Bosch and put it in. That has worked for a year and a half now. My O2 was just bad and did not know it.
Old Apr 29, 2005 | 11:50 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Alright, quick question.
I did a search of heated oxygen sensor and three-wire sensor, etc. I have found two ways to connect the 3-wire sensor.
The first one in the list says that all you need to do is connect one wire to ground, one to the ECM, and one to a 12v key in run position hot wire.
The second one has a complete relay system and getting power from the ECM. It also says that the heated part of the sensor will be disabled once the ECM finishes the ground and disables the relay, thus ending the heating cycle.
Which one is correct?
One, which can be found at:
http://sethirdgen.org/HO2S.htm
And the other which is here:
https://www.thirdgen.org/techbb2/sho...=sensor+heater
Old Apr 29, 2005 | 12:09 PM
vernw's Avatar
Both will work. The relay system just doesn't heat the NB all the time, only when the ECM thinks it needs more heat. I prefer to just have the heat on whenever the key is on/engine is running so there's no lag while it has to heat up again....
Old Apr 29, 2005 | 12:16 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
I wouldn't say either answer is wrong.
IMHO, the simple answer, "hot in start or run" is just fine. That's how GM does it on the OEM heated sensor apps I've seen. Also, the heater only draws a few mV of current, so there's no need for a separate relay.
If you want to get creative, and spend your time building a more complicated circuit, that's fine too.
Old Apr 29, 2005 | 03:58 PM
Cool, just wanted to check.
Eric2ndGen
Nov 5, 2015 01:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
DIY PROM
Aug 23, 2015 11:26 AM
beast94
DIY PROM
Aug 20, 2015 06:44 AM
IROCThe5.7L
DIY PROM
Aug 10, 2015 11:24 AM
