My 89 2.8 Failed Emissions! I have the Graph!
Old Apr 15, 2005 | 02:15 AM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
Hello,
My 89 2.8 Firebird failed Colorado Emissions today, they gave me a graph for a "Technician" to interpret. I was hoping that some one here would know what it meant and what might be causing the high HC and CO. Here are the Scans...I'll put the readings here and the graph one the next post.
Attached Thumbnails My 89 2.8 Failed Emissions! I have the Graph!-readings.jpg
Old Apr 15, 2005 | 02:24 AM
Car: 1989 Firebird
Engine: 2.8
This is the Graph:
Attached Thumbnails My 89 2.8 Failed Emissions! I have the Graph!-graphs.jpg
Old Apr 15, 2005 | 11:00 PM
trans_am_ta_84's Avatar
Car: 89 trans am
well i'm not positive on this but the only thing that does stuff with the exhaust are the 02 sensors that i'm aware of. other then that guess i have no idea.
Old Apr 15, 2005 | 11:02 PM
Car: 1989 Firebird
Engine: 2.8
I replace to O2 sensor right before the Emission Test.
Old Apr 16, 2005 | 01:03 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
how about the egr?
Old Apr 16, 2005 | 01:43 AM
Car: 1989 Firebird
Engine: 2.8
The EGR is not stuck. how can I check that it opens at the right time? I think I read that it opens when it hit 35 MPH, how am I supposed to check that?
I found a vacuum line that was disconnected. Its the line that Ts off from the Vac line that goes to the Cruise Solenoid and goes down to under the Batt. any ideas what that is supposed to be hooked up to?
Low Vacuum cases high HC doesn't it? If so why is that?
Old Apr 16, 2005 | 01:54 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Axle/Gears: 9" with 4.11's
the compy richens the mix to try to keep the engine running IIRC.
Yep, the vacuum line off will cause probs, but looks like you might need to look into a full tuneup, and maybe a new cat.
Old Apr 16, 2005 | 02:14 AM
Car: 1989 Firebird
Engine: 2.8
Im sorry but what does IIRC mean?
Old Apr 16, 2005 | 03:44 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
THe NOx would be higher if the EGR wasn't working.
Old Apr 16, 2005 | 10:55 AM
Engine: 450HP 355
If I Remember Correctly
Old Apr 17, 2005 | 11:13 PM
Car: 1989 Firebird
Engine: 2.8
would Fuel Injector cleaner cause it to fail?
Old Apr 18, 2005 | 12:53 AM
Engine: 450HP 355
not normally...
Old Apr 18, 2005 | 01:40 AM
Car: 1989 Firebird
Engine: 2.8
I was going to take the Cat off to see it was just an empty shell and its welded on.
so what I'm going to do is drill a small hole in the side and stick a pice of wire in there to see if its hollow. then I just put a screw in the hole. or replace the whole thing if its empty.
Old Apr 19, 2005 | 10:32 PM
Stephen Thomas's Avatar
Car: 84 Trans Am
Engine: 5.7 zz430
Figured I would also throw a word in or two..
you failed for high HC
and for CO which means your getting way too much fuel or not enough air... I going to guess too much gas
which from the look of the graph means he is running pig rich, but you might already have known that. trying looking thigs over with the car... are all the hoses in the right place.. esplically the one that goes to your MAP sensor.. becasue that also control how much fuel the car gets. it could be a lot of things but I'ts not releated to the egr so stop looking at that. Let me know how you make out
Old Apr 19, 2005 | 11:16 PM
Car: 1989 Firebird
Engine: 2.8
I thought it might be the MAF i'm going to check the codes to see what it says.
Old Apr 21, 2005 | 01:42 PM
Car: 1989 Firebird
Engine: 2.8
Yep the cats hallow...
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
usafirebird
Sep 29, 2015 11:58 PM
