Side Pipe
Old May 8, 2005 | 04:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Side Pipe
Thought id share my side pipe pic. Looks pretty badass IMO.
[Ignore my nasty door. It needs replaced but I painted it anyways with the rest of the car.
Sounds good, looks neat, makes it more road warrior like with everything black.]
And yes its a side pipe not pipes. I found about 4 feet of rusty pipe making the car sound like a V8 with rusted headers. I had just enough left to come up with this. I'm happy.
Need to get sound clips comparing it to my V8 car.
Very close sound, both have cherry bomb mufflers.
Old May 8, 2005 | 09:05 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
might look better once the door is replaced! LOL.... otherwise looks alright..
Old May 9, 2005 | 11:50 AM
sellmanb's Avatar
Car: '86 Berlinetta
not bad looking. I like that you didnt put some shiney chrome pipes there to draw attention to it.
I like your old school firebird decal lol
Old May 9, 2005 | 06:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea, I was hoping the door would distract from that before the flames started. I like that old school style. Its the only shiny part of the car. As you know its like those prismatic 25cent machine stickers.
Some have suggested bird logo's in the same material. But I never like the 3rd gen small birds and funky placements. Those stickers are in the same spot as the factory name plates.
[rims use to be chrome but are matte black now.]
Old Oct 18, 2005 | 12:43 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I normally hate side pipes, but after realising how much of a pain in the *** doing my exaust is going to be (not to mention expensive) i'd actually concider them. And this pic makes them look real good. And i would have to black them out too. All black car, definately no chrome.
Old Oct 19, 2005 | 01:59 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Dude, run them out that hole in the door! Sorry, not trying to be mean, I just couldn't resist. Luckily, my doors aren't rusty, but I just got done spending 2 weeks sanding and repainting my underbody due to rust. There are several spots that rusted through, so I'm going to have to take the interior out and cut some sections out to replace. I live in Texas, so this is my first experience with rust and I can say that I'm not a big fan of it. Death to rust! I had thought about doing a similar exhaust setup, but doesn't the floor pan drop down pretty low right where yours exits?
Old Oct 24, 2005 | 07:20 PM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
do you have any under the car shots of how you ran it where you mounted it and whatnot i plan on doing the same thing i was looking for some inspiration
Old Oct 25, 2005 | 11:34 AM
ckeene502's Avatar
thats how i wanted mine to turn out!!!! show some under side pics!!!
Old Oct 25, 2005 | 02:37 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Transmission: TH350 3200 stall
Axle/Gears: 4.10's
my side exit's
Old Oct 27, 2005 | 02:59 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Looks good ^^^. I just wish you couldn't see it so much from the side of the car. I am going to do that, but try to tuck it up in the tunnel. Then quickly out and muffl it all with oval pipes and muffflers. We will see.
Old Oct 27, 2005 | 04:51 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
If you can find a better way of routing them more power to ya. The reason why you can see the pipes so well in that picture is because I took them from ground level. When you are standing tho you can only see the 6in. that come out in front of the back rubbers. I'd like to see some pics when you're done with them. You'll love the sound.
Old Oct 27, 2005 | 11:48 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
never mind read it again and realized that you used your existing exhaust to one side pipe
i think it looks nice though
gotta love the sound
have fun with it man
Old Dec 10, 2005 | 09:29 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
What about fit ? attached right behind the cat converter ?
I had to cut my exhaust and need to do something about it, was looking underneath the car, but not sure whether a single cherry bomb or purple hornies would fit behind the cat converter ?
Old Dec 14, 2005 | 06:08 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Love the side pipes, looks old school. Was trying to figure out how to run and if they had pipes in Whitney. Danm nice car, dont take pics of passager side again and stay in the far right hand lane.
Old Dec 30, 2005 | 01:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Lots of questions to answer, sorry for not checkin in sooner.
There is just enough room for the pipe to run in that grove between the floor pan and body. Like a tiny vally but it runs right down the side of the car. But yea, there isn't much room under these cars.
Old Dec 30, 2005 | 01:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Only mount I used was a rear rubber clamp on strap exhaust pipe hanger. Just welded it on and used a GM body bolt and ran it into the floor pan to hold it up tight to the body.
I don't have a cat. It you have a cat it will probaby be a tight fit but there should be enough room. Though you will need to cut the cat off then re-angle the pipe. The stock system has a bend that jets everything towards the middle. Well to run it straight down the side........ the pipe must aim down the side first.
Only thing I had a problem with at first was the hi rpm flow. The dual turn out tips didn't flow well enough. So I cut the end of the pipe so the exhaust can shoot out straight at the tire and out the side. Most of it comes out the side but knockin that hole in the end free'ed up the higher rpm feel.
It will rev fast and hard to red line.
camera is off in vegas, I will get pics.
Old Dec 30, 2005 | 01:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh and in that pic I kinda show how the Y pipe is really two pipes in one. When you cut the bend off to run it straight, you will find this out too. Strange.........
red line is the cut spot, from green line to green line was rusted. But strange rust where it was only on the very top of the pipe. From under the car the pipe looked solid and good. But all alone the top it rusted out, like down the seam.
Old Dec 31, 2005 | 12:11 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
loooks nice, you do it your self?
Old Dec 31, 2005 | 01:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yep, just need a welder and you will find yourselfing doing all kinds of projects. takes some time to learn and get brake to just do it. but will be the best $300 you will ever spend. will save you mucho loot as you can now do most anything, you cant afford to pay to have done.
$20 cut off grinder helps but a $3 hacksaw will do.
no way I could of done it so easy and kinda cheap without a welder. would need 30 adapters n clamps a plenty. Was able to weld 90% of it off the car.
Old Oct 17, 2006 | 12:26 AM
83 Crossfire TA's Avatar
Do you have pics of it from farther away?
What diameter are the pipes you used?
Old Oct 18, 2006 | 01:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
just stock 2-1/2 2-1/4 pipe
FYI Everyone: The end of the pipe is also open. Thought 2 turn out would be enough but it was killing my upper RPM flow. It wasn't bad but it didn't rev as fast in the higher range. So the end of the pipe was also opened and all was well.
So build one with 3 turn outs so ya don't yell at me.
How far away? what ya looking for?
Old Oct 20, 2006 | 02:29 AM
Just far enough away that I could get a real impression of what it looks like on the car (something where you can see the whole car)… might be somewhat irrelevant since there’s no way that anything I own is going to be happy with a 2.5” pipe, although oval might work…
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
chubsworth
Aug 26, 2015 02:34 AM
db057
Aug 22, 2015 08:17 PM
