howto check for fuel
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
i need to check if my engines gettin fuel to narrow down my starting trouble how exaclty do i do this?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When you turn the ignition on with the car off do you hear the fuel pump prime. You should hear a whine/humming sound around the fuel tank. GM fuel pumps are junk and I wouldn't be suprised if yours is shot.
Car: '90 RS
Engine: 377 LSX
Originally posted by bac67
also is there a adapter thing already in my fuel lines where i can hook up a fuel pressure tester? if so where?
You could also plumb in a summit fuel pressure gage for less than $30.
Car: 1991 Chevy Camaro
It talks both options Shifty mentioned.
Car: 91 Camaro
Engine: LO3 305 TBI
ok i have everything fuel,spark, n the starter works....BUT IT WONT START! it trys to and i even got it to run for a second but once RPMs it 2500 its shut off..WHAT IS GOING ON? my friend said camshaft sensor or somthin...clogged fuel filter? any thoiughts
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro
Engine: LO3 305 TBI
k new fuel filter in and while the line was off we turned the fuel pump on and it shot fuel out so im thinkin tahts good. but where else to cehck? how can i tell if my injectors are good or if my coil is bad?
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro
Engine: LO3 305 TBI
ok how do u test the injectors or make sure there fireing like there suppose to?? i can start the engine with some spray engine starter but i dont think fuel or enough fuel is getting to it.
Car: '90 RS
Engine: 377 LSX
92camaroJoe
Aug 13, 2015 06:07 AM
