splicing fan switch?
Old Jul 10, 2005 | 09:32 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i am wanting to hook up a switch to manually turn on the fun when i want to. my question is, do i just splice the fan switch wire into one of the terminals on the switch and put a wire on the ground terminal to ground it? any help would work.
Old Jul 10, 2005 | 09:46 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
What you suggested will work. But, if you want a little less wire to run, you can run your fan switch off of the green/white wire from the coolant fan relay. The fan relay is located on the firewall in between the driver's side fender and the brake booster and master cylinder. It's in a small black bracket that holds 2 relays. The fan relay is the one closest to the driver's side fender.
Here is a bad wiring diagram I did a while back in MS Paint to show how to do it (ignore the fuse, though, it's not needed):
Old Jul 10, 2005 | 10:18 PM
ok thank you, then would i just run the wire through the dash to my switch?
Old Jul 10, 2005 | 10:44 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Does that work the same for an 86? My relay is near my coolant overflow bottle but it should be the same idea, right?
Old Jul 11, 2005 | 08:49 AM
Benm109's Avatar
Yes
Yes, it will work the same. I just checked a wiring diagram for an '86 305 TPI and it's the same wire (green/white).
Old Jul 11, 2005 | 09:14 AM
i love this site. not even 15 minutes from my first poat i got a response. thank you all very much!!!
Old Aug 3, 2005 | 01:11 AM
Winger4800's Avatar
Car: 2003 Corvette
Transmission: one that has 6 speeds
nice
Old Oct 1, 2007 | 09:14 AM
busportygrl's Avatar
Re: splicing fan switch?
What guage wire do you run from the relay to the toggle switch?
Old Oct 1, 2007 | 09:26 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Pretty much any wire will work. It is just relay current (on the order of 400 milliamps).
Anything you can buy at an auto parts store will be fine.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
DIY PROM
Sep 3, 2015 04:21 PM
