Made a CAI.....any questions??
Old Aug 8, 2005 | 12:17 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Its 3.5in exhaust tubing to a 9in K&N cone filter. I brazed the tubing together, bondo'd the seems and painted it with engine paint!!! Its installed into a Camaro so I had to relocate the battery to the drivers side.
Car: 1989 Iroc-Z
Engine: 350ci SBC
n/m
Old Aug 8, 2005 | 12:21 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Old Aug 8, 2005 | 12:22 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Battery relocated to driver's side!!!
Old Aug 8, 2005 | 01:06 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
oh that's nice!!!!! What happened to the evaparation canister? And what did you use at the throttle body?
Old Aug 8, 2005 | 01:14 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Evap can is long gone as well as the cruise. That is a 4in to 3.5in hump hose you can get online at www.airflowonline.com
Old Aug 8, 2005 | 01:57 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
yeah my question ins... where did you get that black rubber hose thats on the throttle body to the pipe? i need one bad
Old Aug 8, 2005 | 07:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Did you cut out the battery tray?
Did you remove plastic shield under it?
Are you going to box the filter in to keep hot engine bay air out of it?
Or, is the air comimg around the headlights enough?
Old Aug 8, 2005 | 08:05 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Looks just as good as aftermarket stuff I have seen. Yet your probably cost a lot less. Good work.
Old Aug 8, 2005 | 12:37 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I believe the air comming around the headlights and up into the fenders is enough. I am going to box in the filter tho.....
Old Aug 8, 2005 | 01:09 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
What tubing did you use? Just in case I can find some like that to mess around with......
Old Aug 8, 2005 | 01:29 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
my air intake looks almost like this. i built mine out of 3.5 exhaust tubing about 3 years ago. the biggest differance between ours is that i cut a hole below where your filter is mounted and routed my tubing thruogh this hole and down behind where the fog light used to be(its on a gta). i dont really drive alot in the rain, so it does not affect me too much. vern, you can buy the tubing from Smileys over on peachtree road in balch springs. the usually carry a varity of 45 and 90 degree bends, most of which are around $17-19 each. i used 2 90 degree bends. as for the coupling to the throttle body, the cary a 4inch(the outside diameter of the tb) to 3.5 inch metal adapter. then you just have to form it around the tb, and get a good silicon reinforced coupler. the peice that he used to attach the air intake to the tb will start to deteriorate in a year or so, so spend a little money and get some good conectors.
Old Aug 8, 2005 | 01:45 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I used 3.5in mandel bent exhaust tubing.
Not sure y you think the hump hose will deteroiate in a year or so??? Its made for automotive applications!!!
Old Aug 8, 2005 | 01:55 PM
vernw's Avatar
Thanks, Veja. I've got one of the LT1 bellows I'm planning to use for that part. I was hoping to hear there was some pre-formed part out of a known exhaust system that could be picked up and cut down to our required length. I may try to find a local shop where I can get some parts to dummy up one so I can know what I need to get to make it work. I've also thought about using PVC to make the dummy kit/pattern for fit testing as well....
Old Aug 8, 2005 | 02:47 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes, very nice. It should work quite well. One thing you might want to consider is partitioning the filter away from the heat of the engine. Let it draw cold air in from the front of the car and the passenger fender well.
Old Aug 9, 2005 | 05:52 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
<--mandrel bends also. i say it will detiriorate in a year or so because mine did. i once had the same piece on my car. they do great if they are not subjected to twisting forces, but being that the engine will twist when throttle is applied, twisting of the bellows is enevitable.
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
