Car is too loud!
Old Aug 14, 2005 | 05:50 AM
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
Car is too loud!
Hi,
my swap is done (350, ported dart alu heads, weiand team g, holley double pumper, rough comp cam etc.)...
...and now the car is way too loud for this country (germany)
setup:
hooker headers
carsound high flow cat (thought it would quiet it down a bit )
hooker aerochamber
all wrapped in a 3" stainless steel pipe
does anybody have an idea how to silent that one down without changing the exhasut setup??
something like a silencer, any tricks to mod a muffler or fabricate something in the pipe...?
please help, because the car runs great and I'd like to enjoy it, but now I always have to think about the cops...and that sucks!
greetings
Simon
Old Aug 14, 2005 | 01:50 PM
CaysE's Avatar
A resonator along the I pipe comes to mind.
Old Aug 14, 2005 | 02:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah maybe a small dynomax bullet somewhere in the I pipe section
Old Aug 14, 2005 | 03:20 PM
RWB____s's Avatar
Car: Z/28
Transmission: Turbo 400
You could try these. DynaTech Cones inserts.
http://www.jegs.com/cgi-bin/ncommerc...12&prmenbr=361
Old Aug 14, 2005 | 05:34 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
http://www.classicchambered.com/classic/sounds.html
Old Aug 14, 2005 | 09:17 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Re: Car is too loud!
[/B][/QUOTE]
lol, i would suggest putting a bullet muffler inplace of the cat or if you have to leave the cat on, put the muffler right after the car. Youll only loose a few hp, but it should quite it down alot
Old Aug 14, 2005 | 10:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Axle/Gears: 8.5" 10-bolt 3.73 Posi
the cat quiets the car alot more than the bullet muffler would.
I'd suggest, if you don't need a cat, put cheap muffler where the cat is. It'll quiet it more than the cat does. Like a flowmaster or something.
Or keep the cat, and add a bullet muffler after it, it should quiet it.
Old Aug 14, 2005 | 11:47 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
check out car chemistry's collector insertshttp://www.carchemistry.com/ccexhaust.html
Old Aug 15, 2005 | 03:55 AM
RWB____s's Avatar
Car: Z/28
Stay away from those CC inserts. I have tried them. They really screw up the tune on a engine by causing way to much back pressure. I could not lean the engine enough to keep it from loading up. I went to the DynaTech cone inserts and they work pretty good with minimun tuning problems.
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
