Northern California Discussion board for Northern and Central California.
everyone scratch you heads for me....
Old Aug 18, 2005 | 03:49 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
A no start cond. after the operating temp. is reached could be what? 89/tpi
Old Aug 18, 2005 | 03:52 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
No crank, or crank no start?
Old Aug 18, 2005 | 03:54 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
yeah need more info?
Dan8289gta- love the sig
Old Aug 18, 2005 | 03:55 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
we get the starter crankin' but acts like no fuel present. kinda tries and coughes a bit'. let her cool down or a cold start...she's fired up.
I have constant fuel pressure at the rail during no start cond. 38lbs. the regulator holds pressure correctly.
Old Aug 18, 2005 | 03:57 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
how board would we be if we didn't have these mysterious gremlins to chase?
data log, data log, data log.
Old Aug 18, 2005 | 03:58 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
since terrell has one....
I want my sig to have a pic of my thirdgen and bike as well
gotta' run with the big boyz'
kairles's Avatar
Engine: 383/LGX
is it(motor) really at operating temp cause if its not and the CTS is saying it is you may not be getting enough fuel to start (cold motors need more fuel to start than warm motors)
Old Aug 18, 2005 | 04:02 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
yeah, we are hot at the motor. start her up cold, drive to the gas station like an @#$%^ pump some 91 octane, go to start and only the starter is spinnin' with no combustion. makes a couple burps like it almost combusted. keep on the starter and like on the tenth try she fires up...all stumbly at first.
Old Aug 18, 2005 | 04:28 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Check the resistance of your injectors with a multimeter when its acting up should be around 16 ohms anything under 10 is trashed.
Old Aug 18, 2005 | 05:04 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
already did the resistance check....all good.
Old Aug 18, 2005 | 05:20 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: everyone scratch you heads for me....
__________________
89 iroc,zz4/T56/3:70 gears/orig. firehawks/herb adams bars/spohn stuff. crummy tpis chipped....soon to have my own burned chip!
You answered your own question . . . it's your crummy tpis chip . . . I'd even go so far as to wager you'll find the answer in the crank fuel pulse width vs. coolant temp table (or similar for your app).
Old Aug 18, 2005 | 05:31 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Since I don't data log yet (got my own cable/laptop already)
I am held prisoner until I can get either eric or terrell to data log for me and teach me a few things..I know I should learn for myself and I will, but I wanna' be up and running for our next meet and the race season.
Old Aug 18, 2005 | 06:29 PM
kairles's Avatar
Engine: 383/LGX
data logging is easy its prom tuning thats hard unless you know how to do it
I have some programs on a disk just give me a call I we can set something up
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
check your coil.
Old Aug 18, 2005 | 06:42 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
heres something to try . . .
start the car, drive around, sit in the driveway - warm it up, whatever it takes to get the car to oper. temp.
Turn it off. Give it a minute. Then try to start it again -- except floor the pedal while your cranking it. This will tell the ECM to enter 'clear flood' mode and set your crank AFR to about 18:1.
When your engine is at oper. temp it needs much less crank fuel to start then when it's cold. I think it's drowning. Let us know what happens.
Old Aug 18, 2005 | 06:51 PM
BORLAZ06's Avatar
Originally posted by TraviZ
check your coil.
i was thinkin the same...but hey what do i know..lol
Old Aug 18, 2005 | 07:01 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Ya' you guys have good points. I will do the "flood" test and after that one, I will turn down the fuel pressure a few.
I think it's fuel related as well. I got time in about 2 hrs. to goof with he rock. I 'll let you know.
Old Aug 18, 2005 | 07:24 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Alright, just got back from testing-
using the flood method produced no compustion.
the mystery no start problem is gone for now, the car won't do it right now.
it still has major issues though. idling at 850 rpm this thing shakes like an early mopar with a flat tappet.
I'm hittin' Terrell up to come hang and have bq' and data log my nizzle.
Old Aug 18, 2005 | 07:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what? tonight? am i invited?
Old Aug 18, 2005 | 09:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Lot's of suggestions, but I'd start with basics first.
Any codes stored?
If not, check for ignition issues...first thing I'd have the ICM tested at your local DAP.
You say "operating temp", but that usually hits in about 5 minutes of driving....you're kinda describing something like a heat soak issue...assuming it takes you longer than 5-8 minutes to go get gas, etc. before she acts up.
Hope ya guys figure it out tonight, post back up after you've looked it over...I'm kid sittin and getting bored
Old Aug 18, 2005 | 10:55 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i say you need to bring it into the shop and pay $75 on a diagnosis no more spending money on useless parts that dont need to be replaced
i think there may be several unrelated problems with your car just tow it in and pay $75 for a diagnosis dont even have to get it repaired
smog diagnostic specialists & auto repair
3100 arden way
sacramento ca 95825
the tpi specialists
call me at the shop for a towing quote 916-974-7664
i just dont have time for a while to come down and devote a day im trying to get my car finished before the 27th so i say bring it down and have it diagnosed no more throwing parts at it.
Old Aug 18, 2005 | 11:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
hey Pork, what's your shop do on the diag?
Old Aug 19, 2005 | 08:58 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
check all the wireing.. Maybe you got a loose connection somewhere? or maybe the starter/coil is getting heat soaked?
Old Aug 19, 2005 | 11:52 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
o.k., o.k., o.k.
eric is probably right about coughing up the diog. fee here....
there seems to be plenty of issues at the moment.
Eric, like Trav said what would I get for my dough.........
and yes Trav, you are welcomed over my place. Terrell and I thought we would data log this Sunday, but I think I should just bring her in to the shop.
are you there tomorrow eric? Sat. works for me.
Old Aug 19, 2005 | 02:22 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
o.k., o.k., o.k.
you would get told exactly what is wrong with the vehicle....so depending on the symtom we will test differently and than a quote for repair and you can choose to repair or leave knowing what is wrong with the vehicle.
yes we are open tommorrow the earlier the better
Old Aug 19, 2005 | 08:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just curiuos, but what exactly does your shop do for the diag...i.e the 75 dollar rate?
Comp test, scan, leakdown, sniffer, etc?
Old Aug 19, 2005 | 09:19 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I don't think Eric can answer that.
Bennie, the actual mechanic will probably have to go the process of elimination route and check a lot of things 1 by 1.
I'm not sure all the diagnosis tools he has, but he has scanners and all sorts of knowledge about these cars.
Old Aug 19, 2005 | 09:37 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
again by symptoms each car is different, we do have a gas analyzer which we may use if the situation calls for it, just like we may do a compression test or combustion leak check if the symptoms call for it, so i mean i cant really say what will be done it will just depend on what we find obviously we arent going to do a compression test on this since the vehile starts up just fine and will run this does not indicate low compression. nor is it a dead miss through out the rpm range.
$75 will be the complete diagnosis none of that level 1 or 2 crap that other shops do 75 flat rate unless we have to do something like pull the valve covers to check for worn camshaft lobe or something of that nature. very rarley does it go over the $75
and del is right about that bennie will be diagnosing the car not me i work on mine and friends cars i just get paid to be a service writer there so thats all i do however unlike most service writers i can also work on the vehicles and i consider my self knowledgeable but still learning hehe but i dont work on the cars unless bennie tells me to and its nice
Jake_92RS
Jan 28, 2020 10:37 PM
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
