Viper 791XV Wiring Guide
Old Sep 25, 2005 | 08:13 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Axle/Gears: 2.73 Posi w/Disc
I wired in my Viper 791XV Remote Start alarm yesterday and since I had some time to kill today, I decided to create a schematic of how I wired it in. Here's Part 1 - the Relay Satellite:
Old Sep 25, 2005 | 09:58 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
...and here's Part 2...the 791XV alarm brain wiring. Note that there are still a few channels free (H2/3 & H2/4, if not more) -- I have 3 extra relays laying around and I'm brainstorming what to do with them...
Old Apr 24, 2006 | 03:09 PM
jderen's Avatar
Very Nice!
That's exactly how I wired mine.
This would have been a huge help!
Old Aug 5, 2007 | 05:11 PM
bruhthakuga's Avatar
Car: '90 GMC Sierra C1500 2WD
Engine: L05 5.7L GAS 8 CYL (5.7K) V8 TBI
Transmission: 4 SPD THM 700
Viper 791XV
I just finished the wiring of my Viper 791XV, well almost, I have all the nessassary alarm wires connected, I don't have the Remote Start Wires connected and the Additional Optional Relays wires connected.
I am not getting a Command Page from the Control Module. When I press a button I see a TX/Signal Icon and then a RX/Signal Icon but soon a series of beeps with a Signal Icon without a TX or RX icon. Every couple of seconds or so I get a RX/Signal icon. If I am correct the RX Icon means that the remote is recieving a signal?
Anyone have any ideas of what I should check? This is my first Alarm but I do have Basic Electronics and computer repair understanding. I also was an electrician for a year and have a certificat of Automotive repair.
Old Feb 11, 2008 | 02:19 PM
tAHOE22's Avatar
Re: Viper 791XV Wiring Guide
HI I HAVE A 95 TAHOE WITH A VIPER 791XV I INSTALLED MYSELF I HAVE 3 ISSUES WITH IT I CANT FIGURE OUT HOW TO PROGRAM IT TO SET ITSELF, IT DOSNT START ON THE FIRST TIME IT STARTS AFTER THE 3RD OR 4TH TIME, AND I AM TRYING TO HOOK UP THE FACTORY HORN TO THE ALARM THERE IS NO HORN WIRE JUST A + SIREN WIRE (BROWN) PLEASE HELP. I ONLY HAVE THE OWNERS MANUAL NOT THE INSTALLATION MANUAL
Old Feb 27, 2008 | 09:39 PM
ThirdGenJP's Avatar
I have this alarm and got it installed, it worked fine until Acura messed with it. I found out that the wiring that Acura messed with made the alarm bad. I recently took all wires apart and tried to put all of them together again. Today I tried to see if the remote and all componenets work but when I start the car automatically it turns off again after 8-10 sec. I don't know what I did wrong. I bought a 998T-DEI Techsoft Bitwriter and it tells me all specifics of what the alarm can do and I saved it to the alarm but still wont work. I'm not sure if the bypass module of the o-ring around the ignition is working fine, I think I connecte it correct. My car is a 1999 Acura T.L.3.2. If anyone can help me please let me know I can make pictures and all of my car to show specifics. I think the Bitwriter is just now programming the Viper alarm correctly although is says Completed Sucessfully.
Old Jun 7, 2008 | 09:58 AM
ElectricJoeNJ26's Avatar
I have a 791xv, and while those pictures are vert helpful. Is there anyone that can send me a copy of the installation manual. Thank you very much..
Joe
ElectricJoeNJ26@aol.com
Old Mar 8, 2009 | 01:00 AM
dfwithin's Avatar
dude i am so lost on my install in my 2002 gmc sierra i ahve the viper 791 xv and i cant figure out where anything goes really. i got the primary half installed and the sat. but i cant find my doors and i cant figureout where my bypass ties into. someone pleaseeeeeeeeeeeeeeeeeeeeeee help
Old Jan 10, 2010 | 08:16 PM
carcrz's Avatar
did anybody get the wiring diagram or am i too late
Old Jan 10, 2010 | 08:19 PM
carcrz's Avatar
i need help with my remote start all it does when i start it is makes s grinding noise and won't start please help
Old Feb 20, 2010 | 12:47 PM
tmemastr's Avatar
I just wanted to say thanks for posting this. I am currently using it to assist my install.
Great breakdown.
Old Feb 21, 2010 | 06:16 PM
tmemastr's Avatar
I am wanting some help please.
I installed my Viper alarm and everything went smoothly.
I am now testing the system, if I close the doors and arm the system, the alarm becomes active and the doors lock....great.
If I click the unlock button, it only disarms the alarm, it does not unlock the doors. I know its wired correctly because if the drivers door is open and I press the unlock button it unlocks both sides and disarms the system...
It will not unlock the doors after I am out and the system arms. Only if I am inside the car testing the system with the door remaining open.
Anyone have any ideas???
Old Feb 21, 2010 | 10:56 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
possibly crossed the door trigger or dome light wires with something.
Old Feb 21, 2010 | 10:58 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
if the starter is grinding adjust the starter with shims. what else could grind? that's not the alarms fault. now if you mean it just turns the motor and doesn't start, maybe you didn't disarm vats which has a fuel injector kill on tpi cars. maybe you have a fuel pump disable too.
Old Feb 22, 2010 | 12:40 PM
tmemastr's Avatar
well I figured out that the doors will unlock, just not after the shock sensor has been tripped. So I know the door trigger wires are fine, what would the dome light wires have to do with this problem?
Old Feb 22, 2010 | 01:59 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
door trigger and dome usually share the door pin switch wire. unless you run dome to the light switch or somewhere else along the line, but same wire still. glad you got it fixed
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Bryan F
Aug 27, 2015 07:28 AM
BrianI
Aug 9, 2015 11:52 AM
