Info: How to buy Speakers
Old Dec 15, 2005 | 02:13 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This one's a LONG one folks...
This is part 2 in my series of (undetermined quantity) articles about buying stereo equipment for your thirdgen.
Once you've got a head unit, your next step can vary based on your priorities, but the next step for most people will be speakers... whether it's 1 pair, or 2 pair.
Writing about buying speakers is a lot more difficult than writing about buying a head unit, because there is a heck of a lot more subjectivity involved. Head unit A and head unit B don’t really sound much different, so it’s generally a matter of comparing features. That’s not the case with speakers. Every two speakers on the market sound different, so ultimately you need to audition them yourself, and trust your own ears. Because of this, this article will not only tell you about speakers, but it is going to attempt to teach you how to listen to them, and to evaluate what you hear.
So… let’s start with the objective part of speakers… their specifications.
Specifications
They’re all crap, so just ignore them.
Power handling depends on too many other factors that aren’t explained in the ratings, so that specification for both RMS and peak power handling can be generally ignored, or used as a guideline at best. I guarantee that any speaker on the market won’t handle its rated power if you feed it a 20hz test tone, but most of them will probably take 3x their rated power at 1khz. There’s also the issue of “handling” the power vs. turning it into useful, undistorted music. I’ve seen plenty of speakers physically handle their rated power without damage, but manage to reach their full excursion with considerably less power. Anything above the amount required to reach full excursion is just going to cause nasty clunks, bangs, and grossly distorted sound, so who really cares if the speaker can “handle” it?
Frequency response numbers are another crock. Nobody’s 4x6 is going to produce useable output at 50hz regardless of what the specifications claim. As with other specs, this one can be heavily manipulated by various smoothing (averaging) techniques, and other various tricks (in-car vs. anechoic measurements) to make a turd look like a diamond. Furthermore, even a speaker with a razor-flat frequency response could still sound like hell. There’s a lot more involved in producing clean, accurate, low distortion sound than getting a flat frequency response, although that’s still one of the most important aspects. Drivers with high distortion can still be implemented with flat frequency responses, but will have various undesirable qualities.
One specification that may actually prove useful, if it's rated accurately, is the sensitivity specification. This number tells you how loud a speaker can play with a given amount of power. The standard convention for rating this sensitivity is to give the SPL (sound pressure level) number for the speaker as measured at a 1 meter distance, with a 1 watt input. You might see a number like 87dB 1w/1m. This means that with a 1 watt input, measured at a distance of 1 meter, the speaker will have an output level of 87dB. Since doubling your amplifier power only gives a 3dB boost, buying a pair of speakers with a 90dB sensitivity as opposed to an 87dB sensitivity is like having double the power. This can be an advantage in low powered setups, like if you're using your head unit to power them. Just be careful when checking these specs, because some companies don't rate them the same. For example, some may rate the sensitivity at .5 meter instead of 1 meter. If that's the case, subtract 3dB from that number for comparison. Also know that it doesn't mean that a speaker with a 90dB sensitivity will go louder than one with a lower sensitivity... it just means that it will be louder with a given amount of power. Many other factors effect the maximum output of a speaker including power handling, excursion capabilities, cooling and other things.
I can’t think of any other specifications that are even included with most car speakers, but if there are any, they’re just marketing crap.
How a Speaker Works
Next it may be a good idea to give a bit of background information on just what a speaker is, and how it works. Short answer: A speaker is a transducer; it converts electrical energy into acoustic energy.
Longer answer: Most conventional speakers (ribbons and planars aside) have a copper coil that’s wrapped around a former. Attached to the end of that former is a cone, or a dome. The coil sits in a gap surrounded by a magnet. When electricity passes through the coil, it is going to want to move away or toward the magnetic field that the magnet is projecting onto the gap that the coil sits in. This causes the coil (and the cone/dome attached to it) to move forward and back as the electrical signal passes through the coil. The cone/dome is moves the air in front of it (and behind it) to produce sound.
One problem with speakers is that it is very difficult (impossible for all practical purposes) to build 1 speaker that can accurately reproduce signals across the entire range of frequencies that the human ear can hear. In general, the average person’s hearing is said to be able to recognize sounds ranging from 20hz to 20,000hz (20khz). Since a lot of you reading this are still teenagers, you might actually still be able to hear 20khz, though it’s not likely. Most people’s hearing doesn’t extend that far, and rest assured, as you age, yours won’t either. By the time you’re 50, you’ll be lucky to hear a note above 12khz. Boom your stereo much and it’ll be more like 8khz. Boom all the time, and by the time you’re 50, your life will sound like AM radio. So anyway… 1 speaker can’t produce 20-20khz signals properly. To produce reasonable output at 20hz, you need a large driver that can move massive amounts of air by moving back and forth 20 times per second. Think of this like a diesel engine, pumping massive amounts of air through the engine at very low rpms. This big, massive speaker that’s capable of moving that kind of air, has no chance of being able to move back and forth 20,000 times per second to reproduce a 20khz signal. For this, you need a very small, lightweight speaker. Think of this as a small displacement formula 1 race engine. It’s small, with lightweight components that allow it to spin at rpms drastically higher than that big clunky diesel engine. Since a larger speaker can generally provide more bass output than a smaller speaker, you will usually find that a larger pair of coax or component speakers (like 6.5”) may have a fuller, deeper sound than a similar pair of 4” or 5 ¼” speakers.
Another issue is directivity. Once a soundwave’s length gets smaller than the diameter of the driver reproducing it, off axis response suffers. In other words, even if your big massive bass driver could somehow accurately reproduce that 20khz signal, it would only be audible if you were perfectly in front of the driver. Move a little to the side or up/down, and it’ll go away. This issue makes it very impractical to use larger “full range” drivers in an environment where you will be listening off axis… like in almost every single car in existence.
So we’ve established that one speaker isn’t going to cut it. We need multiple speakers. This is where speaker design gets complicated. When you utilize multiple drivers to cover one range of frequencies, you need to do it so that both of them don’t try to reproduce the same frequencies. You want each driver to handle a certain range that it is best suited for, and because having the same sound coming from 2 sources is generally bad for a number of reasons. You need to use a crossover to block the high frequencies from the midrange or woofer, and to block the bass frequencies from reaching the tweeter. Designing a good crossover is as much an art as it is a science, and this is usually what really has the most profound effect on how a speaker sounds, and is also one of the biggest areas of cost-cutting, especially in budget designs.
Driver Materials
There are a lot of speakers out there, made from a lot of different things from paper to carbon fiber. What effects do these different materials have? Generally, the more rigid the material is, the cleaner it will play a certain range of frequencies, with lower distortion and less energy storage. The problem is, the more rigid it is, the worse it’s going to be at the high end of it’s range. For example, let’s compare the two extremes… a poly cone to an aluminum cone. Polypropylene cones are generally flexible, while an aluminum cone is extremely rigid. An aluminum cone is likely to have lower distortion in the bass and midrange frequencies than the poly cone because it retains a pistonic behavior instead of flexing. But… at higher frequencies, that aluminum cone is going to have a breakup mode where it basically rings like the liberty bell. Very cheap aluminum drivers often have secondary breakup nodes in the octaves below the primary breakup, and since these are likely to be right in the range of frequencies that you need the driver to play, it will make the driver sound extremely harsh and “tinny”, and will be impossible to remove with the crossover. This poor quality is what can give metal cones a bad reputation as sounding “metallic” or “tinny”. The poly cone won’t do this, because it damps the breakup (it absorbs it). Other materials, such as paper, carbon fiber, and 95% of the speakers out there that have a poly cone with some sort of magic pixy dust coating, fall somewhere in the middle, trying to strike a compromise between clean midrange output and minimal high frequency breakup.
So, why does this matter to you? The more rigid the cone is, the more severe the high frequency breakup will be. This breakup needs special attention in the crossover. It generally means that a steep notch filter aimed at striking that specific breakup frequency is necessary. This not only adds to the cost of the crossover, but it means that quality control on the speaker needs to be good enough that the breakup frequency doesn’t vary from driver to driver. On good quality speakers this probably isn’t a problem, but I wouldn’t touch a $75 set of coaxes that use a fancy carbon fiber or Kevlar cone, because chances are that the crossover is not complex enough to properly handle the cone’s breakup… especially considering that 50% of their entire materials budget just got used up in the cone. Since most poly woofers have a smooth rolloff, crossover design and implementation can be much simpler, which is why poly is used in the vast majority of lower priced speakers. While everybody out there has their special secret ingredients, the fact is, most of them are just adding useless crap to a poly cone so that they can market it as the 8th wonder of the world. The fact is, when dealing with inexpensive speakers, the smoother the driver’s natural response is, the better, because a cheap speaker will NOT use an expensive filter, so you are better off sticking with drivers that don’t need one. Let your ears be the final judge, but in general, you’re better off with less rigid materials like poly and paper.
What about tweeters? You’re probably going to come across 3 different tweeter types depending on your budget: Mylar (plastic), soft domes (fabric or silk) and hard domes (aluminum, sometimes titanium or magnesium). Mylar domes show up generally only on the very cheap coaxes. They’re extremely cheap to manufacture, and their sound quality, while tolerable for OEM type systems, is relatively poor. Hard domes share the same sort of breakup issues that hard coned speakers share, except that in most cases, the breakup is beyond the audible range. However, in cheaply made hard domes, there can be several secondary breakup nodes for many octaves below the primary breakup node, and these secondary nodes will be in the audible spectrum. This breakup is what gives many hard domes that signature “metal” sound that they are known for. For this reason, in general it is not a bad idea to steer away from lower priced speakers that use hard domes, or at least listen to them with more scrutiny during auditions. A high quality hard dome won’t have that “metal” sound and can be very detailed and pleasing. Soft domes are the most commonly used tweeters because, like poly cones, their behavior can be very easy to control and will make crossover design simpler. A well built soft dome can have exceptionally low distortion just like a well built hard dome, but also avoid the high frequency breakup problems. A poorly or cheaply built soft dome, while not nearly as good as a better soft dome, is likely to sound much better than an equally poorly built hard dome.
How to Listen to Speakers
So this brings me to my next step… a little tutorial for how to listen to speakers when auditioning them. Listening to speakers is really quite a bit more difficult than people realize, and because of this, many speakers are designed specifically to appeal to you for the 5 minutes that you’re in the showroom instead of providing you with long term quality. Let me explain. If you listen to a very high quality set of speakers that was built specifically to have a ruler flat frequency response and very low distortion, you’d probably think that they sounded a bit dull and flat during a short audition. It wouldn’t be until you had some real time to spend with them that you discovered that in fact, they actually did everything right. Comparing them to another, far cheaper speaker that’s got a little hotter treble and a little more boom in the bass, your first impression would be to like the cheaper speakers better. Likewise, when comparing a low distortion speaker to one with significantly more distortion, your initial impression might be that the one with more distortion actually has more detail.
Continued in next post…
Old Dec 15, 2005 | 02:14 PM
Jim85IROC's Avatar
When a speaker adds distortion, it gives it an edgy sound that many people mistake for more detail that they hadn’t heard with other speakers, when in fact, the reason they hadn’t heard it before is because it’s not supposed to be there! However, over time, that distortion will drive you nuts.
So… how do you listen? First of all, it depends on how serious of a listener you are. If you’re just a casual listener, there’s no reason to spend a month teaching yourself how to listen. But even without that sort of preparation, in the long run you’ll be happier with a set of speakers that has a smooth, pleasant sound instead of one that jumps right out at you. One quick and easy way to see how you’ll like a speaker in the long term is to turn it up loud. Not so loud that you’re causing the speaker or amplifier to distort, but loud enough that it’s hard to talk over it without yelling. Listen at this level for a couple minutes. Does it still sound good, or is it starting to hurt your ears, seem too loud, or just seem not to sound as good? Any of these issues is a clear sign that the speaker has relatively high distortion, or a very objectionable spike in the frequency response somewhere. A speaker that might jump out at you and sound “lively” at low volumes might have that quality because of a poor frequency response or high distortion, and at louder volumes, that quality really becomes a major drawback. This is a speaker that will constantly have you reaching for the volume **** to turn it down, because you just can’t stand it anymore. Don’t buy this speaker. Buy the one that still has a clean, smooth, pleasant sound at loud volumes, because chances are, this is the one that you’ll be able to live with the longest. Remember that whether you realize it or not, most of your listening in the car will be at levels that are significantly higher than what you’re listening at in the sound booth. If you don’t believe me, next time you park your car, don’t turn the radio down. Leave it just how it was while you were driving home, and next time you get into your car and turn on the radio, pay attention to just how loud it is… you didn’t remember it being that loud when you shut the car off, but it was.
So… you’re the type of guy that wants more than just a “good” sounding set of speakers. You want something that’s really a very good speaker. How do you really become a critical listener, capable of hearing and identifying the more subtle differences between one speaker and another? For the most part, experience, and lots of it. But, your learning process will go much faster if you have a fairly good idea of what to listen for instead of trying to figure it all out for yourself. I’m approaching 30 years old, and I’ve been a hardcore audio nut for over half of my life, and I’m still learning how to listen to speakers. It’s something that really does take many years of experience, but here are some relatively basic pointers.
First of all, it’s essential to have some music that you know very well and that is exceptionally well recorded. It’s good to have a combination of simple and complex recordings with male and female vocals. The more familiar you are with these recordings, the better you’ll be able to evaluate the speakers. It’s always a great idea to invest in a good quality set of headphones, because for $50-100 you can get a very good set that will have very low distortion, and because they’re so closely coupled to your ears, you’ll be able to resolve an amazing amount of detail. This will really help you become familiar with the overall qualities of the music, although it won’t do much to help you with identification of proper imaging and separation, but at least you’ll know what the tonal qualities are supposed to sound like. It’s also very helpful to go to some high end home audio shops and listen to the music on some very good speakers. This will help you build your listening skills with respect to imaging, staging, and with detail resolution in a non-headphone environment. Listening to some lesser speakers with the specific goal of identifying its shortcomings compared to the better ones is a GREAT way to learn the differences. A lot of what I mention below about listening to the car speakers can and should be used when auditioning these high end (and low end) home speakers in order to be able to identify shortcomings. If you can, I would suggest that you listen to the following speakers:
B&W 800-series (804s and larger)
Dynaudio Audience Series (Audience 72 and larger)
Sonus Faber Cremona or higher
Jamo D830
Quad ESL
There are hundreds of other fantastic sounding speakers out there, but these are some that I’m personally very fond of, and are speakers that I’ve found offer very low distortion and an overall enriching listening experience. Each one of these speakers sounds different, and they all have their shortcomings, but they all do an awful lot right as well. Best of all, each of them has different strengths, so listening to them all and picking out their differences will really be a useful exercise.
So now you’ve listened to a bunch of music, and hopefully, you had the chance to listen to some very good high end speakers. Maybe now it’s time to listen to some car speakers. Start off by popping on one of your cds, and turning the speakers up to a reasonable volume. Get the easy stuff out of the way first. Are there any objectionable issues with the frequency response? Are they too bright (too much treble), too dark (not enough treble) or somewhere inbetween? Is the midrange too forward (in your face), too laid back (where’d the vocals go!?), or inbetween? Is the midbass overpowering and unnatural, absent and thin sounding, or somewhere inbetween? How are vocals? You should be listening to male and female vocals, because they will bring out flaws in different ranges. Generally, I’ve found that differences in the 150-500hz range has the most profound effect on male vocals. Too much low frequency energy makes him sound unnaturally bassy. Too little makes it sound thin and hollow, with no warmth. With female vocals, since they have much less low frequency energy in their voices, I seem to find that variations in how they sound seem to correlate with the 400-1khz range. Too much upper frequency output can make a female voice sound shrill and harsh, too little makes it sound recessed and undetailed. Both male and female vocals are dependant on a clean response over a wide range of frequencies, but I’ve found that it’s easiest to find the flaws using the males for the lower and females for the higher range of vocals. Bass response (and to an extent, even midbass) is going to really be hard to judge on car speakers, because a shop’s sound board is a horrible environment for speakers, and is not a whole lot like a car environment. But, you can still compare one to the next in terms of the amount of output and how detailed it is. Do all bass guitar notes have the same volume, or are some louder than others? Just keep in mind that when you put it into your car, it’s going to sound totally different. If you’re running subs, this will be less of an issue, because you’ll have these filtered anyway.
So once you get past the frequency response issues, you can start to listen to more of the detail oriented stuff. Keep in mind that this stuff all hinges on the quality of the recording, and your familiarity with it. All of this detail oriented listening is fairly worthless if you’re not already well aware of what the recording has to offer. How clearly can you focus on one individual instrument? Can you listen to it and hear all it has to offer, or is it hard to pull that instrument from the rest? A better speaker will resolve more detail and allow you to easily distinguish each instrument and listen to it exclusively. You should be able to pick out any instrument to listen to. Lead guitar and rhythm guitar should be clearly distinguishable. Bass guitar should be clear, and separate from bass drum. You should be able to pick out individual bass guitar notes, not just have a low frequency blur. Can you hear the clean upper frequency harmonics of the guitar strings? Can you hear the subtle inflections in the singer’s voice? What about the dynamic impact? Do drums have a hard impact like a live performance, or is it more relaxed?
For those who aren’t real sure what it is, imaging is the ability of a speaker to provide a pinpoint location for various things. For example, a singer’s voice should sound like it’s coming from one very specific location… not from all over your dashboard, and shouldn’t shift back and forth with changes in pitch. It should stay in one tiny, tightly focused spot at all times. This should hold true for all instruments and voices, unless they were specifically intended to have a different effect. Staging (or sound stage) describes how accurately these images are placed. Generally vocals would be perfectly centered. Perhaps there’s a guitar that’s supposed to be ¾ of the distance toward the left and cymbols are 1/2 way between center and right. Imaging and staging are two very important aspects to a quality speaker, but I’m not really going to mention much because any differences from one speaker to the next will be largely overshadowed by your installation. Where you put the speakers and how you aim them will have a profound effect on imaging, so whether or not they image well in a retailer’s sound board really isn’t going to teach you much. The fact that a typical sound board has every speaker sharing a common chamber means that you’ve got 1 speaker and 50 poorly tuned passive radiators, so it’s not likely that you’re going to get a good image anyway.
Suggested Music
As long as you’re going to go listen to a bunch of stuff, I’ll provide you with some suggestions for various music and what to listen for. If you choose to use any of this music, be sure that you’ve spent a lot of time with it so that you’re familiar with it.
Eagles, Hell Freezes Over, particularly Track 6 “Hotel California”
This cd is my number 1 cd, both for pleasure listening and for speaker evaluation. Not only is it a phenomenally well recorded live album, but I’m exceptionally familiar with it, especially Hotel California. What amazes me however, is that I still learn more about this song as I listen to it on better speakers, despite having heard it thousands of time already. This song starts off with thundering deep bass from a bongo drum that Timothy B. Schmidt is pounding on. After the first few, you’ll begin to hear two clearly distinct tones, the first low and the first high. On lesser speakers, you’ll have a hard time distinguishing between the two. This may be below the typical range of many speakers you listen to, especially 4x6s, but none the less it’s something to listen for since the upper harmonics are what really cause you to hear the differences. Anyway, shortly after the bass, you can hear maraca in the right channel, then another in the left. These should be clear and lifelike… not harsh, but very present. Once the actual music starts, you should be able to hear 3 different and distinct guitars. Joe Walsh pounding away on his guitar, Don Felder on his, and Glen Fre on his. On most speakers, you’ll never be able to latch onto any of the individual guitars and listen to it cleanly and clearly without the others interfering. This requires a VERY good set of speakers, and it requires them to be in an exceptional installation. Don Henley’s voice should be realistic sounding. On a lot of speakers it sounds too laid back. While it should never be in your face, it should not get drowned out by the rest of the music either. His voice shouldn’t resonate or be boomy, but should also not be thin and weak sounding. Also take a moment and listen to track 5 “Tequila Sunrise”. In this song, Glen Frey’s “ssss” sounds can be harsh (known as sibilant) and very unpleasant. The speakers should not exhibit this. All of his vocals, including his “ssss” should be smooth and lifelike without being harsh or piercing.
Tom Petty, Greatest Hits, “Mary Jane’s Last Dance”
This is another song that I use a lot. You should be able to clearly distinguish between the 2 guitars… one to the right and one to the left. You should be able to listen to either one without interference from the other, and you should be able to pick out the subtle detail, especially of the left one. Tom Petty, while always nasal sounding, should still sound realistic, like he’s singing right in front of you.
Dire Straits, Brother in Arms, “Money For Nothing”
The 80s are alive again! Be careful with this song. This song has a tendency to sound PHENOMINAL on even mediocre speakers. Every time I use this cd, I wind up just jamming to the tune instead of actually evaluating things. Anyway, there are a couple things you want to use this song for. Overall, the percussion on this song is very well recorded, and should sound very natural. Bass drum should be powerful but realistic. It shouldn’t sound like the boom of a rap song, it should sound like a bass drum. The snare should have a powerful, lifelike, dynamic snap. It should sound live, not laid back and smooth, but also not harsh or unpleasant. Cymbals should be clean with a somewhat laid back sound, but still plenty of air and shimmer. These won’t quite sound live, but they’ll still sound clean. Knopfler’s guitar playing is near g0d-like and sounds fantastic on this song, but I’ve found that it still sounds good on mediocre speakers because more distortion on an electric guitar sound that’s already been distorted intentionally can be hard to pick out. Either way, don’t put much stock in how his guitar sounds because it will sound good on anything. Still, it should have good dynamics, and should convey the lighter details without sounding overly sharp. Knoplfer’s voice should sound realistic and hearty. It has a nice deep sound to it, but shouldn’t be boomy or unnatural sounding.
Alison Kraus and Union Station, Live 2 CD set
Pick whatever songs you want on this one… they’re all exceptionally well recorded. In this all acoustic group, you should once again be able to pick out the 4 individual instruments: Jerry Douglass on dobro, Dan Tyminski on guitar, Ron Block on banjo, and Kraus on violin, as well as Barry bailes on bass (cello, not bass guitar) behind all of it. It’s been a while since I’ve listened to it, so I forget who’s where on the soundstage, but the 4 are spaced evenly from left to right with the bass in the center rear. Kraus’ voice is haunting and intimate, and completely natural sounding. Dan Tyminski’s voice is also very natural sounding. The better the speakers are, the better this whole album sounds.
Jim85IROC's Avatar
Coax vs. Component speakers
A coax speaker usually refers to the type of speaker that’s got the tweeter mounted right in front of the woofer (coaxially; sharing the same axis, hence the name). This type of arrangement is convenient because it can drop right into stock locations and you don’t need to mount anything else. On the other hand a set of components (named because it comes with multiple components) has a separate woofer and tweeter, as well as a separate crossover that’s got to be mounted somewhere.
Your main advantages with coax speakers are cost and installation convenience. Although it’s not always the case, typically a coax speaker will be less expensive, because it’s usually marketed toward people who are looking for an affordable, easy upgrade. Due to packaging constraints and cost concerns, most coax speakers have very simple crossovers, which is why material choice can be so critical. As I mentioned above, while they may be worth a listen, typically you’ll want to stay away from low priced coaxes with rigid woofer materials and hard tome tweeters and stick with a poly woofer & soft dome tweeter combo. Of course, let your ears be the final judge.
Some “coax” speakers have more than just a woofer and tweeter. Some are 3 and even 4-way designs. For the most part, this is largely a gimmick and unless your ears tell you otherwise, don’t waste your time. Most of these 3 and 4 way designs are still just a true 2 way design, with added drivers that are completely non-functional or only semi-functional. It’s usually marketing crap, which is why they’re usually in the lower priced categories. There are a lot of drawbacks to this type of design that can’t be overcome easily or affordably. For one, they typically block a major percentage of the woofer, so you wind up with attenuated output at the top end of the woofer’s usable range. Secondly, there just isn’t room for the overly complicated crossover that would be necessary to make such a design perform properly.
Component speakers don’t have to conform to the tiny packaging restraints imposed on a coax speaker, so it opens up the possibility to produce a much better product. Larger, better quality tweeters can be used, and larger, far more advanced crossovers can be utilized. This doesn’t mean that there aren’t still hundreds of terribly designed component sets out there, only that there is more flexibility to create a better product.
Other than the potentially better component quality, the other advantage to component speakers is the ability to install them in arrangements that are more ideal. You can mount and aim the tweeter independently from the woofer. Not only does this give you the luxury of being to aim the highly directional tweeter for optimum imaging without having to tweak the entire speaker, but it allows you to position the tweeter so that the phase of the two drivers around the crossover frequency is more ideal. I don’t want to get into that whole issue here since this writeup is already turning into a novel, but trust me that it’s an advantage.
The drawbacks to a set of component speakers are that the installation is going to be more challenging, the higher quality is going to cost you more, and that in addition to finding a home for the woofer and tweeter, you’ve also got to find a home for the crossovers. Overall however, if you’re after the best sound you can get, this is probably the way to go.
Where to put the speakers
Now that you know how to listen to speakers, you need to decide where you want to put them so that you can figure out what size and style you want, and then you can finally go audition some.
In a non-Bose equipped thirdgen (GTAs excluded), you’ve got 4x6” speakers in the dash and 6x9” speakers in the sail panels. Bose equipped Camaros had speakers in the kick panels, and speakers in the rear hatch cover. Since the Bose setup was such a pitiful combination of head unit, amplifiers and speakers, I’m going to assume that if you’re interested in upgrading speakers, you’re also going to pitch the head unit and amps, so the non-Bose speaker locations can still apply. If you have a GTA, you’ve got the same crappy 4x6” front speakers, but instead of crappy 6x9s, you’ve got another pair of crappy 4x6s in the back, augmented by a crappy 5.25” “subwoofer” though I use that term very loosely. One interesting tidbit of information is that the primary difference between the base stereo and the premium stereo (non GTA) besides adding a head unit with a 5 band eq (but still just as pitiful sounding as the regular one) was that they used less restrictive speaker grill inserts in the dash pad. Instead of the grills with plastic slats, they used a metal grill with cloth over it. It provided a noticeable improvement in high frequency output.
So anyway, if you’re looking to simply improve a little bit on the factory sound, or if you’re on a real tight budget, sticking with the stock speaker locations is the way to go. If you’re buying both front and rear speakers, make sure to stick with the same brand and model line when possible. The goal here is to have the most similar sound quality possible from front to back so that certain parts of the music don’t become more apparent in the front or back.
Front Speaker Locations
There are some pretty significant drawbacks to the stock dash location that you should be aware of. The first is that the physical location is too small to fit something larger than a 4x6” speaker without significant modification. In many cases, specifically 85-up Firebirds and 90-up Camaros, the space on the driver’s side is so cramped that many 4x6” speakers won’t even fit. These restrictions make it virtually impossible to use a very good speaker in this location… you’re basically stuck with mediocre and lower end stuff.
Another significant drawback is that it is very difficult to get good imaging for one passenger, and it’s impossible to get good imaging for both passengers. The most important part to good imaging is to have equal SPL from both speakers and equal path lengths so that the sound arrives at the proper time. I’ll save the details for a later article, but the quick and dirty is that your brain localizes sounds by comparing the differences in loudness and time delay between the two ears. If something happens to your left, your left ear gets a slightly louder version of the sound than your right ear, and it gets that sound a slight bit sooner. You can adjust your balance control to help compensate for the fact that the closer speaker is significantly louder. This will help give you a broad, even soundstage, but because the path lengths are still way off, it confuses your brain and makes it difficult to recreate a stable, accurate image. Some new head units have time alignment features that help you to adjust these tiny differences in arrival time, and can provide a significant improvement over just using a balance control. However, the image from your dash speakers is only going to get so good, and whatever you do to make it image better in the driver’s seat is going to make it that much worse for the passenger.
The last main drawback to the dash location is that the majority of your sound is being reflected off of the glass. This causes a couple problems. One is that your reflected sound is going to combine with the directly radiated sound, which is the same as having the sound come from 2 unique sources. Since their path lengths to your ear differ, you’re going to get a comb-filtering effect in which some frequencies are cancelled, and some are reinforced. The combination is going to be a very uneven frequency response that will result in a lost of detail and realism, as well as phase issues that will ruin imaging.
Another possibility is to stick the speakers down very low into your doors. If you have manual windows, you can fit up to a 5 ¼” (and most 6.5” brands) in the lower front, though you may have some interference issues with the window crank and the kick panel plastic. If you have power windows, the power window motor sits right in this location, so you will have to build out the door a significant amount in order to fit the speakers. If you use component speakers, you can flush mount the tweeter into the kick panel. This will allow you to use larger speakers than the dash location, and will also help improve imaging. Since most car speakers are designed to work in a large volume like that of a door, your overall bass output will be improved. The fact that you can fit a larger speaker than your dash will also allow bass to be much more improved. One drawback to using the door is that unless you apply generous amounts of sound deadening material, the doors are going to resonate badly. Your speakers will also be exposed to the elements, which will accelerate wear. Lastly, running speaker wire to the doors can be difficult. If you have power windows, building the door out to make the speakers fit can be very difficult, and even harder to make aesthetically pleasing. If you’re paying a pro to do the work, this will be an expensive option due to the custom work involved.
The last common location for speaker placement in the front of a thirdgen is into the kick panels. This location really does help overcome a lot of problems associated with kick panel and door locations. Your path lengths are as close to equal as you’ll be able to achieve in the car, so your imaging and soundstage can be exceptionally good. You can fit large, higher quality drivers, and you have a lot more freedom to aim and position them for best results. With a properly set up kick panel setup, your soundstage will be above dashboard height, and will be fairly far forward… usually as far forward as the furthest point of your windshield or more. There are 2 drawbacks to kick panel locations. The most significant is the lack of airspace for the woofer. Since most car audio speakers are designed for large spaces (infinite baffle) like a door cavity, they perform poorly in very tiny enclosures, like a kick panel. Their low bass response disappears, and the output in the range between 150-400hz becomes exaggerated. The most common fix for this equalization. The second drawback is that people’s legs can block the speakers, causing a high frequency attenuation of a few dB. Because the small interior is so reflective anyway, the difference in sound with and without somebody’s legs in the way is really much less severe than you would think, and is a small price to pay in exchange for the tremendous benefits in imaging and speaker quality that kick panel placement allows. One last drawback is the difficulty and/or expense associated with this type of installation. If you’re not handy enough to create your own set of kick panels, you’ve got to buy them or have them custom made. Q-Logic sells ABS plastic kick panel pods that can hold up to a 5.5” woofer and a tweeter for around $100. These are relatively poor quality, but with additional fiberglass and sound damping material, they can be respectable. Another option is to have one of the guys from the thirdgen message board build a set. There are a couple guys who do this, and both provide kick panels that are significantly higher quality than the Q-Logic pods, and at a price that’s substantially lower than you’d pay for a shop to build them. Still, this adds a significant expense on top of the cost of the speakers themselves, and really only makes sense for those who demand the best from their system.
Rear Speakers
As mentioned before, the most common rear speaker size is 6x9”, located in the sail panels. There is ample room for speakers with deep or large magnets, although tweeter protrusion to the front may be an issue. In worst case scenarios, you should be able to modify the stock cover to add the extra space that you may need. If your car came with 6x9s, the new pair will be a bolt-in affair. If your car came with the Bose or GTA stereo, then you may need to find or fabricate adapters that bolt to the body opening that can accept the 6x9s. These can be cheaply located from salvage yards or the thirdgen classifieds.
One thing that you may want to consider is rather than upgrading all 4 speakers, use the full budget allocated for speaker upgrades for the front speakers only. While some people prefer the “all around you” sound, if you’re the type that prefers a good realistic soundstage and better overall sound quality, spreading your money among just 2 speakers instead of 4 will pay off. You will be able to put that money toward a better quality set of speakers, or toward a different configuration, like kick panels instead of sticking with the stock dash location. Either way, you can retain your stock 6x9s, which are sufficient if you just want to add a little bit of rear fill for ambience. In fact, the stock speakers are perfect for this because they don’t have a lot of high frequency output that can pull your soundstage back.
Recommended Brands
This is tough. Every speaker sounds different, so you really need to decide for yourself, which is why I spent so much time explaining what to listen for. But, the usual low quality brands can be avoided.
Particular brands that you may want to consider auditioning include anything from Boston Acoustics, JL Audio, CDT, midlevel and higher stuff from Alpine and MB Quart, and for high-end type of stuff, look at Dynaudio, high end JL Audio, the new high end Polk components, Rainbow, Seas, DLS, and plenty of others.
Conclusion
As I hope you’ve realized by reading this novel, is that there’s an awful lot to choosing a pair of speakers. This will be the most subjective, and probably most difficult piece of equipment you choose. It will also have the largest impact on the overall sound of your stereo system. I can’t stress enough that you really need to audition the speakers you plan to buy. Mail ordering your stereo equipment can save you a ton of money, but with something as subjective as speakers, you really, really need to audition them to be sure you’re getting what you want.
Happy hunting!
Old Dec 15, 2005 | 04:23 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Holy moly, Jim, did you take the day off to write all of that?
I've got it bookmarked for a later read...only got through the first few paragraphs for now.
Thanks a lot for the awesome, well written guides you are providing!
Old Dec 16, 2005 | 08:37 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I can see you have some expensive tastes as well... B&W 800 series ::drool:: . 700 and 600 series sound really good too. Martin Logan and Definitive get 2 thumbs up in my book as well. Good article yet again. Just wanna add that Jazz is a great thing to listen to speakers with, particularly Miles Davis - Kind of Blue. Most jazz cd's are less processed in both the studio and mastering, giving the instruments a more clean , natural sound, with a wider uncompressed frequency range. Image seperation amongst instruments are some of the best i've ever listened to. Any decent self respecting high end audio shop will probably have that cd lying around somewhere
Old Dec 16, 2005 | 09:15 AM
Jim85IROC's Avatar
I've been unimpressed by the 700 & 600 series speakers, at least when compared to other speakers in the same price brackets, like those Dynaudio Audience speakers for example. But, this might be an unfair comparison, because the only A-B testing I did with the 700 series was against the 804s, which blew the 700's out of the water. I'm not a Martin Logan fan either... while I love the dynamics and the dipole sound, I found them to be very harsh and fatiguing, though very detailed. I found the Quad ESLs to be a vastly superior speaker.
Once I get a house that's got a living room that's actually larger than the bathroom, I hope to start experimenting with dipoles. I'm very impressed with the clarity and precision that you can achieve once you remove the effects the box cause.
Old Dec 16, 2005 | 12:04 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I agree that the 800's destroy the 7 and 6 hundred series ... but they're not even close to the same price range. A decent pair of 800's are upwards of 10k. I agree on the dipoles. Incredibly clean, a bit harsh. There was one i heard other than ML , but i cant remember who it was. They were a lot warmer - but there's no way i can remember the name. Paradigm ( standard type speaker for those that never heard of them either ) i liked, but havent advanced their product lines much at all. Warm sound, but nothing new in quite a long time. Ive been tossing around the idea of getting the bookshelf set of 700's for now as a front 2 channel setup until i get my own place worthy of the floor standing 3way's. When i do, i'll probably move the bookshelves to the surround set. To keep this third gen related and not get too far off topic, how about for the next tutorial, a little troubleshooting guide (sorry, couldnt help the joke)
Old Dec 23, 2005 | 10:23 PM
knoxie90's Avatar
Car: 92 RS Camaro
Engine: 305 tbi
Transmission: 5-speed
ya
Old Dec 27, 2005 | 01:56 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
kudos.
my system (all aftermarket, but relatively low end) shines when I play Hotel California. When in my car, people ask me to put it on just because of how the car makes it sound (and maybe also because its a pretty good song ).
BTW Jim, real nice article. I'm using it, and previous advice, to get some components in my kicks.
Old Jul 24, 2006 | 11:44 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Bumping this because I just spent 30 minutes searching for it. Defiantly a good read for those looking to get started on a system.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
PurelyPMD
May 5, 2016 04:57 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
JamesC
Northern Great Plains and Rocky Mountain
Sep 10, 2015 07:41 AM
