cold air intake with MAF
Old Jan 27, 2006 | 03:31 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
well i finaly almost finished it... few more things then its complete but now i can drive with it on. and this one accualy sucks in COLD air! i used a plasma cutter and cut a hole for the filter to go into..... i was very iffy about doing this but im pretty pleased with it it something if i sell the car i will just weld a plate down there.
incase your wondering i did put somthing to stop the filter from getting wet. its a plastic cover that doesnt allow water to come in and hit the filter under the fender.
one thing i dont like is the clamp i had to use on the MAF to the tube... theres to many hose clamps used here.. ill figure somthing out to clean it up but for now it works.
Old Jan 27, 2006 | 03:32 PM
Engine: 350 tpi
i need to find some better looking clamps for this part too
Old Jan 27, 2006 | 03:34 PM
Engine: 350 tpi
theres the hole i had to cut... i took out the bracket that held in the charcole canister and then just moved it over with some self tapping screws.... its nice having a plasma cutter on hand at work too. took less then a min to cut the hole.
Old Jan 27, 2006 | 03:35 PM
Engine: 350 tpi
last pic.
Old Jan 27, 2006 | 03:40 PM
Engine: 350 tpi
nvm i have one more lol heres the filter in the fender. i took off the plastic peice that keeps water from going into that area... now i need to cut some vents somwhere and get some more air into there.
intotal this cost me
60$ - K&N airfilter
10$ - 3.25 inch exhaust tubing
10$ - 2 90degree bent rubber tubes
4$ - 4'' to 3'' rubber tube
2$- hose clamps for MAF to tube
86$
and i did it all in a day. and got to play with a plasma cutter!
Old Jan 28, 2006 | 11:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
nice! How does the intake sound?
Old Jan 29, 2006 | 01:16 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Dude that is awsome I have the same Intake built out of sewage line from Home Depot....
Old Jan 29, 2006 | 11:52 AM
Engine: 350 tpi
sounds like its sucking hard! ive knowticed a big differnce at idling now that the MAF sensor is a little farther away from the TB. if i had accsess to a pipe bender all of it would be metal. but i dont!
Old Jan 29, 2006 | 12:55 PM
Car: 85 87 87 91 92
If it was all metal it would retain heat the abs plastic disapates heat better
Old Jan 29, 2006 | 10:45 PM
1989karr's Avatar
Engine: 3.4 / 5.0
that's awesome!
Got any more info on what type/brand the
are?
Old Jan 30, 2006 | 12:09 AM
Car: 85 87 87 91 92
Just go to your local Home building store and look at the S$#T piping area they have all the connectors and everything for 50 bucks I bount enough to make 2 CAI's
Old Jan 30, 2006 | 02:12 AM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks!
Old Jan 30, 2006 | 10:42 AM
Demon355's Avatar
I was thinking of doing the exact same thing. I made a piece of **** intake setup in 15mins one day, just because the stock intake setup looked so horribly bad. But as soon as the good weather comes back, I'll head over to home depot and pretty much copy what you did. lol! That's amazing dude, great work. Having the MAF farther away from the TB helps?
Old Jan 30, 2006 | 03:41 PM
Engine: 350 tpi
i think theres a difference in having the MAF farther away... not sure because this set up is differnt from the last one... but one of the guys at my work said to move it farther away if im putting a longer tube then stock on there to get a more accurate reading of whats really entering the engine... not really shure how it could be differnt though.
and i got the 90 degree peices at a manards but most any LARGE hardware store will have them.... the 4-3 inch adaptor didnt fit perfect because its accualy made to go around a tube with a 4 inch inner diamater not outer but it still tightended up. thats why i bought all exaust that was ment to fit around a 3 inch diamater so the fittings would fit correctly... i need to some how fasten down the whole set up now too.. not sure what to do but if any one has any good ideas let me know.
Old Jan 30, 2006 | 07:38 PM
Car: 85 87 87 91 92
I did not get the 4 to 3 adapter I just got a 3 to 3 adapter and it fits on the Throttle body pretty nice and tight....I almost think it would stay on by itself it it wasn't for bumps....lol
Also I do not think having the MAF father away helps in any way.....But I do know that the ABS piping really disapates heat its like a 1/4 inch thick versus having a metal tubing intake....
Old Jan 30, 2006 | 09:22 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Awesome man
Where did you stick the IAT?
Old Jan 30, 2006 | 09:50 PM
Car: 85 87 87 91 92
dude the IAT goes in the bottom of the plenum....Not in the intake hose
Old Jan 30, 2006 | 10:21 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by V8 Slayer
Awesome man
It goes on the plenum on the V8s although placing it anywhere will work just fine.
Old Jan 30, 2006 | 10:32 PM
Car: 85 87 87 91 92
Just dont forget to plug the hole in the plenum
Old Jan 31, 2006 | 12:50 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Yeah because I have a 3.1 V6 where the IAT is right on the side on the cylinderical airbox, can I just silicone it to the inside of the fender or something?
Old Jan 31, 2006 | 01:50 PM
Car: 86 T/A
Engine: HSR 355
He has a V6, its not in the plenum.
Really anywhere near the inlet will work, I chose to just mount mine on the top of my cone filter (still inside the filter housing though). Really doesn't make a difference- they aren't extremely accurate in the first place so +/- a few degrees won't cause any problems.
Old Jan 31, 2006 | 02:50 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Sweet thanks!
Old Jan 31, 2006 | 04:09 PM
Engine: 350 tpi
maybe i should try the 3-3 peice instead of the 4 maybe it will fit better... im sure i have one laying around here too!... kinda funny to today at work they just threw out a bunch of 90 degree 3 inch silicone tubing... i grabbed a few maybe ill switch out with these ones. if your making one make sure you post some pics of it! id love to see it. and i asked about having the maf farther away and aperently the air just gets a chance to smooth out after it hits the sensor and flow a bit better into the TB. so basicly NOOO differnce that any one or any dyno could see. now i think im gunna go and machine a areo foil for the tb at work out of aluminum and see how it turns out.
Old Jan 31, 2006 | 09:41 PM
slick88gta's Avatar
Car: 88 GTA
Engine: 350 L98
Axle/Gears: 3.45 9 bolt posi
Im not associated with these guys in any way, but
www.intakehoses.com has some good stuff for making a cai. Done it with the truck that way and will soon with the gta!!
Old Jan 31, 2006 | 09:47 PM
slick88gta's Avatar
Car: 88 GTA
Engine: 350 L98
http://store.airflo.com/rubber-hoses---clamps.html
found that in another thread as well
Old Feb 2, 2006 | 09:06 PM
Engine: 350 tpi
i wish i would have seen the airflow link before those are pretty cheap and clean looking.
Old Feb 2, 2006 | 11:09 PM
slick88gta's Avatar
Car: 88 GTA
Engine: 350 L98
Yea they look good, just as long as their customer services is good, which is hard to find
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
86IROC112
Sep 7, 2015 01:37 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
