Lambo Doors
Old 02-23-2006, 02:58 PM
leech91's Avatar
Car: 91 Camaro RS
Lambo Doors
i know its out there...but how do lamborghini doors look on a 3rd gen camaro..anybody have pictures?? is there a site where i could buy them?
Old 02-23-2006, 03:53 PM
x007's Avatar
Car: Supercharged Nitrous T/A
Engine: Motown 410SBC
Transmission: 4L80 - Compushift / Custom billet torq
Axle/Gears: 12b Moser 33/spl. /373 posi
Here mine !
its a trans-am but...
Going to a full paintbrush job soon !
Old 02-23-2006, 04:11 PM
leech91's Avatar
Car: 91 Camaro RS
yea thats exactly what im looking for whered u get the hinges?
Old 02-23-2006, 04:20 PM
x007's Avatar
look here :
www.aerokits.net
Old 02-23-2006, 05:21 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
wow I can't wait to see that car painted.
Old 02-23-2006, 05:39 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Heres Dennisbernal91z's car (member on here) http://www.cardomain.com/ride/782913/17 Pretty sick.
Old 02-23-2006, 06:26 PM
x007's Avatar
When you will see the car painted, you will drop from your chair
Old 02-23-2006, 08:47 PM
Engine: L98 and L03
well I almost dropped a brick when I saw your interior so it won't surprise me if i do.
Old 02-23-2006, 09:32 PM
x007's Avatar
i will post pics when done
Old 02-23-2006, 11:52 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
how much room do you loose up by the front of the door? it looks like it sticks back it to the area that you would normally put your feet. Im 6'3" and i need all the room i can get.
Edit: I cant find any hinges that are for a camaro so which ones did you use and how much did you have to modify them?
Old 02-24-2006, 10:51 AM
x007's Avatar
THats not too bad for space, that worse for me a bit because of the Roll Bar, but not too bad...
You need the Diablo GTF kit, thats a universal kit whit two shock each side that support up to 300lbs.
Need welding & some cutting, you have to be realy carefull when installing to make sure all fit perfect before completly weld it !
Old 02-25-2006, 01:16 AM
Engine: L98 and L03
that's the kit I was looking at.
Old 02-25-2006, 04:03 PM
Kandied91z's Avatar
definately interesting...
LSD also makes a kit.
anyone know who makes the kit autoloc uses?
if the car wasn't so square it would look great, good job either way.
Old 02-25-2006, 06:26 PM
xplane's Avatar
Engine: 2.8 MFI
I wouldnt care how it looks as long as it looks normal closed. i just want it for the fact that if ya open the stock door enough to get out is sticks out like 4' to the side. its always fun to get out if your parked along side the road during rush hour.
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
meeklay812
10-01-2015 03:46 PM
kkirch15
09-30-2015 04:44 PM
Quick Reply: Lambo Doors
