LS1 finally 99% done.
Old Feb 26, 2006 | 06:56 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Just a few finished pics. Took forever on the ram-air box. Its part old radiator cover, part RAII hood kit, and part LS1 whisper lid. A bunch of fiberglass later it's finished.
The fuel rail covers will be smoothed and painted body color, I surprisingly only had to trim a bit by the throttle cables. I might get a new one as I didn't need to trim as much as I did.
Be sure to notice the 4th gen cruise, overflow, washer tank, and wiring.. Still need to get AC hoses done. I really didn't enjoy ripping a big hole in the RA1 hood, but there's a wide open path to the filter now. There's foam on the hood that seals the back side from engine air.
Thanks for all the direct and indirect help in getting it done.
Kevin D.
As you can see, I've got a while to go on the interior..
Old Feb 26, 2006 | 08:05 PM
Camaro0605's Avatar
Car: 1991 RS
Looks great.
I like the 4th gen washer fluid, and overflow tanks. Really cleans up the engine bay bye not having the ugly discolored 3rd gen's in there.
Old Feb 26, 2006 | 08:21 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Watch out! I think you are dangerously close to having a car that has a majority of 4th Gen parts.
The install looks great. How many hours a week on average do you put into your car?
This will be one of the sweetest 'verts on the board when you finish.
Old Feb 26, 2006 | 09:54 PM
shr00m's Avatar
Originally posted by Jade Grey
[B]Watch out! I think you are dangerously close to having a car that has a majority of 4th Gen parts.
Best of both worlds I guess.. Having owned a higher mileage 25th Anniversary convertible TA, I know that 'rarity' value is based on low mileage. Even though it is a rarer jade bird it was past the point of holding its 'rarity' value.
As long as it's taken to get to this point, I would say on average not much. As long as I'm not waiting on parts (or money to buy parts) I'd say 10 hours a week??
Kevin D.
Old Feb 27, 2006 | 01:40 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
WOW!!! Looking good. Must be nice to be 99% done LOL. Its going to look so clean when your all done. What year is that LS1 motor? How did you hook up your A/C wiring?
Old Feb 27, 2006 | 12:14 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
How did you do the fuel tank and pressure regulator? I want to get the LS1 plastic tank but I want to run it like the LS1 on my gen 1 miniram. Basically I want to eliminate the return line.
Old Feb 27, 2006 | 03:35 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
what did you do with the brake lines? are you using the stock 3rd gen brake cylinder? how many lines did you run? 2 for the front and 1 for the back?
Old Feb 27, 2006 | 06:18 PM
shr00m's Avatar
It's a 2000 LS1, with all emission stuff removed. It's got an LS6 intake modfied for EGR, which now holds the IAT sensor. Ac wiring is all stock 4th gen (included the controls etc.) You can't see, but all the HVAC mess on top of the blower case is removed. The 4th gen has all that inside the dash. The only thing not hooked up is the pressure sensor, it will go in the line I need to make. 4th gen PCM uses one sensor for pressure that tells it whether it's high,low, or correct. The third-gen uses two sensors, one for too low and one for two high.
It's 3rd gen booster, 4th gen master, 3rd gen prop valve. It's stock 3rd gen brake lines with no ABS. Only reason I swapped the MC is for the 4th gen fluid sensor.
Kevin D.
Old Feb 27, 2006 | 06:20 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Cool thanks alot! thats exactly the setup ill be using just wanted to confirm it would actually work.
Old Feb 27, 2006 | 10:26 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
wow, that looks awesome. If your car was a t-top car instead of a vert, I think that would be my favorite ride on the site. Jade LS1...ooh.
Old Feb 27, 2006 | 10:30 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Looks fabulous, Kevin.
When do you attack the interior?
Old Mar 2, 2006 | 08:49 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Looks good, cool car!
*As for ruining a rare car... I know how you feel. My '91 GTA was originally a 305TPI/5spd/hardtop car... pretty damn rare. With all the miles on it though I'm sure the value would've been hurt. Oh well, I'm building it into what I want and its never leaving my family!
Old Mar 4, 2006 | 09:39 AM
Cadillac's Avatar
Both of you have the cars I envy most on this forum. Awesome car-flesh. Jeremy... remember: My offer always stands.
Old Mar 4, 2006 | 09:54 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
*What offer?
Old Mar 4, 2006 | 10:34 AM
Cadillac's Avatar
*What offer?
PM long ago. Remember?
You shot me down even then.
Old Mar 4, 2006 | 01:33 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
WOW that looks great, good work.
Old Mar 9, 2006 | 01:39 PM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
she's beautiful... hope mine comes out looking that good. Great work!
Old Mar 11, 2006 | 11:36 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Very nice work Summer cant get here soon enough
Old Mar 21, 2006 | 03:49 PM
PewterLS1's Avatar
Car: 2001 Chevrolet Camaro Z/28
Engine: LS1 346cid
Axle/Gears: Stock 10 Bolt W/2.73
Nice job! This is by far one of the cleanest swaps I've seen. I was contemplating on a swap in my 88 Formula, but I took the cheaper route :-D (As noted on below) . To date, how much have you sunk into the swap, including price of the LS1?
Old Mar 21, 2006 | 05:30 PM
shr00m's Avatar
Originally Posted by PewterLS1
Nice job! To date, how much have you sunk into the swap, including price of the LS1?
Thanks. If you take 'time' out of the equation, I think I got back down to the break-even point. I was ahead by about $500 until all the little crap started adding up.
I part cars on the side and kept what I needed from one of them. This includes selling things I didn't need from the 92 as well. Now the interior side of things will more then make up for it though.
Kevin D.
Old Mar 22, 2006 | 12:18 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Thats looking pretty damn good Shroom. Damn I wish summer would come.
Old Apr 2, 2006 | 08:09 PM
snowbird88gta's Avatar
Car: 88 GTA
Axle/Gears: Stock 3.23's
Nice setup man!!! That thing is wicked clean. I might be doing the ram air thing later on but for now I am sticking to my custom (lol) cold air intake. Yours would probably be a little better but right now I'm broke and a new hood isn't that high on the priority list
Old Apr 2, 2006 | 09:44 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
Thats really cool with what you did on the intake. I have a feeling that the unit you made could be used on LT1 swaps as well as factory motors. I would like to have a setup like your eventually, but for the time being I am interested in making an intake like yours for my 350 TPI motor and use one of the ram air ones.
Old Apr 4, 2006 | 10:20 PM
SnkSknrZ28's Avatar
Shroom, what is this a pic of, i believe i am missing this although i have 3 boxes of stuff sitting here so maybe i just over looked it. any help would be great, thanks
MJ
Old Apr 4, 2006 | 10:58 PM
shr00m's Avatar
That's the under hood fuse panel / relay boxes. It's on the body side harness, so if you just purchased an engine combo, you shouldn't have it.
It's not needed at all for the LS1 swap, just needed when using the full 4th gen wiring.
Kevin D.
Old Apr 5, 2006 | 10:59 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
hey Shr00m or anyone else doing or done with the LS1 swap, did you put in the 4th gen engine harness before dropping the engine in? i ask because i got nothign to do until my damn k-member gets done. Wondering if it would be easier to do now or later?
Old Apr 5, 2006 | 06:01 PM
shr00m's Avatar
The engine harness is best left on the engine. It's pretty easy to drop it in all together (or attach it to the crossmember and drop the car on it like I did.)
Kevin D.
Old Apr 5, 2006 | 09:08 PM
SnkSknrZ28's Avatar
Kevin D.
full 4th gen wiring? well i have an engine harness and interior harness, the interior i might just adapt the connectors to my stock harness.. hmm i'm wonderign if i will need it for my swap, i'll have to look into this further..
thanks for the info,
mj
Old Apr 5, 2006 | 10:00 PM
shr00m's Avatar
Yeah the interior harness is kind of useless without the body harness. The make a 'triangle' connection. Engine connects to the the body harness, body connects to the interior, interior then connects back to the engine harness.
If you're swapping the dash over and don't feel like getting a body harness, your best bet is to get the engine in and running witout worrying about gauges. Then swap the dash over and hook the 4th gen gauges up to the 4th gen engine harness.
I've got a spare body harness off a 99TA, PM me if you're interested. Very few pigtails cut off of it.
Kevin D.
Old Apr 6, 2006 | 12:47 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Damn Shr00m, every time I see your engine bay pics I have to double take because it looks so much like mine.
Its nice to have all the harnesses because if you happen to need a connecter you have it. I used the 4th gen interior harness to wire up my swap. Tho I had to make custom connectors to get my interior harness to connect to the engine harness. I am also using the interior harness in my 4th gen dash swap to wire in my gauges to the motor and the light switch and the heat ect.
Shr00m, I might be interested in that body harness I think, just to clean up the wiring under my hood. Could ya throw me a PM and give me some details and what not about whats cut and how much your looking to get? Thanks.
Old Apr 6, 2006 | 05:25 PM
SnkSknrZ28's Avatar
Thats pretty much was i was banking on doing shroom.. for the next few months i'm gonna swap the motor & tranny in, get that done and situated, then over the next winter i will do the interior swap, i got a great deal on all these parts so i grabbed it, took the leather interior and everything.. So for now i'm gonna just concentrate on the motor/tranny stuff, that'll be enough work for this season
Im sure ill have many many more questions
Old Apr 12, 2006 | 12:36 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
how are ya getting around needing 2 O2 sensors?
Old Apr 12, 2006 | 09:22 PM
shr00m's Avatar
Not sure what you mean. They come with 4, I've removed the back two and will program them out of the PCM. One of the fronts screws in the manifold, the other will screw into my y-pipe.
Kevin D.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
