what cars have big enough turbos?
what are some common cars that hold big enough turbos to make a twin turbo smallblock f-body? i have 2 3rd gen supra turbos which are CT-26's and somebody told me they are to much of a "high end" turbo and i also have 2 2.2 chrysler turbos TEO4H's which someone else told me they were too small. there are plenty of cars out there with turbos in the local junkyards. volvos, saabs, dodge, lots. i just need to know which ones to get. and if anyone knows about the CT-26's i have i would like to use those or the TEO4H's. thanks for the help
race it or sell it
race it or sell it
Chrysler 2.2s are about 135 cid so the turbos are suited to the small block I read some time ago that the to4 turbos were the ones to use on twin setups for small blocks but I haven't done one myself
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
with a tpi engine you would want a little more high end than you'd think it's tough to get a 3rd gen planted n/a combine that with it running out of air at 4800 you'd want the turbo to force feed the motor above 3500 IMO i would recommend logging on to mkiv.com(supra site)some of those guys are running low 10's they'll be able to help you as far as the turbo specs and applications.
Guido is correct. For the airflow requirements of a V8, use 2 stock GN turbos. The CT-26 turbos from a MKIII Supra will also work. In a pinch, use 2 TD05H-14B turbos from 5-speed DSM cars.
1989 Trans Am
GM tall deck Bow-Tie block
TH400 w/transbrake
Hahn Racecraft turbosystem
NOS dry-fogger kit
Gunnin' for 8's
1994 Toyota Supra Turbo
6-speed, sportroof
11-second daily driver
1994 Jeep Grand Cherokee Limited
5.2L V8, loaded
K&N Filtercharger kit w/cold air intake
Flowmaster cat-back
Pioneer/Polk Audio CD system
FOR SALE!
Member of Midwest F-Body Association www.mfba.org
1989 Trans Am
TH400 w/transbrake
NOS dry-fogger kit
Gunnin' for 8's
6-speed, sportroof
5.2L V8, loaded
Flowmaster cat-back
FOR SALE!
Car: 1992 B4C 1LE
how about the DSM 16G turbo (thwo of them)
The T3 tubos off of 2.3 turbo coups work well. You have to resize the turbin housing A/R to .82 and change the compressor wheel to a 60 trim and you'll have some very decent power on hand. It should make around 10 lbs of boost.
I know I'm a little late here, but I made over 500rwhp on a bone stock 5.0 (FORD, I know, I know) in my mustang. The only thing I messed with use the EEC and the fuel system.
I used two t3 turbos with the .48 A/R housing, which are the smaller of the two that come on the t-bird turbocoupes. The T3 is basically the 'standard' in JY turbos...especially for fords, I would assume that a 5.0 or 5.7 GM would be the same.
So has anyone built a kit for the third gens?
Shawn
Shawn
Car: 1992 B4C 1LE
Shawn
Shawn
Car: 1992 B4C 1LE
yeah its called buy some steampipe and weld it together and get some junkyard turbos. but you might want to look at this thread https://www.thirdgen.org/techbb2/sho...hreadid=140637
Car: 1991 Z-28
I was going to use 2 T3's with .60/.63 AR housings. I have since changed my mind, due to the sheer cost of even a basic setup. I am going to sell the 3 T3's I have, and save so I can make a better run at biulding a turbo engine.
Shawn
Shawn
I have a BANKS TT KIT for the 3rd gen, possibly for sale, also where do you live, your car sounds exactly like one runnning around Ft. Collins....
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Originally posted by a73camaro
A T3 Garrett with a turbine housing A/R .82 came on the carbed Buick V6's, '77-'83.
Turbo notes
Anyone have twins on a third gen? It seems cramped in these engine bays.. (new to these cars..)
Shawn
Shawn
Check out the link in my sig...
Cheers!
Terrell351
06-13-2021 01:13 PM
