FOR ALL wanting to build a cheap cable for ALDL
Old Feb 8, 2002 | 01:37 PM
89camaroRSV6's Avatar
i have tried this and it really works for ALDL..this is the cheapest way to read ... definitely works till 90 camaros that have PIN E 160 baud..
i havent yet tried this on Pin M 8192 baud
http://w1.601.telia.com/~u60113744/s...dl/winaldl.htm
he is a member of this board... thanx a million to him..
Old Feb 10, 2002 | 02:18 AM
KevGt40's Avatar
What resistor did you use for R3?
Old Feb 10, 2002 | 02:26 AM
depends on wat car u have kev...
i have a 89 ... i use a 10K to read the ALDL ... the software will read all the data and translate it into readings only if a 10K is there... otherwise if u leave it open it reads something but not significant portion of the data...
89 - my computer is a '302( i have both pin E and pin M)
the 91 and later that use 7730 dont have that pin E i guess atleat camaro_hunters 92 RS doesnt have pin E only has pin M which is 8192 baud .. there is a diff circuit and diff software for that .... tell me how the 10K works...
Old Feb 10, 2002 | 02:30 AM
KevGt40's Avatar
Thanks, I think I`ll make it tommorow and try it on my buddies truck.
Old Feb 10, 2002 | 02:33 AM
remember whatever u do ... dont short that place where the resistor is .. althought the circuit says short it for factory test mode....
Old Feb 10, 2002 | 09:24 PM
Greenshamrock77's Avatar
I tried it on the Grand National today, and it works great. I made a trick connector for the ALDL, have pictures, but do not know how to insert images in here.
Click on IMG, and it asks for a javascript prompt. What do I do from there.
Old Feb 13, 2002 | 05:24 PM
Camaro_hunter_d's Avatar
You have to save the pic as a JPeg or GIF. Click browse(for attachment) find the PIC, click it and it will load automatically.
Old Feb 13, 2002 | 05:34 PM
KevGt40's Avatar
Worked awsome!!! However I`m pretty new to GM diagnostics, where can I find the meanings of the flags and anacronyms and good stuff like that.
:hail: winALDL
Old Feb 13, 2002 | 07:49 PM
you need a decoder. 89RS has one. I(or you) can email him and ask. I imagine others have it as well. A search may be advisable for a topic thread.
Old Feb 13, 2002 | 09:03 PM
here goes nothing...
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00214.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00215.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00216.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00217.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00218.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00227.jpg[/IMG]
[IMG]C:\My Documents\GNSTUFF\IMCIF100\Dsc00219.jpg[/IMG]
The pins I used are from the chassis to engine harness connectors (chassis side) that are behind the dash on the passenger side.
Attached Thumbnails FOR ALL wanting to build a cheap cable for ALDL-dsc00213.jpg
Old Feb 13, 2002 | 09:13 PM
wow it worked.
To mount the pins, I first drilled holes in the case that were in the proper positions, slid the pins through, and plugged them into an ALDL I got from the junk yard to mock it up. Then poured 5 min epoxy all over the inside back of the pins to finish. It worked great. Only three of those pins actually do anything, but the others offer additional support and locate the pins in the proper socket in the ALDL. I would have used a smaller box, but already had that one.
Old Feb 13, 2002 | 09:45 PM
KevGt40's Avatar
I went for a ride in my buddies truck today, and I don't know what everything is supposed to look like when it is operating normally. Can someone look at this and see if it is messed up as I think it is........
File Type: zip
Old Feb 13, 2002 | 10:30 PM
hey kevin,
i saw that log it seems fine to me...lol when u data log using WinALDL it is better if u dont record the RAW values...cos it just takes space...
what i do is record the sensor data , flags and error codes and import the file into excel that way i can read it better , and also graph all the functions to time (which seems real cool at this point)
well kevin what do u mean when u say meaning of the flags ... do u mean like MAF = Mass Air Flow, and so on...
well our cars have a lot of sensors and so there are many of the values are here... one of the major uses of this is that it can detect the error codes that costly machines like AutoXray detect like for example all the error codes are shown which act just like the scanner....
and lol kevin do u own a GT40 ...if ya i wanna drive in that
Old Feb 13, 2002 | 10:41 PM
KevGt40's Avatar
LOL, no I don't have a GT40, but if I told you what I drive, you`all might not help me All of my friends are Chevy guys, but I enjoy working on cars not matter what they are.
Thanks for the advice about the dataloging, the flag question is that the rich flag is continually flashing, I`m not sure why. As well, why is the MAP only 27 kpa at idle, is the MAP ported vacuum? And what is the proper range for o2 sensor operation. If reference is .45, what is .1 and what is .8 in stoiechiometric ratio.
It's just as we were driving, some of the values didn't seem to jive.
Thanks for your time dude. :hail: Your the man
Old Feb 14, 2002 | 01:11 AM
kevin ill help ppl irespective of what they drive ....
well i cant answer ur Question on MAP cos i have a MAF
and i know the 02 sensor runs like this
u can even connect a volt meter to the o2 sensor to read the Air fuel ratio ... the value from the o2 sensor ranges from 0.1v to 1V
my understainding is that when u cruise the meter will show 0.1v
and 1v when ur accelerating hard...so i guess 0.1v is lean and 1v is rich...all those fancy a/f gauges are basically voltmeters....with a sensitivity of .1v / led
on my car sometimes the rich flag pops on then suddenly goes off...
well when i was driving amnd loggin sometimes my park /Neutral flag kept flashing ... i donno if that was a bug too... sometimes my TCC lockup wouldnt enabel but i could hear the car lockup so i dont know if that software is 100% correct as its only 160 baud the sample rate is very slow thats why im switching to PIN M which is 8192 connector...which ill be building sometime this week..
and what do u drive anyway...lol ..I love the GT40 anyways
Old Feb 14, 2002 | 11:31 AM
formula5's Avatar
What k resistor for 89 maf??Which diagram did you use,jonas or peter version?
Old Feb 14, 2002 | 02:35 PM
for 89 MAF ..same as what i ahve ... use 10K and the diagram is in the link on my first post here on this thread...
Old Feb 22, 2002 | 12:15 AM
KevGt40's Avatar
I was away for a little while.... anyways, my daily driver is a 87 Mercury Cougar 20th Anniversay, but my real car is an 88 Mustang GT. Yes, I`m Blue Oval loyal. After I get out of school, I`m thinking of getting a GT40 kit car/replicas. Not those cheezy ones based off a Fiero, but a real replica with the Monocouque construction.
BTW, I used to work a a GM dealership and will never forget taking a new Camaro SS for a "test drive" That car was AWSOME, and I`m not afraid to admit it. Think is was a '99
9192camaro
16
Feb 3, 2019 12:21 AM
italiano67
Dec 11, 2016 09:21 AM
86camaroman201
Aug 19, 2015 04:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
